Description
After CUDA 11.3 is installed, following the local repo file installations instructions (at docs.nvidia com/deeplearning/tensorrt/install-guide/index.html) breaks with
$ sudo apt-get install python3-libnvinfer-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python3-libnvinfer-dev : Depends: python3-libnvinfer (= 8.0.0-1+cuda11.3) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Environment
TensorRT Version: 8.0.0
GPU Type: GeForce GTX 1080
Nvidia Driver Version: 465.19.01
CUDA Version: 11.3
CUDNN Version: release 11.3, V11.3.58 Build cuda_11.3.r11.3/compiler.29745058_0
Operating System + Version: Ubuntu18.04
Python Version (if applicable): 3.8 or 3.6
Steps To Reproduce
sudo dpkg -i nv-tensorrt-repo-ubuntu1804-cuda11.3-trt8.0.0.3-ea-20210423_1-1_amd64.deb
sudo apt-key add /var/nv-tensorrt-repo-ubuntu1804-cuda11.3-trt8.0.0.3-ea-20210423/7fa2af80.pub
sudo apt-get update
sudo apt-get install tensorrt
Testing further
python3-libnvinfer : Depends: python3 (< 3.7) but 3.8.2-0ubuntu2 is to be installed
This reproduces for both python3.8 and python3.6
$ apt list python3
Listing... Done
python3/focal,focal,now 3.8.2-0ubuntu2 amd64 [installed]
