I am running the YOLO 3 Google colab work book and I am having an issue downloading the DATA SET.
I have retrived the DAT Set links from my e-mail and put them in the Colab script but I am getting a syntax error.
I have put the download links into my browser and it works but the script in the Colab workbook says there is a syntax error.
import os
!mkdir -p $DATA_DIR
os.environ[“URL_IMAGES”]= https://urldefense.com/v3/__https://s3.eu-central-1.amazonaws.com/avg-kitti/data_object_image_2.zip__;!!AWL9ZJ8!LrBzKGNXJ6O2OcSnkkMJoIGOcvrwxGoe8FjNY9vEjzF7n_kWWvOyl-8afGyjsaSAZ5hG8bMdDMmmXQ$
!if [ ! -f $DATA_DIR/data_object_image_2.zip ]; then wget $URL_IMAGES -O $DATA_DIR/data_object_image_2.zip; else echo “image archive already downloaded”; fi
os.environ[“URL_LABELS”]= https://urldefense.com/v3/__https://s3.eu-central-1.amazonaws.com/avg-kitti/data_object_label_2.zip__;!!AWL9ZJ8!PNbax0sC4KLreQXdzQ70EwsIdeklr-g15MW9n_ig5xK8BxhOzXWrgvQD-4HztOyP1sGIghn-v1MOxw$
!if [ ! -f $DATA_DIR/data_object_label_2.zip ]; then wget $URL_LABELS -O $DATA_DIR/data_object_label_2.zip; else echo “label archive already downloaded”; fi
Here is error:
File "<ipython-input-5-f46475096188>", line 3
os.environ["URL_IMAGES"]= https://urldefense.com/v3/__https://s3.eu-central-1.amazonaws.com/avg-kitti/data_object_image_2.zip__;!!AWL9ZJ8!LrBzKGNXJ6O2OcSnkkMJoIGOcvrwxGoe8FjNY9vEjzF7n_kWWvOyl-8afGyjsaSAZ5hG8bMdDMmmXQ$
SyntaxError: invalid syntax
