This seems like an installation issue. Please reflash your TX2 to latest jetpack and try again. I’m able to build trt samples from tx2 successfully.
[code]nvidia@tegra-ubuntu:/usr/src/tensorrt/samples$ sudo make -j4
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleCharRNN’
../Makefile.config:6: CUDA_INSTALL_DIR variable is not specified, using /usr/local/cuda-9.0 by default, use CUDA_INSTALL_DIR=<cuda_dire ctory> to change.
../Makefile.config:9: CUDNN_INSTALL_DIR variable is not specified, using by default, use CUDNN_INSTALL_DIR=<cudnn_directory> to change .
if [ ! -d ../../bin/dchobj ]; then mkdir -p ../../bin/dchobj; fi
g++ -MM -MF ../../bin/dchobj/sampleCharRNN.d -MP -MT ../../bin/dchobj/sampleCharRNN.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleCharRNN.cpp
Compiling: sampleCharRNN.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/sampleCharRNN.o sampleCharRNN.cpp
if [ ! -d ../../bin/chobj ]; then mkdir -p ../../bin/chobj; fi
g++ -MM -MF ../../bin/chobj/sampleCharRNN.d -MP -MT ../../bin/chobj/sampleCharRNN.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I “/usr/local/include” -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleCharRNN.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/sampleCharRNN.o sampleCharRNN.cpp
Linking: ../../bin/sample_char_rnn
g++ -o ../../bin/sample_char_rnn ../../bin/chobj/sampleCharRNN.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L “/usr/local/lib” -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -l nvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/sample_char_rnn_debug
g++ -o ../../bin/sample_char_rnn_debug ../../bin/dchobj/sampleCharRNN.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/li b64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-g roup -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Copy every EXTRA_FILE of this sample to bin dir
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleCharRNN’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleMNIST’
make[1]: Nothing to be done for ‘all’.
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleMNIST’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleMNISTAPI’
g++ -MM -MF ../../bin/dchobj/sampleMNISTAPI.d -MP -MT ../../bin/dchobj/sampleMNISTAPI.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include " -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleMNISTAPI.cp p
Compiling: sampleMNISTAPI.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/sampleMNISTAPI.o sampleMNISTAPI.cpp
g++ -MM -MF ../../bin/chobj/sampleMNISTAPI.d -MP -MT ../../bin/chobj/sampleMNISTAPI.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleMNISTAPI.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/sampleMNISTAPI.o sampleMNISTAPI.cpp
Linking: ../../bin/sample_mnist_api
g++ -o ../../bin/sample_mnist_api ../../bin/chobj/sampleMNISTAPI.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/sample_mnist_api_debug
g++ -o ../../bin/sample_mnist_api_debug ../../bin/dchobj/sampleMNISTAPI.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/ lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start -group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-grou p
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleMNISTAPI’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleGoogleNet’
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleGoogleNet’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/trtexec’
g++ -MM -MF ../../bin/dchobj/trtexec.d -MP -MT ../../bin/dchobj/trtexec.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/loca l/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT trtexec.cpp
Compiling: trtexec.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/trtexec.o trtexec.cpp
g++ -MM -MF ../../bin/chobj/trtexec.d -MP -MT ../../bin/chobj/trtexec.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/ include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT trtexec.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/trtexec.o trtexec.cpp
Linking: ../../bin/trtexec
g++ -o ../../bin/trtexec ../../bin/chobj/trtexec.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/li b" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvpa rsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/trtexec_debug
g++ -o ../../bin/trtexec_debug ../../bin/dchobj/trtexec.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/l ocal/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
cp -f giexec ../../bin/giexec;
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/trtexec’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleINT8’
g++ -MM -MF ../../bin/dchobj/sampleINT8.d -MP -MT ../../bin/dchobj/sampleINT8.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/us r/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleINT8.cpp
Compiling: sampleINT8.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/sampleINT8.o sampleINT8.cpp
g++ -MM -MF ../../bin/chobj/sampleINT8.d -MP -MT ../../bin/chobj/sampleINT8.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/ local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleINT8.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/sampleINT8.o sampleINT8.cpp
Linking: ../../bin/sample_int8
g++ -o ../../bin/sample_int8 ../../bin/chobj/sampleINT8.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/l ocal/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/sample_int8_debug
g++ -o ../../bin/sample_int8_debug ../../bin/dchobj/sampleINT8.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L “/usr/local/lib” -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -l nvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleINT8’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/getDigits’
cp download-digits-model.py ../../bin/download-digits-model.py
chmod u+x ../../bin/download-digits-model.py
chmod u+w ../../bin/download-digits-model.py
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/getDigits’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/samplePlugin’
g++ -MM -MF ../../bin/dchobj/samplePlugin.d -MP -MT ../../bin/dchobj/samplePlugin.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I “/usr/local/include” -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT samplePlugin.cpp
Compiling: samplePlugin.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/samplePlugin.o samplePlugin.cpp
g++ -MM -MF ../../bin/chobj/samplePlugin.d -MP -MT ../../bin/chobj/samplePlugin.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/ usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT samplePlugin.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include " -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/samplePlugin.o samplePlugin.cpp
Linking: ../../bin/sample_plugin
g++ -o ../../bin/sample_plugin ../../bin/chobj/samplePlugin.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/sample_plugin_debug
g++ -o ../../bin/sample_plugin_debug ../../bin/dchobj/samplePlugin.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/samplePlugin’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleFasterRCNN’
../Makefile.config:6: CUDA_INSTALL_DIR variable is not specified, using /usr/local/cuda-9.0 by default, use CUDA_INSTALL_DIR=<cuda_directory> to change.
