• Hardware: AGX Orin
• Network Type: Any
• TAO Version: 5.0.0
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hi.
I am trying to use TAO-Deploy to export a model to .engine
format for a Jetson device. As mentioned in the TAO Deploy Github, you need to run the following commands when using tao-deploy on aarch64 devices.
sudo docker run -it --rm --net=host --runtime nvidia nvcr.io/nvidia/l4t-tensorrt:8.5.2.2-devel /bin/bash
apt update
apt install libopenmpi-dev
pip install nvidia_tao_deploy==5.0.0.423.dev0
pip install https://urm.nvidia.com/artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
pip install https://urm.nvidia.com/artifactory/sw-eff-pypi/nvidia-eff/0.6.2/nvidia_eff-0.6.2-py38-none-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
However, I am unable to download the nvidia-eff-tao-encryption
and nvidia_eff
wheels, logs below.
Collecting nvidia-eff-tao-encryption==0.1.7
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff854a4b20>: Failed to establish a new connection: [Errno -5] No address associated with hostname')': /artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff854a4e20>: Failed to establish a new connection: [Errno -5] No address associated with hostname')': /artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff854c20d0>: Failed to establish a new connection: [Errno -5] No address associated with hostname')': /artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff854c22e0>: Failed to establish a new connection: [Errno -5] No address associated with hostname')': /artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff854c24c0>: Failed to establish a new connection: [Errno -5] No address associated with hostname')': /artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl
ERROR: Could not install packages due to an OSError: HTTPSConnectionPool(host='urm.nvidia.com', port=443): Max retries exceeded with url: /artifactory/sw-eff-pypi/nvidia-eff-tao-encryption/0.1.7/nvidia_eff_tao_encryption-0.1.7-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (Caused by NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xffff854c26a0>: Failed to establish a new connection: [Errno -5] No address associated with hostname'))
Any assistance will be appreciated.
Kind regards,
Nicholas
