Hardware platform: Jetson Xavier NX
Software version:
config A: Jetpack 4.6.4 + DeepStream 6.0.1 + TensorRT 8.2.1.9
config B: Jetpack 5.1 + DeepStream 6.2.0 + TensorRT 8.5.2.2
Issue type: question
Hi!
I’m trying to build a pipeline which splits the batched stream into two sub-streams and then demuxes the batched sub-streams, but have trouble migrating from DeepStream 6.0 to DeepStream 6.2.
My pipeline (see sample pipeline 1 below) works with DeepStream 6.0 (config A) but not with DeepStream 6.2 (config B).
Curiously,
-changing the order from tee->demux to demux->tee makes the pipeline work (see sample pipeline 2 below).
-changing the number of sub-streams from 2 to 1 makes the pipeline work (see sample pipeline 3 below).
Now, what I would like to know:
-what is wrong with sample pipeline 1 ?
-which gstreamer element causes the issue, and in what way has it changed between DeepStream versions 6.0 and 6.2 ?
-is there any official documentation (where?) that details the changes that caused the issue?
Note: I use “deepstream-6.2” folder in the paths (for models and video files) of the sample pipelines below.
When running with DeepStream 6.0, the folder paths need to be adjusted to “deepstream-6.0”.
Pipeline 1 (tee then 2x demux)(works with config A, but never completes with config B)
(when interrupting with ctrl+c on config B, console says ‘pipeline doesnt want to preroll’):
gst-launch-1.0 -vvv \
filesrc location=/opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.h264 ! \
h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1920 height=1080 ! \
nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/config_infer_primary.txt ! \
nvvideoconvert ! nvdsosd ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=I420' ! \
t.sink tee name=t \
t.src_0 ! d0.sink nvstreamdemux name=d0 \
t.src_1 ! d1.sink nvstreamdemux name=d1 \
d0.src_0 ! nvv4l2h264enc ! h264parse ! filesink location=test3.mp4 \
d1.src_0 ! nvv4l2h264enc ! h264parse ! filesink location=test4.mp4
Pipeline 2 (first demux then tee)(works with config A and B):
d.sink nvstreamdemux name=d \
d.src_0 ! t.sink tee name=t \
t.src_0 ! nvv4l2h264enc ! h264parse ! filesink location=test1.mp4 \
t.src_1 ! nvv4l2h264enc ! h264parse ! filesink location=test2.mp4
Pipeline 3 (tee then 1x demux)(works with config A and B):
t.sink tee name=t \
