Description:
When I test my ONNX model on TensorRT 7.1.3.4, it cased segmentation fault error.
This ONNX model was passed on TensorRT 6.0.1.5 / 7.0.0.11 and only Failed on the newest 7.1.3.4.
Log:
$ ./trtexec.exe --onnx=/d/onnx_test/simple_unsqueeze_opset11.onnx --explicitBatch --verbose
&&&& RUNNING TensorRT.trtexec # D:\nvidia\TensorRT-7.1.3.4.Windows10.x86_64.cuda-11.0.cudnn8.0\TensorRT-7.1.3.4\ bin\trtexec.exe --onnx=D:/onnx_test/simple_unsqueeze_opset11.onnx --explicitBatch --verbose
[07/27/2020-15:19:24] [I] === Model Options ===
[07/27/2020-15:19:24] [I] Format: ONNX
[07/27/2020-15:19:24] [I] Model: D:/onnx_test/simple_unsqueeze_opset11.onnx
[07/27/2020-15:19:24] [I] Output:
[07/27/2020-15:19:24] [I] === Build Options ===
[07/27/2020-15:19:24] [I] Max batch: explicit
[07/27/2020-15:19:24] [I] Workspace: 16 MB
[07/27/2020-15:19:24] [I] minTiming: 1
[07/27/2020-15:19:24] [I] avgTiming: 8
[07/27/2020-15:19:24] [I] Precision: FP32
[07/27/2020-15:19:24] [I] Calibration:
[07/27/2020-15:19:24] [I] Safe mode: Disabled
[07/27/2020-15:19:24] [I] Save engine:
[07/27/2020-15:19:24] [I] Load engine:
[07/27/2020-15:19:24] [I] Builder Cache: Enabled
[07/27/2020-15:19:24] [I] NVTX verbosity: 0
[07/27/2020-15:19:24] [I] Inputs format: fp32:CHW
[07/27/2020-15:19:24] [I] Outputs format: fp32:CHW
[07/27/2020-15:19:24] [I] Input build shapes: model
[07/27/2020-15:19:24] [I] Input calibration shapes: model
[07/27/2020-15:19:24] [I] === System Options ===
[07/27/2020-15:19:24] [I] Device: 0
[07/27/2020-15:19:24] [I] DLACore:
[07/27/2020-15:19:24] [I] Plugins:
[07/27/2020-15:19:24] [I] === Inference Options ===
[07/27/2020-15:19:24] [I] Batch: Explicit
[07/27/2020-15:19:24] [I] Input inference shapes: model
[07/27/2020-15:19:24] [I] Iterations: 10
[07/27/2020-15:19:24] [I] Duration: 3s (+ 200ms warm up)
[07/27/2020-15:19:24] [I] Sleep time: 0ms
[07/27/2020-15:19:24] [I] Streams: 1
[07/27/2020-15:19:24] [I] ExposeDMA: Disabled
[07/27/2020-15:19:24] [I] Spin-wait: Disabled
[07/27/2020-15:19:24] [I] Multithreading: Disabled
[07/27/2020-15:19:24] [I] CUDA Graph: Disabled
[07/27/2020-15:19:24] [I] Skip inference: Disabled
[07/27/2020-15:19:24] [I] Inputs:
[07/27/2020-15:19:24] [I] === Reporting Options ===
[07/27/2020-15:19:24] [I] Verbose: Enabled
[07/27/2020-15:19:24] [I] Averages: 10 inferences
[07/27/2020-15:19:24] [I] Percentile: 99
[07/27/2020-15:19:24] [I] Dump output: Disabled
[07/27/2020-15:19:24] [I] Profile: Disabled
[07/27/2020-15:19:24] [I] Export timing to JSON file:
[07/27/2020-15:19:24] [I] Export output to JSON file:
[07/27/2020-15:19:24] [I] Export profile to JSON file:
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::GridAnchor_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::NMS_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::Reorg_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::Region_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::Clip_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::LReLU_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::PriorBox_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::Normalize_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::RPROI_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::BatchedNMS_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::FlattenConcat_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::CropAndResize
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::DetectionLayer_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::Proposal
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::ProposalLayer_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::PyramidROIAlign_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::ResizeNearest_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::Split
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::SpecialSlice_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ::InstanceNormalization_TRT
Input filename: D:/onnx_test/simple_unsqueeze_opset11.onnx
ONNX IR version: 0.0.6
Opset version: 11
Producer name: pytorch
Producer version: 1.5
Domain:
Model version: 0
Doc string:
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::GridAnchor_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::NMS_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Reorg_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Region_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Clip_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::LReLU_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::PriorBox_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Normalize_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::RPROI_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::BatchedNMS_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::FlattenConcat_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::CropAndResize
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::DetectionLayer_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Proposal
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::ProposalLayer_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::PyramidROIAlign_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::ResizeNearest_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::Split
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::SpecialSlice_TRT
[07/27/2020-15:19:25] [V] [TRT] Plugin creator registration succeeded - ONNXTRT_NAMESPACE::InstanceNormalization _TRT
[07/27/2020-15:19:25] [V] [TRT] ModelImporter.cpp:203: Adding network input: 0 with dtype: float32, dimensions: (3, 300, 400)
[07/27/2020-15:19:25] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 0 for ONNX tensor: 0
[07/27/2020-15:19:25] [V] [TRT] ModelImporter.cpp:107: Parsing node: Unsqueeze_0 [Unsqueeze]
[07/27/2020-15:19:25] [V] [TRT] ModelImporter.cpp:123: Searching for input: 0
[07/27/2020-15:19:25] [V] [TRT] ModelImporter.cpp:129: Unsqueeze_0 [Unsqueeze] inputs: [0 -> (3, 300, 400)],
[07/27/2020-15:19:25] [V] [TRT] onnx2trt_utils.cpp:1411: Original shape: (3, 300, 400), unsqueezing to: (1, 3, 3 00, 400)
[07/27/2020-15:19:25] [V] [TRT] ImporterContext.hpp:122: Registering layer: Unsqueeze_0 for ONNX node: Unsqueeze _0
[07/27/2020-15:19:25] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 1_1 for ONNX tensor: 1
[07/27/2020-15:19:25] [V] [TRT] ModelImporter.cpp:180: Unsqueeze_0 [Unsqueeze] outputs: [1 -> (1, 3, 300, 400)],
[07/27/2020-15:19:25] [V] [TRT] ModelImporter.cpp:494: Marking 1_1 as output: 1
----- Parsing of ONNX model D:/onnx_test/simple_unsqueeze_opset11.onnx is Done ----
Segmentation fault
ONNX model details
This is an very simple ONNX model. The Netron show model graph as follow:
It is created by code:
import torch
class TestModel(torch.nn.Module):
def __init__(self):
super(TestModel, self).__init__()
def forward(self, input):
output = input.unsqueeze(0)
return output
model = TestModel()
x = torch.ones((3, 300, 400))
torch.onnx.export(model, x, "simple_unsqueeze_opset11.onnx", opset_version=11)
simple_unsqueeze_opset11.zip (326 Bytes)
My dev enviroments:
- RTX2060
- Windows10
- Python 3.7 64bit
- Pytorch 1.5.1
- TensorRT-7.1.3.4.Windows10.x86_64.cuda-11.0.cudnn8.0
- TensorRT-7.0.0.11.Windows10.x86_64.cuda-10.2.cudnn7.6
- TensorRT-6.0.1.5.Windows10.x86_64.cuda-10.1.cudnn7.6
Thank you all for your patience.
