I get the following error when I try to run sample_mnist
ERROR: cudnnLayerUtils.cpp (288) - Cuda Error in smVersion: 35
terminate called after throwing an instance of 'nvinfer1::CudaError'
what(): std::exception
where, I have flashed L4T 28.1 from Jetpack 3.1 and CuDNN, Cuda, TensorRT, OpenCV 3.3 and Multimedia API from JetPack 3.2
yea @AastaLLL, the error statement specified some architectural mismatch
thats why, I tried to find where sm=35 is set in make files, but could not find this
and yes I built it on TX2 from /usr/src/tensorrt
however I cannot check again as per your suggestion, since I am on L4T 28.2 now and error was appearing on 28.1
Due to different driver version, you can’t install the libraries from JetPack3.2 but use the JetPack3.1 OS.
Please remember to use the OS and libraries from the same installer to avoid incompatibility.
