As mentioned in previous posts 213791 and 214020 there is an issue on the TensorRT version of Jetpack 4.6.1 that makes it incompatible with Xavier NX emmc 16GB. It is suggested to upgrade to Jetpack 5.0.1. However, we are using Auvidea JNxxx board which provides firmware up to Jetpack 4.6. Is there any other workaround to solve the missing TensorRT device entry?
Does your board work with JetPack 4.6 which contains TensorRT 8.0?
This issue is specified for the TensorRT 8.2.
Please uses TensorRT 8.0 (JetPack 4.6) or TensorRT 8.2 (JetPack 5) instead.
You can find the overlay patch below:
Thank you. Using that patch solved it.
