Tenorrt模型推理速度,使用jetpack6.2比使用jetpack5.1慢了很多
yolo11s检测模型转换为tensorrt半精度浮点模型做测试,在jetpack5.1上8张图像批处理耗时27毫秒,在jetpack6.2耗时42毫秒,除了jetpack版本不一样,代码、模型和图片都是一样的。
请问可能是什么原因?要查找问题可以从哪些方面入手?谢谢!
Do you test the model with the maximum performance?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Do you test the performance with trtexec?
If yes, could you share the logs with --verbose with us?
yes, tested the model with the maximum performance.
but not tested the performance with trtexec,we will test and share the logs with you.
~0521
