I tried couple of time (no change in bazel version- 0.21.0), last time with re-booting the tegra-B, this time the installation proceeded further, but got a different error.
Error message
[code]
/tensorflow$ bazel build --config=opt --config=cuda --config=nonccl //tensorflow/tools/pip_package:build_pip_package
Starting local Bazel server and connecting to it…
WARNING: The following configs were expanded more than once: [cuda]. For repeatable flags, repeats are counted twice and may lead to unexpected behavior.
INFO: Invocation ID: d95a8b95-71c7-40aa-beb5-a067357e568e
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/python/BUILD:2986:1: in py_library rule //tensorflow/python:standard_ops: target ‘//tensorflow/python:standard_ops’ depends on deprecated target ‘//tensorflow/python/ops/distributions:distributions’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.distributions will not receive new features, and will be removed by early 2019. You should update all usage of tf.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/gan/BUILD:136:1: in py_library rule //tensorflow/contrib/gan:losses_impl: target ‘//tensorflow/contrib/gan:losses_impl’ depends on deprecated target ‘//tensorflow/python/ops/distributions:distributions’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.distributions will not receive new features, and will be removed by early 2019. You should update all usage of tf.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/metrics/BUILD:16:1: in py_library rule //tensorflow/contrib/metrics:metrics_py: target ‘//tensorflow/contrib/metrics:metrics_py’ depends on deprecated target ‘//tensorflow/python/ops/distributions:distributions’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.distributions will not receive new features, and will be removed by early 2019. You should update all usage of tf.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/python/BUILD:77:1: in py_library rule //tensorflow/python:no_contrib: target ‘//tensorflow/python:no_contrib’ depends on deprecated target ‘//tensorflow/python/ops/distributions:distributions’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.distributions will not receive new features, and will be removed by early 2019. You should update all usage of tf.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/learn/BUILD:17:1: in py_library rule //tensorflow/contrib/learn:learn: target ‘//tensorflow/contrib/learn:learn’ depends on deprecated target ‘//tensorflow/contrib/session_bundle:exporter’: No longer supported. Switch to SavedModel immediately.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/learn/BUILD:17:1: in py_library rule //tensorflow/contrib/learn:learn: target ‘//tensorflow/contrib/learn:learn’ depends on deprecated target ‘//tensorflow/contrib/session_bundle:gc’: No longer supported. Switch to SavedModel immediately.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/seq2seq/BUILD:23:1: in py_library rule //tensorflow/contrib/seq2seq:seq2seq_py: target ‘//tensorflow/contrib/seq2seq:seq2seq_py’ depends on deprecated target ‘//tensorflow/contrib/distributions:distributions_py’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.contrib.distributions are unmaintained, unsupported, and will be removed by late 2018. You should update all usage of tf.contrib.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/seq2seq/BUILD:23:1: in py_library rule //tensorflow/contrib/seq2seq:seq2seq_py: target ‘//tensorflow/contrib/seq2seq:seq2seq_py’ depends on deprecated target ‘//tensorflow/python/ops/distributions:distributions’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.distributions will not receive new features, and will be removed by early 2019. You should update all usage of tf.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/timeseries/python/timeseries/state_space_models/BUILD:233:1: in py_library rule //tensorflow/contrib/timeseries/python/timeseries/state_space_models:filtering_postprocessor: target ‘//tensorflow/contrib/timeseries/python/timeseries/state_space_models:filtering_postprocessor’ depends on deprecated target ‘//tensorflow/contrib/distributions:distributions_py’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.contrib.distributions are unmaintained, unsupported, and will be removed by late 2018. You should update all usage of tf.contrib.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/timeseries/python/timeseries/state_space_models/BUILD:76:1: in py_library rule //tensorflow/contrib/timeseries/python/timeseries/state_space_models:kalman_filter: target ‘//tensorflow/contrib/timeseries/python/timeseries/state_space_models:kalman_filter’ depends on deprecated target ‘//tensorflow/contrib/distributions:distributions_py’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.contrib.distributions are unmaintained, unsupported, and will be removed by late 2018. You should update all usage of tf.contrib.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/timeseries/python/timeseries/BUILD:356:1: in py_library rule //tensorflow/contrib/timeseries/python/timeseries:ar_model: target ‘//tensorflow/contrib/timeseries/python/timeseries:ar_model’ depends on deprecated target ‘//tensorflow/contrib/distributions:distributions_py’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.contrib.distributions are unmaintained, unsupported, and will be removed by late 2018. You should update all usage of tf.contrib.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/bayesflow/BUILD:17:1: in py_library rule //tensorflow/contrib/bayesflow:bayesflow_py: target ‘//tensorflow/contrib/bayesflow:bayesflow_py’ depends on deprecated target ‘//tensorflow/contrib/distributions:distributions_py’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.contrib.distributions are unmaintained, unsupported, and will be removed by late 2018. You should update all usage of tf.contrib.distributions to tfp.distributions.
