Information:
Radeon 2700x
RTX2080
Windows10
python3.6
CUDA10.0
cuDNN 7.3.1
I want to use tensorflow-gpu but when I try to import tensorflow, the error occur.
And I also tried to install CUDA9.2, it was same.
Under CUDA9.1 version can’t install because it doen’t support my graphic card driver.
error log is this:
Python 3.6.7 |Anaconda, Inc.| (default, Oct 28 2018, 19:44:12) [MSC v.1915 64 bit (AMD64)] on win32
Type “help”, “copyright”, “credits” or “license” for more information.
import tensorflow as tf
File “C:\Anaconda3\envs\deep\lib\site-packages\tensorflow\python\pywrap_tensorflow.py”, line 58, in
from tensorflow.python.pywrap_tensorflow_internal import *
File “C:\Anaconda3\envs\deep\lib\site-packages\tensorflow\python\pywrap_tensorflow_internal.py”, line 28, in
_pywrap_tensorflow_internal = swig_import_helper()
File “C:\Anaconda3\envs\deep\lib\site-packages\tensorflow\python\pywrap_tensorflow_internal.py”, line 24, in swig_import_helper
_mod = imp.load_module(’_pywrap_tensorflow_internal’, fp, pathname, description)
File “C:\Anaconda3\envs\deep\lib\imp.py”, line 243, in load_module
return load_dynamic(name, filename, file)
File “C:\Anaconda3\envs\deep\lib\imp.py”, line 343, in load_dynamic
return _load(spec)
ImportError: DLL load failed: can not find module.
During handling of the above exception, another exception occurred:
File “”, line 1, in
File “C:\Anaconda3\envs\deep\lib\site-packages\tensorflow_init_.py”, line 24, in
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File “C:\Anaconda3\envs\deep\lib\site-packages\tensorflow\python_init_.py”, line 49, in
File “C:\Anaconda3\envs\deep\lib\site-packages\tensorflow\python\pywrap_tensorflow.py”, line 74, in
raise ImportError(msg)
ImportError: Traceback (most recent call last):
return _load(spec)
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/errors
for some common reasons and solutions. Include the entire stack trace
above this error message when asking for help.
How can I use tensorflow-gpu?