../Makefile.config:9: CUDNN_INSTALL_DIR variable is not specified, using by default, use CUDNN_INSTALL_DIR=<cudnn_directory> to change.
g++ -MM -MF ../../bin/dchobj/sampleFasterRCNN.d -MP -MT ../../bin/dchobj/sampleFasterRCNN.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleFasterRCNN.cpp
Compiling: sampleFasterRCNN.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/sampleFasterRCNN.o sampleFasterRCNN.cpp
g++ -MM -MF ../../bin/chobj/sampleFasterRCNN.d -MP -MT ../../bin/chobj/sampleFasterRCNN.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleFasterRCNN.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/sampleFasterRCNN.o sampleFasterRCNN.cpp
Linking: ../../bin/sample_fasterRCNN
g++ -o ../../bin/sample_fasterRCNN ../../bin/chobj/sampleFasterRCNN.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/sample_fasterRCNN_debug
g++ -o ../../bin/sample_fasterRCNN_debug ../../bin/dchobj/sampleFasterRCNN.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleFasterRCNN’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleUffMNIST’
g++ -MM -MF ../../bin/dchobj/sampleUffMNIST.d -MP -MT ../../bin/dchobj/sampleUffMNIST.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleUffMNIST.cpp
Compiling: sampleUffMNIST.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/sampleUffMNIST.o sampleUffMNIST.cpp
g++ -MM -MF ../../bin/chobj/sampleUffMNIST.d -MP -MT ../../bin/chobj/sampleUffMNIST.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT sampleUffMNIST.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -D_REENTRANT -c -o ../../bin/chobj/sampleUffMNIST.o sampleUffMNIST.cpp
Linking: ../../bin/sample_uff_mnist
g++ -o ../../bin/sample_uff_mnist ../../bin/chobj/sampleUffMNIST.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
Linking: ../../bin/sample_uff_mnist_debug
g++ -o ../../bin/sample_uff_mnist_debug ../../bin/dchobj/sampleUffMNIST.o -L"“../../lib”" -L"/usr/local/cuda-9.0/targets/aarch64-linux/lib64" -L"/usr/local/lib" -L"../lib" -L"/usr/local/cuda-9.0/lib64" -L"/usr/local/cuda-9.0/lib64" -L"../../lib" -L../../bin -Wl,–start-group -lnvinfer -lnvparsers -lnvinfer_plugin -lcudnn -lcublas -lcudart_static -lnvToolsExt -lcudart -lrt -ldl -lpthread -Wl,–end-group
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleUffMNIST’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleOnnxMNIST’
make[1]: Leaving directory ‘/usr/src/tensorrt/samples/sampleOnnxMNIST’
make[1]: Entering directory ‘/usr/src/tensorrt/samples/sampleNMT’
if [ ! -d ../../bin/chobj/data ]; then mkdir -p ../../bin/dchobj/data; fi; if [ ! -d ../../bin/chobj/model ]; then mkdir -p ../../bin/dchobj/model; fi; :
g++ -MM -MF ../../bin/dchobj/trtUtil.d -MP -MT ../../bin/dchobj/trtUtil.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT trtUtil.cpp
Compiling: trtUtil.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/trtUtil.o trtUtil.cpp
g++ -MM -MF ../../bin/dchobj/sampleNMT.d -MP -MT ../../bin/dchobj/sampleNMT.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT sampleNMT.cpp
Compiling: sampleNMT.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/sampleNMT.o sampleNMT.cpp
g++ -MM -MF ../../bin/dchobj/data/dataWriter.d -MP -MT ../../bin/dchobj/data/dataWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/dataWriter.cpp
Compiling: data/dataWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/dataWriter.o data/dataWriter.cpp
g++ -MM -MF ../../bin/dchobj/data/limitedSamplesDataReader.d -MP -MT ../../bin/dchobj/data/limitedSamplesDataReader.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/limitedSamplesDataReader.cpp
Compiling: data/limitedSamplesDataReader.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/limitedSamplesDataReader.o data/limitedSamplesDataReader.cpp
g++ -MM -MF ../../bin/dchobj/data/benchmarkWriter.d -MP -MT ../../bin/dchobj/data/benchmarkWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/benchmarkWriter.cpp
Compiling: data/benchmarkWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/benchmarkWriter.o data/benchmarkWriter.cpp
g++ -MM -MF ../../bin/dchobj/data/textWriter.d -MP -MT ../../bin/dchobj/data/textWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/textWriter.cpp
Compiling: data/textWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/textWriter.o data/textWriter.cpp
g++ -MM -MF ../../bin/dchobj/data/textReader.d -MP -MT ../../bin/dchobj/data/textReader.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/textReader.cpp
Compiling: data/textReader.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/textReader.o data/textReader.cpp