WARNING: /home/nvidia/bazel-0.21.0-dist/tensorflow/tensorflow/contrib/BUILD:13:1: in py_library rule //tensorflow/contrib:contrib_py: target ‘//tensorflow/contrib:contrib_py’ depends on deprecated target ‘//tensorflow/contrib/distributions:distributions_py’: TensorFlow Distributions has migrated to TensorFlow Probability (GitHub - tensorflow/probability: Probabilistic reasoning and statistical analysis in TensorFlow). Deprecated copies remaining in tf.contrib.distributions are unmaintained, unsupported, and will be removed by late 2018. You should update all usage of tf.contrib.distributions to tfp.distributions.
INFO: Analysed target //tensorflow/tools/pip_package:build_pip_package (347 packages loaded, 17756 targets configured).
INFO: Found 1 target…
INFO: From Compiling tensorflow/python/framework/fast_tensor_util.cpp [for host]:
In file included from bazel-out/host/genfiles/external/local_config_python/numpy_include/numpy/ndarraytypes.h:1822:0,
from bazel-out/host/genfiles/external/local_config_python/numpy_include/numpy/ndarrayobject.h:12,
from bazel-out/host/genfiles/external/local_config_python/numpy_include/numpy/arrayobject.h:4,
from bazel-out/host/genfiles/tensorflow/python/framework/fast_tensor_util.cpp:581:
bazel-out/host/genfiles/external/local_config_python/numpy_include/numpy/npy_1_7_deprecated_api.h:17:2: warning: #warning "Using deprecated NumPy API, disable it with " “#define NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION” [-Wcpp]
INFO: From Compiling external/icu/icu4c/source/common/uidna.cpp [for host]:
external/icu/icu4c/source/common/uidna.cpp: In function ‘int32_t internal_toUnicode(const UChar*, int32_t, UChar*, int32_t, int32_t, UStringPrepProfile*, UParseError*, UErrorCode*)‘:
external/icu/icu4c/source/common/uidna.cpp:515:85: warning: ‘int32_t uidna_toASCII_62(const UChar*, int32_t, UChar*, int32_t, int32_t, UParseError*, UErrorCode*)’ is deprecated [-Wdeprecated-declarations]
b3Len = uidna_toASCII(b2, b2Len, b3, b3Capacity, options, parseError, status);
In file included from external/icu/icu4c/source/common/unicode/platform.h:25:0,
from external/icu/icu4c/source/common/unicode/ptypes.h:52,
from external/icu/icu4c/source/common/unicode/umachine.h:46,
from external/icu/icu4c/source/common/unicode/utypes.h:38,
from external/icu/icu4c/source/common/uidna.cpp:19:
external/icu/icu4c/source/common/unicode/uidna.h:576:1: note: declared here
uidna_toASCII(const UChar* src, int32_t srcLength,
external/icu/icu4c/source/common/uidna.cpp:528:80: warning: ‘int32_t uidna_toASCII_62(const UChar*, int32_t, UChar*, int32_t, int32_t, UParseError*, UErrorCode*)’ is deprecated [-Wdeprecated-declarations]
b3Len = uidna_toASCII(b2,b2Len,b3,b3Len,options,parseError, status);
external/icu/icu4c/source/common/uidna.cpp: In function ‘int32_t uidna_compare_62(const UChar*, int32_t, const UChar*, int32_t, int32_t, UErrorCode*)’:
external/icu/icu4c/source/common/uidna.cpp:878:87: warning: ‘int32_t uidna_IDNToASCII_62(const UChar*, int32_t, UChar*, int32_t, int32_t, UParseError*, UErrorCode*)’ is deprecated [-Wdeprecated-declarations]
b1Len = uidna_IDNToASCII(s1, length1, b1, b1Capacity, options, &parseError, status);
external/icu/icu4c/source/common/uidna.cpp:670:1: note: declared here
uidna_IDNToASCII( const UChar src, int32_t srcLength,
external/icu/icu4c/source/common/uidna.cpp:889:83: warning: 'int32_t uidna_IDNToASCII_62(const UChar, int32_t, UChar*, int32_t, int32_t, UParseError*, UErrorCode*)’ is deprecated [-Wdeprecated-declarations]
b1Len = uidna_IDNToASCII(s1,length1,b1,b1Len, options, &parseError, status);
external/icu/icu4c/source/common/uidna.cpp:893:85: warning: 'int32_t uidna_IDNToASCII_62(const UChar, int32_t, UChar*, int32_t, int32_t, UParseError*, UErrorCode*)’ is deprecated [-Wdeprecated-declarations]
