Hello.
I’ve created a unet model and converted it to .trt format.
Now I’m trying to run it on the xavier TensorRT. The inference
starts fine, but i can’t get the visible result. Cuda just returns
me data that makes no sense. In the end I’m trying to visualize the mask and
I just got black image.
The input format for .trt: FP32:CHW
The output format for .trt: FP32:CHW
Inference code
#include
#include
#include
#include
#include
#include <opencv2/opencv.hpp>
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/types_c.h>
#include <cuda_runtime.h>
#include “./csrc/engine.h”
using namespace std;
using namespace cv;
#define N 1000
int main(int argc, char *argv) {
if (argc<3 || argc>4) {
cerr << “Usage: " << argv[0] << " engine.plan image.jpg [.png]” << endl;
return 1;
cout << "Loading engine..." << endl;
auto engine = retinanet::Engine(argv[1]);
cout << "Preparing data..." << endl;
auto image = imread(argv[2], IMREAD_COLOR);
auto inputSize = engine.getInputSize();
cv::resize(image, image, Size(inputSize[0], inputSize[1]));
cv::Mat pixels;
image.convertTo(pixels, CV_32FC3, 1.0 / 255, 0);
int channels = 3;
vector<float> img;
vector<float> data (channels * inputSize[0] * inputSize[1]);
if (pixels.isContinuous())
img.assign((float*)pixels.datastart, (float*)pixels.dataend);
else {
cerr << "Error reading image " << argv[2] << endl;
return -1;
vector<float> mean {0.485, 0.456, 0.406};
vector<float> std {0.229, 0.224, 0.225};
for (int c = 0; c < channels; c++) {
for (int j = 0, hw = inputSize[0] * inputSize[1]; j < hw; j++) {
data[c * hw + j] = (img[channels * j + 2 - c] - mean[c]) / std[c];
// Create device buffers
void *data_d, *mask_d;
auto num_det = engine.getMaxDetections();
cudaMalloc(&data_d, 3 * inputSize[0] * inputSize[1] * sizeof(float));
cudaMalloc(&mask_d, 1 * inputSize[0] * inputSize[1] * sizeof(float));
// Copy image to device
size_t dataSize = data.size() * sizeof(float);
cudaMemcpy(data_d, data.data(), dataSize, cudaMemcpyHostToDevice);
// Run inference n times
cout << "Running inference..." << endl;
const int count = 100;
auto start = chrono::steady_clock::now();
vector<void *> buffers = { data_d, mask_d };
// vector<void *> buffers = { data_d};
for (int i = 0; i < count; i++) {
engine.infer(buffers);
auto stop = chrono::steady_clock::now();
auto timing = chrono::duration_cast<chrono::duration<double>>(stop - start);
cout << "Took " << timing.count() / count << " seconds per inference." << endl;
// cudaFree(data_d);
// Get back the bounding boxes
unique_ptr<float[]> scores(new float[num_det]);
unique_ptr<float[]> boxes(new float[num_det * 4]);
unique_ptr<float[]> classes(new float[num_det]);
Mat m = Mat(inputSize[0], inputSize[1], CV_32F);
cudaMemcpy(m.data, mask_d, 1 * inputSize[0] * inputSize[1] * sizeof(float), cudaMemcpyDeviceToHost);
cudaFree(data_d);
cout << "Channels" << channels << endl;
cout << "inputSize[0]" << inputSize[0] << endl;
cout << "inputSize[1]" << inputSize[1] << endl;
cv::Mat bgr;
cvtColor(m, bgr, CV_GRAY2BGR);
// Write image
string out_file = argc == 4 ? string(argv[3]) : "detections.png";
cout << "Saving result to " << out_file << endl;
imwrite(out_file, bgr);
return 0;
How to get correct result from the cudaMemcpyDeviceToHost ?
Currently it returns me
And the image is black
TensorRT Version : 7
GPU Type : GeForce GTX 166…
Nvidia Driver Version : 440.64
CUDA Version : 10.2
CUDNN Version :
Operating System + Version : Ubuntu Xavier
Python Version (if applicable) : 3.6
TensorFlow Version (if applicable) :
PyTorch Version (if applicable) : 1.4
Baremetal or Container (if container which image + tag) :
Relevant Files
Link to the inference code.
The problem is in
