Folks I am having trouble flashing the Jetson nano
-With the SDK manager I get the next output:
20:26:12 INFO : Flash Jetson Nano : Start to install 'Flash Jetson Nano'
20:26:13 DEBUG : Flash Jetson Nano : running command < cd '/home/luis/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/luis/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/luis/.nvsdkm/logs/JetPack_4.2_Linux' -p='3689' -t='P3448-0000' -e='undefined' >
20:26:13 INFO : Flash Jetson Nano : [ Disk Avail:4.56 GB ]
20:26:13 INFO : Flash Jetson Nano : Using GenericInstaller to Install NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP
20:26:13 INFO : Flash Jetson Nano : enter working directory: /home/luis/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra
20:26:13 INFO : Flash Jetson Nano : [ Component Install Started ]
20:26:13 INFO : Flash Jetson Nano : current working directory is /home/luis/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448/Linux_for_Tegra
20:26:13 INFO : Flash Jetson Nano : exec_command [target]:
20:26:13 INFO : Flash Jetson Nano : **********************
20:26:13 INFO : Flash Jetson Nano : #!/bin/bash
20:26:13 INFO : Flash Jetson Nano : set -e
20:26:13 INFO : Flash Jetson Nano : export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
20:26:13 INFO : Flash Jetson Nano : sudo reboot forced-recovery
20:26:13 INFO : Flash Jetson Nano : exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh luis@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no luis@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh"
20:26:34 ERROR : Flash Jetson Nano : lost connection
20:26:55 INFO : Flash Jetson Nano : exit status 255
20:26:55 WARNING : Flash Jetson Nano : command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh luis@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no luis@192.168.55.1 "~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh && rm -f ~/tmp_NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP.sh" finished with error, but ignored
20:26:55 INFO : Flash Jetson Nano : exec_command: sleep 20
20:27:15 INFO : Flash Jetson Nano : exec_command: sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
20:27:15 INFO : Flash Jetson Nano : ###############################################################################
20:27:15 INFO : Flash Jetson Nano : # L4T BSP Information:
20:27:15 INFO : Flash Jetson Nano : # R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
20:27:15 INFO : Flash Jetson Nano : # DATE: Wed Mar 13 07:46:13 UTC 2019
20:27:15 INFO : Flash Jetson Nano : Error: probing the target board failed.
20:27:15 INFO : Flash Jetson Nano : Make sure the target board is connected through
20:27:15 INFO : Flash Jetson Nano : USB port and is in recovery mode.
20:27:15 INFO : Flash Jetson Nano : exit status 1
20:27:15 INFO : Flash Jetson Nano : [ Component Install Finished with Error ]
20:27:15 ERROR : Flash Jetson Nano : NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
20:27:15 INFO : Flash Jetson Nano : [ 12.00 KB used. Disk Avail: 4.56 GB ]
20:27:15 INFO : Flash Jetson Nano : [ NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP Install took 1m3s ]
20:27:15 INFO : Flash Jetson Nano : command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 finished with error
20:27:15 ERROR : Flash Jetson Nano : command terminated with error
20:27:15 ERROR : Flash Jetson Nano : install 'Flash Jetson Nano' failure, command < cd '/home/luis/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' ; /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -a='install' -c='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' -i='NV_L4T_FLASH_NANO_WITH_OS_IMAGE_COMP' -v='32.1' -l='/home/luis/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3448' -L='/home/luis/.nvsdkm/logs/JetPack_4.2_Linux' -p='3689' -t='P3448-0000' -e='undefined' > terminated with error
20:27:16 INFO : Device Mode Host Setup in Target SDK : install 'Device Mode Host Setup in Target SDK' Skipped
20:27:16 INFO : DateTime Target Setup : install 'DateTime Target Setup' Skipped
20:27:16 INFO : CUDA Toolkit for L4T : install 'CUDA Toolkit for L4T' Skipped
20:27:16 INFO : cuDNN on Target : install 'cuDNN on Target' Skipped
20:27:17 INFO : TensorRT on Target : install 'TensorRT on Target' Skipped
20:27:17 INFO : OpenCV on Target : install 'OpenCV on Target' Skipped
20:27:17 INFO : VisionWorks on Target : install 'VisionWorks on Target' Skipped
20:27:17 INFO : Multimedia API : install 'Multimedia API' Skipped
20:27:19 INFO : All done!
FLASHING FAILED
Review terminal tab for details. Resolve and RETRY.
 Installation of target SDK components was skipped
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright © 2019,
NVIDIA CORPORATION
All rights reserved.
NVIDIA Developer
-With the command sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1 I get the next output:
-With the command lsusb I get the next output:
Bus 001 Device 006: ID 0955:7f21 NVidia Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 004: ID 0e0f:0008 VMware, Inc.
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
