Hello, I am running into an issue similar to this one when trying to run evaluation with an unpruned, un-trained, TrafficCamNet from detectnet_v2 with TAO toolkit version 4.0.1.
Command:
%%bash -s "$tao_container_id" "$TRAFFIC_CAM_MODEL_SPEC_PATH" "$TRAFFIC_CAM_MODEL_PATH" "$KEY"
docker exec $1 detectnet_v2 evaluate --experiment_spec_file $2 --model_file $3 --key $4 --framework tlt
produces the following exception:
2023-07-28 15:40:44.038041: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
2023-07-28 15:40:52,430 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tao-eval/specs/traffic_cam_model_spec.txt
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2023-07-28 15:40:52,435 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2023-07-28 15:40:53,235 [INFO] root: Loading model weights.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2023-07-28 15:40:53,678 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2023-07-28 15:40:53,689 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2023-07-28 15:40:53,721 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2023-07-28 15:40:54,945 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2023-07-28 15:40:54,945 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2023-07-28 15:40:54,946 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2023-07-28 15:40:55,298 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was *not* compiled. Compile it manually.
warnings.warn('No training configuration found in save file: '
2023-07-28 15:40:56,006 [INFO] iva.detectnet_v2.objectives.bbox_objective: Default L1 loss function will be used.
2023-07-28 15:40:56,006 [INFO] root: Building dataloader.
2023-07-28 15:40:57,331 [INFO] root: Sampling mode of the dataloader was set to user_defined.
2023-07-28 15:40:57,332 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2023-07-28 15:40:57,332 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2023-07-28 15:40:57,332 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2023-07-28 15:40:57,332 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 24, io threads: 48, compute threads: 24, buffered batches: 4
2023-07-28 15:40:57,333 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 10552, number of sources: 1, batch size per gpu: 4, steps: 2638
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2023-07-28 15:40:57,373 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff743a1fe10>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff743a1fe10>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-07-28 15:40:57,415 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff743a1fe10>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff743a1fe10>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-07-28 15:40:57,439 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2023-07-28 15:40:57,747 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: False - shard 0 of 1
2023-07-28 15:40:57,755 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2023-07-28 15:40:57,755 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff71fff6dd8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff71fff6dd8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-07-28 15:40:57,774 [WARNING] tensorflow: Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff71fff6dd8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff71fff6dd8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-07-28 15:40:58,081 [INFO] iva.detectnet_v2.evaluation.build_evaluator: Found 10552 samples in validation set
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1607, in _create_c_op
c_op = c_api.TF_FinishOperation(op_desc)
tensorflow.python.framework.errors_impl.InvalidArgumentError: Cannot reshape a tensor with 130560 elements to shape [4,1,4,34,60] (32640 elements) for 'reshape_1_1/Reshape' (op: 'Reshape') with input shapes: [4,16,34,60], [5] and with input tensors computed as partial shapes: input[1] = [4,1,4,34,60].
During handling of the above exception, another exception occurred:
File "</usr/local/lib/python3.6/dist-packages/iva/detectnet_v2/scripts/evaluate.py>", line 3, in <module>
File "<frozen iva.detectnet_v2.scripts.evaluate>", line 204, in <module>
File "<frozen iva.detectnet_v2.scripts.evaluate>", line 194, in <module>
File "<decorator-gen-2>", line 2, in main
File "<frozen iva.detectnet_v2.utilities.timer>", line 46, in wrapped_fn
File "<frozen iva.detectnet_v2.scripts.evaluate>", line 177, in main
File "<frozen iva.detectnet_v2.evaluation.build_evaluator>", line 158, in build_evaluator_for_trained_gridbox
File "<frozen iva.detectnet_v2.model.utilities>", line 30, in _fn_wrapper
File "<frozen iva.detectnet_v2.model.detectnet_model>", line 736, in build_validation_graph
File "<frozen iva.detectnet_v2.model.detectnet_model>", line 690, in build_inference_graph
File "<frozen iva.detectnet_v2.model.detectnet_model>", line 306, in predictions_to_dict
File "<frozen iva.detectnet_v2.objectives.base_objective>", line 98, in reshape_output
File "/usr/local/lib/python3.6/dist-packages/keras/engine/base_layer.py", line 457, in __call__
output = self.call(inputs, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/keras/layers/core.py", line 401, in call
return K.reshape(inputs, (K.shape(inputs)[0],) + self.target_shape)
File "/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py", line 1969, in reshape
return tf.reshape(x, shape)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/array_ops.py", line 131, in reshape
result = gen_array_ops.reshape(tensor, shape, name)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/gen_array_ops.py", line 8115, in reshape
"Reshape", tensor=tensor, shape=shape, name=name)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 513, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
attrs, op_def, compute_device)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1770, in __init__
control_input_ops)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1610, in _create_c_op
raise ValueError(str(e))
ValueError: Cannot reshape a tensor with 130560 elements to shape [4,1,4,34,60] (32640 elements) for 'reshape_1_1/Reshape' (op: 'Reshape') with input shapes: [4,16,34,60], [5] and with input tensors computed as partial shapes: input[1] = [4,1,4,34,60].