b2Len = uidna_IDNToASCII(s2,length2, b2,b2Capacity, options, &parseError, status);
external/icu/icu4c/source/common/uidna.cpp:904:86: warning: 'int32_t uidna_IDNToASCII_62(const UChar, int32_t, UChar*, int32_t, int32_t, UParseError*, UErrorCode*)’ is deprecated [-Wdeprecated-declarations]
b2Len = uidna_IDNToASCII(s2, length2, b2, b2Len, options, &parseError, status);
INFO: From Compiling external/icu/icu4c/source/common/static_unicode_sets.cpp [for host]:
external/icu/icu4c/source/common/static_unicode_sets.cpp: In function ‘UBool {anonymous}::cleanupNumberParseUniSets()’:
external/icu/icu4c/source/common/static_unicode_sets.cpp:121:56: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
reinterpret_cast<UnicodeSet>(gEmptyUnicodeSet)->~UnicodeSet();
external/icu/icu4c/source/common/static_unicode_sets.cpp: In function ‘void {anonymous}::initNumberParseUniSets(UErrorCode&)’:
external/icu/icu4c/source/common/static_unicode_sets.cpp:137:52: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
reinterpret_cast<UnicodeSet*>(gEmptyUnicodeSet)->freeze();
INFO: From Compiling external/icu/icu4c/source/common/rbbitblb.cpp [for host]:
external/icu/icu4c/source/common/rbbitblb.cpp: In member function ‘bool icu_62::RBBITableBuilder::findDuplCharClassFrom(icu_62::IntPair*)’:
external/icu/icu4c/source/common/rbbitblb.cpp:1097:14: warning: ‘table_dupl’ may be used uninitialized in this function [-Wmaybe-uninitialized]
if (table_base == table_dupl) {
external/icu/icu4c/source/common/rbbitblb.cpp:1097:14: warning: ‘table_base’ may be used uninitialized in this function [-Wmaybe-uninitialized]
INFO: From Compiling tensorflow/lite/string_util.cc [for host]:
tensorflow/lite/string_util.cc: In member function ‘int tflite::DynamicBuffer::WriteToBuffer(char**)’:
tensorflow/lite/string_util.cc:89:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (int i = 0; i < offset.size(); i++) {
INFO: From Compiling tensorflow/lite/c/c_api_internal.c [for host]:
In file included from tensorflow/lite/c/c_api_internal.c:16:0:
./tensorflow/lite/c/c_api_internal.h:60:34: warning: ‘struct TfLiteContext’ declared inside parameter list
TfLiteStatus (Refresh)(struct TfLiteContext context);
./tensorflow/lite/c/c_api_internal.h:60:34: warning: its scope is only this definition or declaration, which is probably not what you want
INFO: From Compiling tensorflow/lite/arena_planner.cc [for host]:
tensorflow/lite/arena_planner.cc: In member function ‘virtual TfLiteStatus tflite::ArenaPlanner::PlanAllocations()’:
tensorflow/lite/arena_planner.cc:133:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (int i = 0; i < graph_info_->num_nodes(); ++i) {
tensorflow/lite/arena_planner.cc:151:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
tensorflow/lite/arena_planner.cc: In member function ‘virtual TfLiteStatus tflite::ArenaPlanner::ExecuteAllocations(int, int)’:
tensorflow/lite/arena_planner.cc:191:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (int i = 0; i < graph_info_->num_tensors(); ++i) {
tensorflow/lite/arena_planner.cc: In member function ‘TfLiteStatus tflite::ArenaPlanner::CalculateAllocationOfInternalTensors(int)’:
tensorflow/lite/arena_planner.cc:282:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (node_index < graph_info_->num_nodes()) {
tensorflow/lite/arena_planner.cc: In member function ‘TfLiteStatus tflite::ArenaPlanner::CalculateDeallocationOfInternalTensors(int)’:
tensorflow/lite/arena_planner.cc:295:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
INFO: From Compiling tensorflow/lite/kernels/internal/mfcc.cc [for host]:
tensorflow/lite/kernels/internal/mfcc.cc: In member function ‘void tflite::internal::Mfcc::Compute(const std::vector&, std::vector) const’:
