TensorRT make error
when I build “sample_FasterRCNN” based on TensorRT3.0.1 on TitanGPU
and error occurs:
TensorRT-3.0.1/lib/libnvinfer_plugin.so: undefined reference to `std::__throw_out_of_range_fmt(char const*, …)@GLIBCXX_3.4.20’
TensorRT-3.0.1/lib/libnvcaffe_parser.so: undefined reference to `__cxa_throw_bad_array_new_length@CXXABI_1.3.8’
collect2: error: ld returned 1 exit status
but TensorRT3.0.0 has no such error when build despite couldn’t be runned after build for not supported in Titan
with ver3.0.0
thanks for your help!
can anybody give some advice?
Probably related to your libc and compiler versions. Did you make sure you downloaded the correct one? 14 vs 16 ubuntu?
Thx! Error is really caused by incorrect version for ubuntu
this time, I have checked my cuda and cudnn version already
However, I face another error:
cudnnLayerUtils.cpp(288)-Cuda Error in smVersion: 35
in IBuilder* builder = createInferBuilder(gLogger);
Should I revise anything in makefile?
for avoiding error:
Hi
I have met this issue too.
This issue may cause by set wrong environment variable “CUDA_VISIBLE_DEVICES”.
There is 2 way to figure out:
  1. export CUDA_VISIBLE_DEVIDES=;make clean;make
  2. reboot the machine and make clean and make again.