g++ -MM -MF ../../bin/dchobj/data/vocabulary.d -MP -MT ../../bin/dchobj/data/vocabulary.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/vocabulary.cpp
Compiling: data/vocabulary.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/vocabulary.o data/vocabulary.cpp
g++ -MM -MF ../../bin/dchobj/data/bleuScoreWriter.d -MP -MT ../../bin/dchobj/data/bleuScoreWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/bleuScoreWriter.cpp
Compiling: data/bleuScoreWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/data/bleuScoreWriter.o data/bleuScoreWriter.cpp
g++ -MM -MF ../../bin/dchobj/model/softmaxLikelihood.d -MP -MT ../../bin/dchobj/model/softmaxLikelihood.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/softmaxLikelihood.cpp
Compiling: model/softmaxLikelihood.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/softmaxLikelihood.o model/softmaxLikelihood.cpp
g++ -MM -MF ../../bin/dchobj/model/multiplicativeAlignment.d -MP -MT ../../bin/dchobj/model/multiplicativeAlignment.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/multiplicativeAlignment.cpp
Compiling: model/multiplicativeAlignment.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/multiplicativeAlignment.o model/multiplicativeAlignment.cpp
g++ -MM -MF ../../bin/dchobj/model/slpProjection.d -MP -MT ../../bin/dchobj/model/slpProjection.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/slpProjection.cpp
Compiling: model/slpProjection.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/slpProjection.o model/slpProjection.cpp
g++ -MM -MF ../../bin/dchobj/model/lstmEncoder.d -MP -MT ../../bin/dchobj/model/lstmEncoder.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/lstmEncoder.cpp
Compiling: model/lstmEncoder.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/lstmEncoder.o model/lstmEncoder.cpp
g++ -MM -MF ../../bin/dchobj/model/context.d -MP -MT ../../bin/dchobj/model/context.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/context.cpp
Compiling: model/context.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/context.o model/context.cpp
g++ -MM -MF ../../bin/dchobj/model/componentWeights.d -MP -MT ../../bin/dchobj/model/componentWeights.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/componentWeights.cpp
Compiling: model/componentWeights.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/componentWeights.o model/componentWeights.cpp
g++ -MM -MF ../../bin/dchobj/model/lstmDecoder.d -MP -MT ../../bin/dchobj/model/lstmDecoder.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/lstmDecoder.cpp
Compiling: model/lstmDecoder.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/lstmDecoder.o model/lstmDecoder.cpp
g++ -MM -MF ../../bin/dchobj/model/slpEmbedder.d -MP -MT ../../bin/dchobj/model/slpEmbedder.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/slpEmbedder.cpp
Compiling: model/slpEmbedder.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/slpEmbedder.o model/slpEmbedder.cpp
g++ -MM -MF ../../bin/dchobj/model/debugUtil.d -MP -MT ../../bin/dchobj/model/debugUtil.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/debugUtil.cpp
Compiling: model/debugUtil.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/debugUtil.o model/debugUtil.cpp
g++ -MM -MF ../../bin/dchobj/model/slpAttention.d -MP -MT ../../bin/dchobj/model/slpAttention.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/slpAttention.cpp
Compiling: model/slpAttention.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/slpAttention.o model/slpAttention.cpp
g++ -MM -MF ../../bin/dchobj/model/beamSearchPolicy.d -MP -MT ../../bin/dchobj/model/beamSearchPolicy.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/beamSearchPolicy.cpp
Compiling: model/beamSearchPolicy.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -g -c -o ../../bin/dchobj/model/beamSearchPolicy.o model/beamSearchPolicy.cpp
if [ ! -d ../../bin/chobj/data ]; then mkdir -p ../../bin/chobj/data; fi; if [ ! -d ../../bin/chobj/model ]; then mkdir -p ../../bin/chobj/model; fi; :
g++ -MM -MF ../../bin/chobj/trtUtil.d -MP -MT ../../bin/chobj/trtUtil.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT trtUtil.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/trtUtil.o trtUtil.cpp
g++ -MM -MF ../../bin/chobj/sampleNMT.d -MP -MT ../../bin/chobj/sampleNMT.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT sampleNMT.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/sampleNMT.o sampleNMT.cpp
