TensorRT Engine
Hi, is there any tool/method I can check the parameters for tensorrt engine? like check the precision set during engine creation. Thanks.
Hi ,
We recommend you to check the supported features from the below link.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
Thanks for the prompt reply. I’m sorry that I might not clarify my question in a better way. My question is what if I have an engine where I forgot about the precision I have set during the engine creation (or any other parameters), is it possible for me to check back the precision that was set during the engine creation?
By default, TensorRT chooses FP32 as a precision if you don’t mention it externally.
I don’t think we have an API, but we can verify always in verbose logs.
Using trtexec verbose logs as well we can verify.
Thank you.
