Tensorrt C++ inference for custom onnx model gives random results
Environment
Jetson TX2
TensorRT 8.2.1-1+cuda10.2
I have a custom TensorFlow model that I’ve converted to ONNX format. The following Python code works correctly for inference:
import cv2
import onnxruntime as ort
import numpy as np
def prepare_image(image, size=(100, 100)):
  image = cv2.resize(image, size)
  image = image.astype(np.float32)
  image = image / 255.0
  image = image[np.newaxis, :, :, np.newaxis] # Shape: [1, 100, 100, 1]
  return image
def run_inference(model, image):
  input_name = model.get_inputs()[0].name
  output_name = model.get_outputs()[0].name
  results = model.run([output_name], {input_name: image})[0]
  return results
image_path = 'test/100.png'
model_path = 'model.onnx'
image = cv2.imread(image_path, cv2.IMREAD_GRAYSCALE)
model = ort.InferenceSession(model_path)
prepared_image = prepare_image(image)
inference_results = run_inference(model, prepared_image)
print("Inference Results:", inference_results)`
However, I need to do this in C++. I’ve been trying for several days, but I’m getting completely random inference results for different input data. I tried analyzing the sampleOnnxMnist example. I suspect my error is in the processInput function, which originally looked like this:
bool SampleOnnxMNIST::processInput(const samplesCommon::BufferManager &buffers)
    const int inputH = 28;
    const int inputW = 28;
    // Read a random digit file
    srand(unsigned(time(nullptr)));
    std::vector<uint8_t> fileData(inputH * inputW);
    mNumber = (rand() % 10);
    readPGMFile(locateFile(std::to_string(mNumber) + ".pgm", mParams.dataDirs), fileData.data(), inputH, inputW);
    float *hostDataBuffer = static_cast<float *>(buffers.getHostBuffer(mParams.inputTensorNames[0]));
    for (int i = 0; i < inputH * inputW; i++)
        hostDataBuffer[i] = float(fileData[i] / 255.0);
    return true;
My modified version:
    const std::string imagePath = "../data/99.png";
    const int inputH = 100;
    const int inputW = 100;
    Mat image = imread(imagePath, IMREAD_GRAYSCALE);
    Mat convertedImage;
    image.convertTo(convertedImage, CV_32F, 1.0 / 255.0);
    for (int row = 0; row < inputH; ++row)
        for (int col = 0; col < inputW; ++col)
            hostDataBuffer[row * inputW + col] = convertedImage.at<float>(row, col);
    return true;
Can someone suggest a fix or provide a relevant link? I’ve searched extensively online without finding a suitable solution.
Hi @temarco ,
Can you please share the onnx model with us?
Aakanksha
