A clear and concise description of the bug or issue.
Environment
TensorRT Version : ‘8.0.1.6’ GPU Type : Nvidia Driver Version : CUDA Version : 11.4 CUDNN Version : 8.2 Operating System + Version : ubuntu 20.04 Python Version (if applicable) : 3.8.10 TensorFlow Version (if applicable) : PyTorch Version (if applicable) : ‘1.8.1+cu102’ Baremetal or Container (if container which image + tag) :
Relevant Files
Can anyone give a sample code to implement quantize and dequantize nodes in the Tensor RT network using Python API.
The above example converts an ONNX model to TensorRT. Can you give an example where you convert the PyTorch QAT model to TensorRT without converting it into ONNX?
These two documents don’t have any example code to implement for the direct QAT Torch model to TensorRT without converting it into ONNX.
Can anyone share the related documents with code samples.
