Installation error in setting up tao in nvidia-tensorflow in jetson nano
I am trying to use BYOM in tao toolkit to convert my onnx model. I am following the steps given on the official webstie. I am getting error when i am installing nvidia-tensorflow
pip3 install nvidia-tensorflow
system information:
model: Jetson nano 4gb
deepstream version:6.0
jetpack version: 4.6
pytorch:1.08
RuntimeError:
The package you are trying to install is only a placeholder project on PyPI.org repository.
This package is hosted on NVIDIA Python Package Index.
This package can be installed as:
$ pip install nvidia-pyindex
$ pip install nvidia-tensorflow
Please refer to NVIDIA instructions: https://github.com/NVIDIA/tensorflow#install.
WARNING: Discarding https://files.pythonhosted.org/packages/c7/b8/b96bd09cc7c9cf9dbd8b82313c4f9860fe615b3ce7f3f6efc962d166178b/nvidia-tensorflow-0.0.1.dev5.tar.gz#sha256=65f44f1b583b950925a3617a75fd299c29975f1f14327bb2d946cb52e84baef5 (from Links for nvidia-tensorflow). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Downloading nvidia-tensorflow-0.0.1.dev4.tar.gz (3.8 kB)
Preparing metadata (setup.py) … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-yso1a_vu/nvidia-tensorflow_e72f8fea991e40399d96149f68cb1415/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-yso1a_vu/nvidia-tensorflow_e72f8fea991e40399d96149f68cb1415/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base /tmp/pip-pip-egg-info-ib8hf0en
cwd: /tmp/pip-install-yso1a_vu/nvidia-tensorflow_e72f8fea991e40399d96149f68cb1415/
Complete output (17 lines):
File “”, line 1, in
File “/tmp/pip-install-yso1a_vu/nvidia-tensorflow_e72f8fea991e40399d96149f68cb1415/setup.py”, line 150, in
raise RuntimeError(open(“ERROR.txt”, “r”).read())
RuntimeError:
WARNING: Discarding https://files.pythonhosted.org/packages/97/39/b1aa7fe84e2ad1f183f5fc851bea78bb46a73ebb9a91ffed0878f656f2f6/nvidia-tensorflow-0.0.1.dev4.tar.gz#sha256=1be0b140aadedcd7a05f736566587bb1aacc6baa1797d7fda7d8f23e59f35142 (from Links for nvidia-tensorflow). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement nvidia-tensorflow (from versions: 0.0.1.dev4, 0.0.1.dev5)
ERROR: No matching distribution found for nvidia-tensorflow
I am moving your topic to the Jetson Nano category so the Jetson support team has visibility.
Please find the below document to install TensorFlow on Jetson:
Thank you @AastaLLL for reply. I have successfully installed tesnorflow on my device but when I am installing
pip3 install nvidia-tao-byom
I am getting the follwoing error
If anyhow netron is solved agin i am getting error related to nvidia-eff version.
Please install the converter on a desktop environment and generate the etlt model first.
Then copy the etlt model to Jetson and run it with Deepstream.
