TensorRT view the layers that are converted
Description
I’m trying to convert a saved_model to a TensorRT model using tensorflow.python.compiler.tensorrt.trt_convert.TrtGraphConverterV2 but I’m not able to see the log with the details on which layers have been converted or optimized for TensorRT. Also, is there a way to view the layers a of the model after being converted to TRT saved_model?
Environment
TensorRT Version:
GPU Type: Tesla T4
Nvidia Driver Version: 450.80.02
CUDA Version: 11.0
Operating System + Version: AWS Sagemaker instance ml.g4dn.xlarge
Python Version (if applicable): 3.7
TensorFlow Version (if applicable): 2.5
Relevant Files
def convert_to_trt_graph_and_save(precision_mode='float32', input_saved_model_dir='resnet_v2_152_saved_model', calibration_data=''):
    if precision_mode == 'float32':
        precision_mode = trt.TrtPrecisionMode.FP32
        converted_save_suffix = '_TFTRT_FP32'
    if precision_mode == 'float16':
        precision_mode = trt.TrtPrecisionMode.FP16
        converted_save_suffix = '_TFTRT_FP16'
    # Per usual, set the precision_mode
    if precision_mode == 'int8':
        precision_mode = trt.TrtPrecisionMode.INT8
        converted_save_suffix = '_TFTRT_INT8'
    output_saved_model_dir = input_saved_model_dir + converted_save_suffix
    conversion_params = trt.DEFAULT_TRT_CONVERSION_PARAMS._replace(
        precision_mode=precision_mode,
        max_workspace_size_bytes=8000000000
    converter = trt.TrtGraphConverterV2(
        input_saved_model_dir=input_saved_model_dir,
        conversion_params=conversion_params
    print('Converting {} to TF-TRT graph precision mode {}...'.format(input_saved_model_dir, precision_mode))
    if precision_mode == trt.TrtPrecisionMode.INT8:
        # Here we define a simple generator to yield calibration data
        def calibration_input_fn():
            yield (calibration_data, )
        # When performing INT8 optimization, we must pass a calibration function to convert
        converter.convert(calibration_input_fn=calibration_input_fn)
    else:
        converter.convert()
    print(converter.graph.structured_outputs)
    print('Saving converted model to {}...'.format(output_saved_model_dir))
    converter.save(output_saved_model_dir=output_saved_model_dir)
    print('Complete')
convert_to_trt_graph_and_save(precision_mode='float32', input_saved_model_dir='savedmodel', calibration_data= batched_input)
Hi @dhivya.jayaraman,
If you are using TF-TRT, TensorRT logs appear as part of TensorFlow logs. The verbosity level of TensorFlow logs affects the verbosity level of TensorRT logs. Please refer,
Thank you.
