• Hardware (T4)
• Network Type (Dino/Yolov3)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
When i run the below tensorboard command while my Dino training using TAO launcher CLI is going on i got some errors
(launcher) (venvs) rishi@rishi-workspace:~/tao_training/training_home/Dino/dino$ tensorboard --logdir results/ --host 0.0.0.0 --port 8080
TensorFlow installation not found - running with reduced feature set.
NOTE: Using experimental fast data loading logic. To disable, pass
"--load_fast=false" and report issues on GitHub. More details:
https://github.com/tensorflow/tensorboard/issues/4784
TensorBoard 2.14.0 at http://0.0.0.0:8080/ (Press CTRL+C to quit)
E0523 06:33:17.119219 139673577961216 _internal.py:97] Error on request:
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/werkzeug/serving.py", line 363, in run_wsgi
execute(self.server.app)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/werkzeug/serving.py", line 324, in execute
application_iter = app(environ, start_response)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/application.py", line 528, in __call__
return self._app(environ, start_response)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/application.py", line 569, in wrapper
return wsgi_app(environ, start_response)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/security_validator.py", line 91, in __call__
return self._application(environ, start_response_proxy)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/path_prefix.py", line 68, in __call__
return self._application(environ, start_response)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/experiment_id.py", line 73, in __call__
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/empty_path_redirect.py", line 43, in __call__
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/client_feature_flags.py", line 55, in __call__
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/auth_context_middleware.py", line 38, in __call__
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/backend/application.py", line 551, in _route_request
return self.exact_routes[clean_path](environ, start_response)
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/werkzeug/wrappers/request.py", line 190, in application
resp = f(*args[:-2] + (request,))
File "/home/rishi/miniconda3/envs/launcher/lib/python3.8/site-packages/tensorboard/plugins/hparams/hparams_plugin.py", line 122, in get_experiment_route
json_format.MessageToJson(
TypeError: MessageToJson() got an unexpected keyword argument 'including_default_value_fields'
In the browser also i see the message "Failed to fetch " and disappear
Can you advice why this is occuring and how to monitor the training of Dino with tensorboard
