Hello. I’ve updated the latest ngc api key and input in in the variable named ngc_api_key
However. I got 401 unauthorized error as the picture below when I tried logining.
How should I do to deal with the problem ?
It is a known issue since last week.
Please use below workaround.
ports:
-name: api
nodePort: 31951
port: 8000
protocol: TCP
targetPort: 8000
type: NodePort
As seen as below,
Then double check with $ kubectl get services
Please note that, login API will still return {} an empty dict. That is expected.
In the notebook, instead of calling the login API, you can just do :
import uuid
user_id = str(uuid.uuid4())
token = “whatever”
Also change the port of the host_url
Reference for this step.
It works ! Thank you very much @Morganh