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: __init__() missing 4 required positional arguments: 'code', 'msg', 'hdrs', and 'fp'
Execution status: FAIL
• Hardware: Tesla T4
• Network Type: Detectnet_v2/TrafficCamNet) (unpruned)
• Training spec file (see below)
random_seed: 23
model_config {
arch: "resnet"
pretrained_model_file: "/workspace/tao-eval/trafficcamnet/unpruned_v1.0/trafficcamnet_vunpruned_v1.0/resnet18_trafficcamnet.tlt"
num_layers: 18
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
all_projections: true
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
average_precision_mode: INTEGRATE
minimum_detection_ground_truth_overlap {
key: "car"
value: 0.6
evaluation_box_config {
key: "car"
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
dataset_config {
data_sources {
tfrecords_path: "/workspace/tao-eval/data/tfrecords/*"
image_directory_path: "/workspace/tao-eval/coco/data"
image_extension: "jpg"
target_class_mapping {
key: "car"
value: "car"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
enable_auto_resize: true
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
# Taken from notebook example:
postprocessing_config {
target_class_config {
key: "car"
value {
clustering_config {
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.9
coverage_threshold: 0.0
dbscan_eps: 0.2
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
training_config {
batch_size_per_gpu: 4
num_epochs: 120
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-09
optimizer {
adam {
epsilon: 10e-09
beta1: 0.9
beta2: 1.0
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
visualizer {
enabled: true
num_images: 3
scalar_logging_frequency: 50
infrequent_logging_frequency: 5
key: "car"
value: {
coverage_threshold: 0.005
checkpoint_interval: 10
bbox_rasterizer_config {
key: "car"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
bbox_min_radius: 1.0
deadzone_radius: 0.4
My coco_config file is used for dataset conversion:
coco_traffic_cam_spec.txt
coco_config {
root_directory_path: "/workspace/tao-eval/coco/"
img_dir_names: ["data"]
annotation_files: ["labels.json"]
num_partitions: 1
num_shards: [8]
image_directory_path: "/workspace/tao-eval/coco/"
key: "vehicle" # Label from dataset
value: "car" # Label in TrafficCamNet
which works properly for the following command:
%%bash -s "$tao_container_id" "$TRAFFIC_CAM_DATA_SPEC_PATH" "$CONVERT_OUTPUT_DIR"
docker exec $1 detectnet_v2 dataset_convert --dataset_export_spec $2 --output_filename $3
with output:
2023-07-28 15:40:11,559 [INFO] iva.detectnet_v2.dataio.build_converter: Instantiating a coco converter
2023-07-28 15:40:12,287 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 0
2023-07-28 15:40:12,613 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 1
2023-07-28 15:40:12,951 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 2
2023-07-28 15:40:13,293 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 3
2023-07-28 15:40:13,612 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 4
2023-07-28 15:40:13,925 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 5
2023-07-28 15:40:14,214 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 6
2023-07-28 15:40:14,489 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 7
2023-07-28 15:40:14,765 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib:
Wrote the following numbers of objects:
b'vehicle': 38956
2023-07-28 15:40:14,765 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 0
2023-07-28 15:40:15,097 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 1
2023-07-28 15:40:15,439 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 2
2023-07-28 15:40:15,758 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 3
2023-07-28 15:40:16,084 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 4
2023-07-28 15:40:16,406 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 5
2023-07-28 15:40:16,695 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 6
2023-07-28 15:40:16,983 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 7
2023-07-28 15:40:17,276 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib:
b'vehicle': 38956
2023-07-28 15:40:17,276 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Cumulative object statistics
b'vehicle': 77912
2023-07-28 15:40:17,276 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Class map.
Label in GT: Label in tfrecords file
vehicle: vehicle
2023-07-28 15:40:17,276 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Tfrecords generation complete.
loading annotations into memory...
Done (t=0.26s)
creating index...
index created!
Done (t=0.42s)
creating index...
index created!
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
Note that in my training spec I have preprocessing
in augmentation_config
set to the output dimensions expected by TrafficCamNet, which is 960x544.
My TFRecord input files are of uniform dimension (640x480) with a single label class. Dimension uniformity confirmed by this script:
import tensorflow as tf
import os
tfrecord_dir = "/workspace/tao-eval/data/tfrecords/"
files = os.listdir(tfrecord_dir)
expected_frame_width = 640
expected_frame_height = 480
found_width = []
found_height = []
for file in files:
full_path = tfrecord_dir + file
tfrecords_iter = tf.python_io.tf_record_iterator(full_path)
for record in tfrecords_iter:
example = tf.train.Example()
example.ParseFromString(record)
features = example.features.feature
frame_width = features["frame/width"].int64_list.value
frame_height = features["frame/height"].int64_list.value
if frame_width[0] not in found_width:
found_width.append(frame_width[0])
if frame_height[0] not in found_height:
found_height.append(frame_height[0])
if frame_width[0] != expected_frame_width:
print("The frame_id is: {}\n".format(frame_id))
print("The frame_width is:{}\n".format(frame_width))
print("The frame_height:{}\n".format(frame_height))
elif frame_height[0] != expected_frame_height:
print(found_width)
print(found_height)
I expect the resizing from (640x480) to the needed (960x544) to be taken care of by the enable_auto_resize: true
in the augmentation_config.preprocessing
block.
So my guess is my issue is related to the fact that my source dataset has 5 classes (the only one I care about is vehicle, so I only map ‘vehicle’ to ‘car’ in target_class_mapping
, but TrafficCamNet was trained on 4 classes. Are there best practices for dealing with unused classes from the source dataset? I have also tried evaluation with a subset of my training data that consists of only “vehicle” detections with the same issue.
Last thing: it seems that you usually run evaluate
after train
, but I am running evaluate
first in order to establish a performance baseline before fine-tuning.
Any advice appreciated. Thank you.
