please refer to this faq for How to connect a USB camera in DeepStream. you can use gst-launch debug first. then port the pipeline to Python code.
fanzh
5
Related topics
| Deepstream_test_1_usb with CSI camera on jetson orin nano | 8 | 896 | May 29, 2024 | |
| Deepstream-test3 with USB camera | 1 | 509 | July 25, 2022 | |
| Which Deepstream 7.1 Docker Imgae to use for Jetson Orin Nano | 3 | 220 | January 6, 2026 | |
| Deepstream example doesn't work! | 12 | 1730 | February 7, 2023 | |
| Deploy Deepstream 7.0 with USB Camera | 1 | 154 | September 18, 2024 | |
| ERROR from src_elem: Internal data stream error while trying to connect USB camera to do detection | 2 | 141 | July 14, 2025 | |
| DeepStream stopped working after several seconds while using webcam | 6 | 984 | August 21, 2023 | |
| Problems with test 1 usb camera | 1 | 1118 | July 28, 2020 | |
| [Jetson TX2] help!RTSP camera and USB camera did not work in deepstream4.0 | 5 | 1211 | August 13, 2019 | |
| Deepstream 2.0 can not use USB camera | 3 | 805 | August 6, 2018 |
