Hi and appreciate your response and would like your further comments on my diagnosis action here, and suggest possible troubleshooting steps.
Right from the start, the Logitech F710 was set for “X” out of the box. Rebooting the Nano Jetson and the usual updates, sudo apt-get update, upgrade, list-upgrade, and "rsync jetbot/notebooks ~/Notebooks did not appear to enable the gamepad in the Notebook. I also checked lsusb and dmesg, as follows, that shows the Gamepad appears to be collected to Ubuntu.
jetbot@jetbot:~$ lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0a2b Intel Corp.
Bus 001 Device 006: ID 046d:c21f Logitech, Inc. F710 Wireless Gamepad [XInput Mode]
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
jetbot@jetbot:~$ dmesg | grep gamepad
jetbot@jetbot:~$ dmesg | grep Logitech
[ 9.024635] usb 1-2.2: Manufacturer: Logitech
[ 9.142803] usb 1-2.4: Product: Logitech Cordless RumblePad 2
[ 9.142806] usb 1-2.4: Manufacturer: Logitech
[ 9.145635] hid-generic 0003:046D:C22F.0004: hidraw0: USB HID v1.11 Device [Logitech Logitech Cordless RumblePad 2] on usb-70090000.xusb-2.4/input0
[ 9.147602] hid-generic 0003:046D:C22F.0005: hidraw1: USB HID v1.11 Device [Logitech Logitech Cordless RumblePad 2] on usb-70090000.xusb-2.4/input1
[ 9.976788] logitech-djreceiver 0003:046D:C52B.0003: hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-70090000.xusb-2.2/input2
[ 10.149106] input: Logitech K400 Plus as /devices/70090000.xusb/usb1/1-2/1-2.2/1-2.2:1.2/0003:046D:C52B.0003/0003:046D:404D.0006/input/input2
[ 10.195240] logitech-hidpp-device 0003:046D:404D.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech K400 Plus] on usb-70090000.xusb-2.2:1
[ 15.416493] usb 1-2.4: Manufacturer: Logitech
[ 15.418012] input: Logitech Gamepad F710 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input3
jetbot@jetbot:~$
jetbot@jetbot:~$ ls -l /dev/input/js*
crw-rw-r–+ 1 root input 13, 0 Jul 9 20:05 /dev/input/js0
jetbot@jetbot:~$
jstest-gtk app also indicates the F710 is properly connected to /dev/input/js0.
One more thing, running https://html5gamepad.com displays the F710 and proper button and joystick operation. The name is Logitech Wireless Gamepad F710(Standard GAMEPAD Vendor 046d Product c21f. And on the Nano desktop opening in the Chrome Browser: [b]https://gamedevelopment.tutsplus.com/tutorials/using-the-html5-gamepad-api-to-add-controller-support-to-browser-games--cms-21345[/b] has an html Demo that correctly reads the gamepad and displays the Button and Joystick status.:
Gamepad connected!
id: Logitech Wireless Gamepad F710 (STANDARD GAMEPAD Vendor: o4gd Product c21f
Button1…
Stick 1:0, -0.00000061…
Stick 2:0, -0.00000061…
Here’s the Jupiter Notebook sequence from my Mac Safari Browser connected to the Nano Jetbot:
Create gamepad controller
The first thing we want to do is create an instance of the Controller widget, which we’ll use to drive our robot. The Controller widget takes a index parameter, which specifies the number of the controller. This is useful in case you have multiple controllers attached, or some gamepads appear as multiple controllers. To determine the index of the controller you’re using,
Visit http://html5gamepad.com.
Press buttons on the gamepad you’re using
Remember the index of the gamepad that is responding to the button presses
Next, we’ll create and display our controller using that index.
import ipywidgets.widgets as widgets
controller = widgets.Controller(index=1) # replace with index of your controller
display(controller)
Connect gamepad and press any button.
Even if the index is correct, you may see the text Connect gamepad and press any button. That’s because the gamepad hasn’t registered with this notebook yet. Press a button and you should see the gamepad widget appear above.
*** Nothing happens here***
from jetbot import Robot
import traitlets
robot = Robot()
left_link = traitlets.dlink((controller.axes[1], ‘value’), (robot.left_motor, ‘value’), transform=lambda x: -x)
right_link = traitlets.dlink((controller.axes[3], ‘value’), (robot.right_motor, ‘value’), transform=lambda x: -x)
IndexError Traceback (most recent call last)
in
4 robot = Robot()
5
----> 6 left_link = traitlets.dlink((controller.axes[1], ‘value’), (robot.left_motor, ‘value’), transform=lambda x: -x)
7 right_link = traitlets.dlink((controller.axes[3], ‘value’), (robot.right_motor, ‘value’), transform=lambda x: -x)
IndexError: tuple index out of range
Awesome! Our robot should now respond to our gamepad controller movements. Now we want to view the live video feed from the camera!
The following Notebook cells that show the Camera image work correctly