tensorflow/lite/kernels/internal/mfcc.cc:54:21: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (int i = 0; i < working.size(); ++i) {
INFO: From Compiling tensorflow/lite/kernels/internal/mfcc_mel_filterbank.cc [for host]:
tensorflow/lite/kernels/internal/mfcc_mel_filterbank.cc: In member function 'void tflite::internal::MfccMelFilterbank::Compute(const std::vector&, std::vector) const’:
tensorflow/lite/kernels/internal/mfcc_mel_filterbank.cc:179:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (input.size() <= end_index_) {
INFO: From Compiling external/kafka/src/rdbuf.c:
external/kafka/src/rdbuf.c: In function ‘rd_slice_init_full’:
external/kafka/src/rdbuf.c:741:13: warning: unused variable ‘r’ [-Wunused-variable]
int r = rd_slice_init(slice, rbuf, 0, rd_buf_len(rbuf));
external/kafka/src/rdbuf.c: In function ‘rd_buf_dump’:
external/kafka/src/rdbuf.c:1117:24: warning: unused variable ‘segcnt’ [-Wunused-variable]
size_t segcnt = 0;
INFO: From Compiling external/kafka/src/rdkafka_transport.c:
In file included from external/kafka/src/rdkafka_transport.c:36:0:
external/kafka/src/rdkafka_transport.c: In function ‘rd_kafka_transport_ssl_ctx_init’:
external/kafka/src/rdkafka_transport.c:830:47: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 9 has type ‘int’ [-Wformat=]
rd_kafka_dbg(rk, SECURITY, “OPENSSL”, "Using OpenSSL version %s "
external/kafka/src/rdkafka_int.h:396:53: note: in definition of macro ‘rd_kafka_dbg’
LOG_DEBUG,fac,VA_ARGS);
INFO: From Compiling external/kafka/src/tinycthread.c:
external/kafka/src/tinycthread.c: In function ‘rwlock_rdlock’:
external/kafka/src/tinycthread.c:1012:13: warning: unused variable ‘r’ [-Wunused-variable]
int r = pthread_rwlock_rdlock(rwl);
external/kafka/src/tinycthread.c: In function ‘rwlock_wrlock’:
external/kafka/src/tinycthread.c:1018:13: warning: unused variable ‘r’ [-Wunused-variable]
int r = pthread_rwlock_wrlock(rwl);
external/kafka/src/tinycthread.c: In function ‘rwlock_rdunlock’:
external/kafka/src/tinycthread.c:1024:13: warning: unused variable ‘r’ [-Wunused-variable]
int r = pthread_rwlock_unlock(rwl);
external/kafka/src/tinycthread.c: In function ‘rwlock_wrunlock’:
external/kafka/src/tinycthread.c:1030:13: warning: unused variable ‘r’ [-Wunused-variable]
INFO: From Compiling external/kafka/src/rdkafka_msgset_writer.c:
external/kafka/src/rdkafka_msgset_writer.c: In function ‘rd_kafka_msgset_writer_write_msg’:
external/kafka/src/rdkafka_msgset_writer.c:684:16: warning: variable ‘actual_written’ set but not used [-Wunused-but-set-variable]
size_t actual_written;
external/kafka/src/rdkafka_msgset_writer.c: In function ‘rd_kafka_msgset_writer_calc_crc_v2’:
external/kafka/src/rdkafka_msgset_writer.c:1066:13: warning: variable ‘r’ set but not used [-Wunused-but-set-variable]
int r;
INFO: From Compiling external/kafka/src/rdkafka_op.c:
external/kafka/src/rdkafka_op.c: In function ‘rd_kafka_op_destroy’:
external/kafka/src/rdkafka_op.c:325:35: warning: variable ‘res’ set but not used [-Wunused-but-set-variable]
rd_kafka_op_res_t res;
INFO: From Compiling external/kafka/src/rdkafka_admin.c:
external/kafka/src/rdkafka_admin.c: In function ‘rd_kafka_admin_result_ret_topics’:
external/kafka/src/rdkafka_admin.c:344:28: warning: unused variable ‘reqtype’ [-Wunused-variable]
rd_kafka_op_type_t reqtype =
external/kafka/src/rdkafka_admin.c: In function ‘rd_kafka_admin_result_ret_resources’:
external/kafka/src/rdkafka_admin.c:361:28: warning: unused variable ‘reqtype’ [-Wunused-variable]
INFO: From ProtoCompile tensorflow/contrib/boosted_trees/proto/learner.pb.cc:
bazel-out/aarch64-opt/genfiles/external/protobuf_archive/src: warning: directory does not exist.
