• Hardware Platform (Jetson / GPU) Jetson AGX Orin • DeepStream Version 6.3 • JetPack Version (valid for Jetson only) 5.1.2
The Pytorch code that is running a Tensorrt engine for the same model has some names for the heads at the output layer. When I try to profile the TensorRT engine using trtexec, I see generic names like output_0, output_1 and output_2. Why is this happening? Am I missing something?
You can use INetworkDefinition::setWeightsName() to name weights at build time - the ONNX parser uses this API to associate the weights with the names used in the ONNX model. Otherwise, TensorRT will name the weights internally based on the related layer names and weight roles.
def default_output_names(num_outputs):
return ["output_%d" % i for i in range(num_outputs)]
But this function is called when there is no output pre-defined.
Please try to feed the expected output name when calling the torch2trt.
(ex. output_names=['output_0','output_1',output_2])
