D:\anaconda\python.exe D:/keras-yolo3/train.py
D:\anaconda\lib\site-packages\h5py\__init__.py:36: FutureWarning: Conversion of the second argument of issubdtype from `float` to `np.floating` is deprecated. In future, it will be treated as `np.float64 == np.dtype(float).type`.
from ._conv import register_converters as _register_converters
Using TensorFlow backend.
2018-10-16 16:40:21.107744: I tensorflow/core/platform/cpu_feature_guard.cc:141] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2
2018-10-16 16:40:21.443178: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1411] Found device 0 with properties:
name: GeForce RTX 2080 major: 7 minor: 5 memoryClockRate(GHz): 1.8
pciBusID: 0000:01:00.0
totalMemory: 8.00GiB freeMemory: 6.53GiB
2018-10-16 16:40:21.443542: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1490] Adding visible gpu devices: 0
2018-10-16 16:40:22.278990: I tensorflow/core/common_runtime/gpu/gpu_device.cc:971] Device interconnect StreamExecutor with strength 1 edge matrix:
2018-10-16 16:40:22.279198: I tensorflow/core/common_runtime/gpu/gpu_device.cc:977] 0
2018-10-16 16:40:22.279321: I tensorflow/core/common_runtime/gpu/gpu_device.cc:990] 0: N
2018-10-16 16:40:22.279544: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1103] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 6270 MB memory) -> physical GPU (device: 0, name: GeForce RTX 2080, pci bus id: 0000:01:00.0, compute capability: 7.5)
Create YOLOv3 model with 9 anchors and 13 classes.
D:\anaconda\lib\site-packages\keras\engine\saving.py:1140: UserWarning: Skipping loading of weights for layer conv2d_59 due to mismatch in shape ((1, 1, 1024, 54) vs (255, 1024, 1, 1)).
weight_values[i].shape))
D:\anaconda\lib\site-packages\keras\engine\saving.py:1140: UserWarning: Skipping loading of weights for layer conv2d_59 due to mismatch in shape ((54,) vs (255,)).
D:\anaconda\lib\site-packages\keras\engine\saving.py:1140: UserWarning: Skipping loading of weights for layer conv2d_67 due to mismatch in shape ((1, 1, 512, 54) vs (255, 512, 1, 1)).
D:\anaconda\lib\site-packages\keras\engine\saving.py:1140: UserWarning: Skipping loading of weights for layer conv2d_67 due to mismatch in shape ((54,) vs (255,)).
D:\anaconda\lib\site-packages\keras\engine\saving.py:1140: UserWarning: Skipping loading of weights for layer conv2d_75 due to mismatch in shape ((1, 1, 256, 54) vs (255, 256, 1, 1)).
D:\anaconda\lib\site-packages\keras\engine\saving.py:1140: UserWarning: Skipping loading of weights for layer conv2d_75 due to mismatch in shape ((54,) vs (255,)).
Load weights model_data/yolo_weights.h5.
Freeze the first 249 layers of total 252 layers.
Train on 468 samples, val on 51 samples, with batch size 2.
Epoch 1/800
2018-10-16 16:40:35.133313: E tensorflow/stream_executor/cuda/cuda_blas.cc:652] failed to run cuBLAS routine cublasSgemm_v2: CUBLAS_STATUS_EXECUTION_FAILED
File "D:/keras-yolo3/train.py", line 217, in <module>
_main()
File "D:/keras-yolo3/train.py", line 84, in _main
epochs=800
File "D:\anaconda\lib\site-packages\keras\legacy\interfaces.py", line 91, in wrapper
return func(*args, **kwargs)
File "D:\anaconda\lib\site-packages\keras\engine\training.py", line 1418, in fit_generator
initial_epoch=initial_epoch)
File "D:\anaconda\lib\site-packages\keras\engine\training_generator.py", line 217, in fit_generator
class_weight=class_weight)
File "D:\anaconda\lib\site-packages\keras\engine\training.py", line 1217, in train_on_batch
outputs = self.train_function(ins)
File "D:\anaconda\lib\site-packages\keras\backend\tensorflow_backend.py", line 2715, in __call__
return self._call(inputs)
File "D:\anaconda\lib\site-packages\keras\backend\tensorflow_backend.py", line 2675, in _call
fetched = self._callable_fn(*array_vals)
File "D:\anaconda\lib\site-packages\tensorflow\python\client\session.py", line 1399, in __call__
run_metadata_ptr)
File "D:\anaconda\lib\site-packages\tensorflow\python\framework\errors_impl.py", line 526, in __exit__
c_api.TF_GetCode(self.status.status))
tensorflow.python.framework.errors_impl.InternalError: Blas SGEMM launch failed : m=86528, n=32, k=64
[[{{node conv2d_3/convolution}} = Conv2D[T=DT_FLOAT, _class=["loc:@batch_normalization_3/cond/FusedBatchNorm/Switch"], data_format="NHWC", dilations=[1, 1, 1, 1], padding="SAME", strides=[1, 1, 1, 1], use_cudnn_on_gpu=true, _device="/job:localhost/replica:0/task:0/device:GPU:0"](leaky_re_lu_2/LeakyRelu, conv2d_3/kernel/read)]]
[[{{node yolo_loss/while_1/strided_slice/stack/_2895}} = _HostRecv[client_terminated=false, recv_device="/job:localhost/replica:0/task:0/device:CPU:0", send_device="/job:localhost/replica:0/task:0/device:GPU:0", send_device_incarnation=1, tensor_name="edge_3114_yolo_loss/while_1/strided_slice/stack", tensor_type=DT_INT32, _device="/job:localhost/replica:0/task:0/device:CPU:0"](^_cloopyolo_loss/while_1/strided_slice_1/stack_2/_2805)]]