INFO: From ProtoCompile tensorflow/contrib/tpu/proto/tpu_embedding_configuration.pb.cc [for host]:
bazel-out/host/genfiles/external/protobuf_archive/src: warning: directory does not exist.
INFO: From ProtoCompile tensorflow/contrib/tensor_forest/proto/fertile_stats.pb.cc:
INFO: From ProtoCompile tensorflow/core/debug/debugger_event_metadata.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/contrib/cloud/kernels/bigquery_table_partition.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/core/kernels/boosted_trees/boosted_trees.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/core/protobuf/master.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/core/protobuf/worker.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/core/protobuf/eager_service.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/core/profiler/profile.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/python/framework/cpp_shape_inference.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/core/debug/debug_service.pb.cc [for host]:
INFO: From ProtoCompile external/com_github_googleapis_googleapis/google/api/annotations.pb.cc:
INFO: From ProtoCompile tensorflow/core/protobuf/replay_log.pb.cc [for host]:
tensorflow/core/protobuf/replay_log.proto: warning: Import tensorflow/core/framework/graph.proto but not used.
tensorflow/core/protobuf/replay_log.proto: warning: Import tensorflow/core/protobuf/cluster.proto but not used.
INFO: From ProtoCompile tensorflow/lite/toco/toco_flags.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/lite/toco/types.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/lite/toco/model_flags.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/contrib/boosted_trees/proto/learner.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/contrib/tpu/proto/tpu_embedding_output_layout.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/tpu/proto/optimization_parameters.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/tpu/proto/tpu_embedding_configuration.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/decision_trees/proto/generic_tree_model_extensions.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/tensor_forest/proto/tensor_forest_params.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/decision_trees/proto/generic_tree_model.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/tpu/proto/optimization_parameters.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/contrib/tpu/proto/tpu_embedding_output_layout.pb.cc [for host]:
INFO: From ProtoCompile tensorflow/contrib/boosted_trees/proto/tree_config.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/boosted_trees/proto/split_info.pb.cc:
INFO: From ProtoCompile tensorflow/contrib/boosted_trees/proto/quantiles.pb.cc:
INFO: From Compiling external/protobuf_archive/python/google/protobuf/pyext/message.cc [for host]:
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘PyObject* google::protobuf::python::message_meta::New(PyTypeObject*, PyObject*, PyObject*)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:208:54: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
static char kwlist[] = {“name”, “bases”, “dict”, 0};
external/protobuf_archive/python/google/protobuf/pyext/message.cc:208:54: warning: ISO C++ forbids converting a string constant to 'char’ [-Wwrite-strings]
external/protobuf_archive/python/google/protobuf/pyext/message.cc: At global scope:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:406:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘bool google::protobuf::python::CheckAndGetDouble(PyObject*, double*)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:710:44: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
FormatTypeError(arg, “int, long, float”);
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘bool google::protobuf::python::CheckAndGetBool(PyObject*, bool*)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:728:43: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
FormatTypeError(arg, “int, long, bool”);
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘PyObject* google::protobuf::python::CheckString(PyObject*, const google::protobuf::FieldDescriptor*)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:764:44: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
FormatTypeError(arg, “bytes, unicode”);
external/protobuf_archive/python/google/protobuf/pyext/message.cc:779:33: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
FormatTypeError(arg, “bytes”);
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘int google::protobuf::python::cmessage::InitAttributes(google::protobuf::python::CMessage*, PyObject*, PyObject*)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:1193:65: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
function_return.get(), “MergeFrom”, “O”, map_value));
external/protobuf_archive/python/google/protobuf/pyext/message.cc:1201:64: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
PyObject_CallMethod(map.get(), “update”, “O”, value));
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘PyObject* google::protobuf::python::cmessage::InternalSerializeToString(google::protobuf::python::CMessage*, PyObject*, PyObject*, bool)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:1812:48: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
static char* kwlist = { “deterministic”, 0 };
external/protobuf_archive/python/google/protobuf/pyext/message.cc:1836:67: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
PyObject_CallMethod(comma.get(), “join”, “O”, errors.get()));
