Description
I’m converting my tensorflow graph using the TrtGraphConverter, but on one computer the code crashes looking for libnvinfer.so.6, when libnvinfer.so.7 is installed.
Environment
TensorRT Version: 7
GPU Type: GeForce GTX 1070
Nvidia Driver Version: 450.36.06
CUDA Version: 10.1?
CUDNN Version: 7?
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.7.6
TensorFlow Version (if applicable): 2.3.0
Note that the above values may be untrue, it seems that the cuda and cudnn versions that get loaded are different than the ones I’m expecting (see traceback). It looks like tensorflow/cuda will look through /usr/lib/x86_64-linux-gnu to find the files, this is different from what I understand from the cuda/cudnn installation guide. This is possibly because I installed CUDA via debian/conda or some other method a long time ago.
Inside /usr/lib/x86_64-linux-gnu the file libnvinfer.so.7 does exist though.
Steps To Reproduce
from tensorflow.python.compiler.tensorrt import trt_convert as trt
converter = trt.TrtGraphConverter(frozen_graph)
Traceback
2020-09-14 11:31:00.701931: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2020-09-14 11:31:01.612659: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcuda.so.1
2020-09-14 11:31:01.639098: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.639412: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1716] Found device 0 with properties:
pciBusID: 0000:01:00.0 name: GeForce GTX 1070 computeCapability: 6.1
coreClock: 1.7845GHz coreCount: 15 deviceMemorySize: 7.93GiB deviceMemoryBandwidth: 238.66GiB/s
2020-09-14 11:31:01.639441: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2020-09-14 11:31:01.640565: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcublas.so.10
2020-09-14 11:31:01.641387: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcufft.so.10
2020-09-14 11:31:01.641579: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcurand.so.10
2020-09-14 11:31:01.642666: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusolver.so.10
2020-09-14 11:31:01.643493: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusparse.so.10
2020-09-14 11:31:01.645915: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudnn.so.7
2020-09-14 11:31:01.646065: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.646658: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.647052: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1858] Adding visible gpu devices: 0
2020-09-14 11:31:01.647323: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN)to use the following CPU instructions in performance-critical operations: AVX2 FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2020-09-14 11:31:01.652371: I tensorflow/core/platform/profile_utils/cpu_utils.cc:104] CPU Frequency: 3499910000 Hz
2020-09-14 11:31:01.652529: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x55bad0a2a510 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2020-09-14 11:31:01.652542: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2020-09-14 11:31:01.707940: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.708354: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x55bad0aae490 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2020-09-14 11:31:01.708369: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): GeForce GTX 1070, Compute Capability 6.1
2020-09-14 11:31:01.708500: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.708757: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1716] Found device 0 with properties:
2020-09-14 11:31:01.708777: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2020-09-14 11:31:01.708796: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcublas.so.10
2020-09-14 11:31:01.708808: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcufft.so.10
2020-09-14 11:31:01.708824: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcurand.so.10
2020-09-14 11:31:01.708835: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusolver.so.10
2020-09-14 11:31:01.708868: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcusparse.so.10
2020-09-14 11:31:01.708892: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudnn.so.7
2020-09-14 11:31:01.708931: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.709197: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:01.709440: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1858] Adding visible gpu devices: 0
2020-09-14 11:31:01.709474: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.1
2020-09-14 11:31:02.019795: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1257] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-14 11:31:02.019825: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1263] 0
2020-09-14 11:31:02.019830: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1276] 0: N
2020-09-14 11:31:02.020004: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:02.020327: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:982] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 11:31:02.020625: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1402] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 6460 MB memory) → physical GPU (device: 0, name: GeForce GTX 1070, pci bus id: 0000:01:00.0, compute capability: 6.1)
2020-09-14 11:31:02.022451: W tensorflow/stream_executor/platform/default/dso_loader.cc:59] Could not load dynamic library ‘libnvinfer.so.6’; dlerror: libnvinfer.so.6: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda/lib64:/usr/lib/x86_64-linux-gnu
2020-09-14 11:31:02.022464: F tensorflow/compiler/tf2tensorrt/stub/nvinfer_stub.cc:49] getInferLibVersion symbol not found.
Aborted (core dumped)
