Is NVIDIA Jetson Xavier ITAR export controlle item?
Is there a solution or version of NVIDIA Jetson Xavier adapted for exclusively conductive cooling?
Are there any wet capacitors inside the NVIDIA Jetson Xavier?
Will the computer work after exposure to vacuum in non operating state?
Thanks,
V.
Please refer to regulatory docs in DLC: https://developer.nvidia.com/embedded/dlc/agx-xavier-regulatory-compliance-docs, ITAR is not supported.
For a cooling solution please refer to ecosystem: https://developer.nvidia.com/embedded/community/ecosystem
No wet capacitors on board.
No vacuum test done as you can see in the tests table in module datasheet: https://developer.nvidia.com/jetson-agx-xavier-series-datasheet
