Hi all,
Passing a function pointer to a CUDA kernel is described in detailed in the SDK project FunctionPointers.
In that example, the function accepts a few unsigned char and float parameters and returns an unsigned char.
My kernel is a TEMPLATE kernel and I would like to pass a TEMPLATE function to it.
To this end, I have tried the following:
- Define a template typedef of the type of function I would like to pass as parameter (typedef cannot be templated as-is, it must be wrapped in a struct/class).
template<class T>
struct Operators
typedef T (*Operator)(T);
- Define a device template function ‘d_Inverse’ of type device Operators::Operator
__device__ Operators<T>::Operator d_Inverse = Inverse;
where Inverse is a host function with a number of overloaded implementations, e.g.,
int Inverse(int i){return 1/i;}
float Inverse(float f){return 1/f;}
- Before the kernel launch, called within a templated “extern” function, I copy the address of ‘d_Inverse’ to a host variable ‘op’.
Operators<T>::Operator op = NULL;
cudaError_t error = cudaMemcpyFromSymbol((void*)&op, d_Inverse, (size_t)sizeof(Operators<T>::Operator));
- I call my kernel with op as parameter of type
Operators<T>::Operator.
This code mimics the strategy adopted for non-templated functions. Unfortunately it fails to compile. In particular, the call
returns a compilation error, whereas the instantiated version of it
Operators<float>::Operator op = NULL;
does not.
Help is greatly appreciated!
Thanks,
Olivier