external/protobuf_archive/python/google/protobuf/pyext/message.cc:2632:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In function ‘bool google::protobuf::python::InitProto2MessageModule(PyObject*)’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:2972:62: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
&RepeatedScalarContainer_Type)) == NULL) {
external/protobuf_archive/python/google/protobuf/pyext/message.cc:2977:65: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
&RepeatedCompositeContainer_Type)) == NULL) {
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In instantiation of ‘bool google::protobuf::python::CheckAndGetInteger(PyObject*, T*) [with T = int; PyObject = _object]’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:702:58: required from here
external/protobuf_archive/python/google/protobuf/pyext/message.cc:642:22: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
FormatTypeError(arg, “int, long”);
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In instantiation of ‘bool google::protobuf::python::CheckAndGetInteger(PyObject*, T*) [with T = long int; PyObject = _object]’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:703:58: required from here
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In instantiation of ‘bool google::protobuf::python::CheckAndGetInteger(PyObject*, T*) [with T = unsigned int; PyObject = _object]’:
external/protobuf_archive/python/google/protobuf/pyext/message.cc:704:60: required from here
external/protobuf_archive/python/google/protobuf/pyext/message.cc: In instantiation of 'bool google::protobuf::python::CheckAndGetInteger(PyObject*, T*) [with T = long unsigned int; PyObject = object]':
external/protobuf_archive/python/google/protobuf/pyext/message.cc:705:60: required from here
At global scope:
cc1plus: warning: unrecognized command line option ‘-Wno-writable-strings’
INFO: From Compiling external/protobuf_archive/python/google/protobuf/pyext/message_factory.cc [for host]:
external/protobuf_archive/python/google/protobuf/pyext/message_factory.cc: In function ‘PyObject* google::protobuf::python::message_factory::New(PyTypeObject*, PyObject*, PyObject*)’:
external/protobuf_archive/python/google/protobuf/pyext/message_factory.cc:78:37: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
static char* kwlist[] = {“pool”, 0};
external/protobuf_archive/python/google/protobuf/pyext/message_factory.cc: At global scope:
external/protobuf_archive/python/google/protobuf/pyext/message_factory.cc:227:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
INFO: From Compiling external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc [for host]:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc: In function ‘bool google::protobuf::python::GetFileDescriptorProto(PyObject*, google::protobuf::FileDescriptorProto*)’:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc:84:69: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
PyObject_CallMethod(py_descriptor, “SerializeToString”, NULL));
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc: In member function ‘virtual bool google::protobuf::python::PyDescriptorDatabase::FindFileByName(const string&, google::protobuf::FileDescriptorProto*)’:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc:114:78: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
py_database, “FindFileByName”, “s#”, filename.c_str(), filename.size()));
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc: In member function ‘virtual bool google::protobuf::python::PyDescriptorDatabase::FindFileContainingSymbol(const string&, google::protobuf::FileDescriptorProto*)’:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc:123:66: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
symbol_name.c_str(), symbol_name.size()));
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc: In member function ‘virtual bool google::protobuf::python::PyDescriptorDatabase::FindFileContainingExtension(const string&, int, google::protobuf::FileDescriptorProto*)’:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_database.cc:142:65: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
containing_type.size(), field_number));
At global scope:
INFO: From Compiling external/protobuf_archive/python/google/protobuf/pyext/descriptor_pool.cc [for host]:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_pool.cc: In function ‘PyObject* google::protobuf::python::cdescriptor_pool::New(PyTypeObject*, PyObject*, PyObject*)’:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_pool.cc:139:46: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
static char* kwlist = {“descriptor_db”, 0};
external/protobuf_archive/python/google/protobuf/pyext/descriptor_pool.cc: In function ‘PyObject* google::protobuf::python::cdescriptor_pool::Add(PyObject*, PyObject*)’:
external/protobuf_archive/python/google/protobuf/pyext/descriptor_pool.cc:564:75: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
PyObject_CallMethod(file_descriptor_proto, “SerializeToString”, NULL));
At global scope:
INFO: From Compiling external/protobuf_archive/python/google/protobuf/pyext/descriptor.cc [for host]:
external/protobuf_archive/python/google/protobuf/pyext/descriptor.cc:638:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
external/protobuf_archive/python/google/protobuf/pyext/descriptor.cc:946:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
external/protobuf_archive/python/google/protobuf/pyext/descriptor.cc:1106:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
external/protobuf_archive/python/google/protobuf/pyext/descriptor.cc:1221:1: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
