OSError Traceback (most recent call last)
~\AppData\Local\conda\conda\envs\tensorflow-gpu\lib\site-packages\tensorflow\python\platform\self_check.py in preload_check()
74 try:
—> 75 ctypes.WinDLL(build_info.cudart_dll_name)
76 except OSError:
~\AppData\Local\conda\conda\envs\tensorflow-gpu\lib\ctypes_init_.py in init(self, name, mode, handle, use_errno, use_last_error)
350 if handle is None:
→ 351 self._handle = _dlopen(self._name, mode)
352 else:
OSError: [WinError 126] 找不到指定的模組。
During handling of the above exception, another exception occurred:
ImportError Traceback (most recent call last)
in ()
----> 1 import tensorflow as tf
2 import time
~\AppData\Local\conda\conda\envs\tensorflow-gpu\lib\site-packages\tensorflow_init_.py in ()
20
21 # pylint: disable=g-bad-import-order
—> 22 from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
23 from . import app
24 from . import bitwise
~\AppData\Local\conda\conda\envs\tensorflow-gpu\lib\site-packages\tensorflow\python_init_.py in ()
47 import numpy as np
48
—> 49 from tensorflow.python import pywrap_tensorflow
50
51 # Protocol buffers
~\AppData\Local\conda\conda\envs\tensorflow-gpu\lib\site-packages\tensorflow\python\pywrap_tensorflow.py in ()
28 # Perform pre-load sanity checks in order to produce a more actionable error
29 # than we get from an error during SWIG import.
—> 30 self_check.preload_check()
31
32 # pylint: disable=wildcard-import,g-import-not-at-top,unused-import,line-too-long
80 "environment variable. Download and install CUDA %s from "
81 “this URL: https://developer.nvidia.com/cuda-toolkit”
—> 82 % (build_info.cudart_dll_name, build_info.cuda_version_number))
83
84 if hasattr(build_info, “cudnn_dll_name”) and hasattr(
ImportError: Could not find ‘cudart64_90.dll’. TensorFlow requires that this DLL be installed in a directory that is named in your %PATH% environment variable. Download and install CUDA 9.0 from this URL: https://developer.nvidia.com/cuda-toolkit