g++ -MM -MF ../../bin/chobj/data/dataWriter.d -MP -MT ../../bin/chobj/data/dataWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/dataWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/dataWriter.o data/dataWriter.cpp
g++ -MM -MF ../../bin/chobj/data/limitedSamplesDataReader.d -MP -MT ../../bin/chobj/data/limitedSamplesDataReader.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/limitedSamplesDataReader.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/limitedSamplesDataReader.o data/limitedSamplesDataReader.cpp
g++ -MM -MF ../../bin/chobj/data/benchmarkWriter.d -MP -MT ../../bin/chobj/data/benchmarkWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/benchmarkWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/benchmarkWriter.o data/benchmarkWriter.cpp
g++ -MM -MF ../../bin/chobj/data/textWriter.d -MP -MT ../../bin/chobj/data/textWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/textWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/textWriter.o data/textWriter.cpp
g++ -MM -MF ../../bin/chobj/data/textReader.d -MP -MT ../../bin/chobj/data/textReader.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/textReader.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/textReader.o data/textReader.cpp
g++ -MM -MF ../../bin/chobj/data/vocabulary.d -MP -MT ../../bin/chobj/data/vocabulary.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/vocabulary.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/vocabulary.o data/vocabulary.cpp
g++ -MM -MF ../../bin/chobj/data/bleuScoreWriter.d -MP -MT ../../bin/chobj/data/bleuScoreWriter.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT data/bleuScoreWriter.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/data/bleuScoreWriter.o data/bleuScoreWriter.cpp
g++ -MM -MF ../../bin/chobj/model/softmaxLikelihood.d -MP -MT ../../bin/chobj/model/softmaxLikelihood.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/softmaxLikelihood.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/softmaxLikelihood.o model/softmaxLikelihood.cpp
g++ -MM -MF ../../bin/chobj/model/multiplicativeAlignment.d -MP -MT ../../bin/chobj/model/multiplicativeAlignment.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/multiplicativeAlignment.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/multiplicativeAlignment.o model/multiplicativeAlignment.cpp
g++ -MM -MF ../../bin/chobj/model/slpProjection.d -MP -MT ../../bin/chobj/model/slpProjection.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/slpProjection.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/slpProjection.o model/slpProjection.cpp
g++ -MM -MF ../../bin/chobj/model/lstmEncoder.d -MP -MT ../../bin/chobj/model/lstmEncoder.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/lstmEncoder.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/lstmEncoder.o model/lstmEncoder.cpp
g++ -MM -MF ../../bin/chobj/model/context.d -MP -MT ../../bin/chobj/model/context.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/context.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/context.o model/context.cpp
g++ -MM -MF ../../bin/chobj/model/componentWeights.d -MP -MT ../../bin/chobj/model/componentWeights.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/componentWeights.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/componentWeights.o model/componentWeights.cpp
g++ -MM -MF ../../bin/chobj/model/lstmDecoder.d -MP -MT ../../bin/chobj/model/lstmDecoder.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/lstmDecoder.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/lstmDecoder.o model/lstmDecoder.cpp
g++ -MM -MF ../../bin/chobj/model/slpEmbedder.d -MP -MT ../../bin/chobj/model/slpEmbedder.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/slpEmbedder.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/slpEmbedder.o model/slpEmbedder.cpp
g++ -MM -MF ../../bin/chobj/model/debugUtil.d -MP -MT ../../bin/chobj/model/debugUtil.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/debugUtil.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/debugUtil.o model/debugUtil.cpp
g++ -MM -MF ../../bin/chobj/model/slpAttention.d -MP -MT ../../bin/chobj/model/slpAttention.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/slpAttention.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT -c -o ../../bin/chobj/model/slpAttention.o model/slpAttention.cpp
g++ -MM -MF ../../bin/chobj/model/beamSearchPolicy.d -MP -MT ../../bin/chobj/model/beamSearchPolicy.o -Wall -std=c++11 -I"/usr/local/cuda-9.0/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda-9.0/include" -I"../../include" -I"." -D_REENTRANT model/beamSearchPolicy.cpp
