Description
pytorch → onnx → tensorrt
Environment
TensorRT Version : tensorrt 7.0.0.11
GPU Type : RTX 2080ti
Nvidia Driver Version : 440.64
CUDA Version : 10.2
CUDNN Version : i don’t know
Operating System + Version : ubuntu 18.04
Python Version (if applicable) : 3.6x
TensorFlow Version (if applicable) : X
PyTorch Version (if applicable) : 1.4.0
Baremetal or Container (if container which image + tag) : Ok ( _tensorrt git(url:GitHub - NVIDIA/TensorRT: NVIDIA® TensorRT™ is an SDK for high-performance deep learning inference on NVIDIA GPUs. This repository contains the open source components of TensorRT.))
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
class Res_Deeplab(nn.Module):
def __init__(self):
super(Res_Deeplab, self).__init__()
self.conv1 = nn.Conv2d(3, 64, kernel_size=3, stride=2, padding=1, bias=False)
self.bn1 = nn.BatchNorm2d(64)
self.maxpool = nn.MaxPool2d(kernel_size=3, stride=2, padding=1, ceil_mode=True)
self.relu = nn.ReLU(inplace=False)
self.avgpool = nn.AvgPool2d((129,257))
self.conv2 = nn.Conv2d(64, 64, kernel_size=1, padding=0, dilation=1, bias=False)
self.conv3 = nn.Conv2d(64, 64, kernel_size=1, padding=0, dilation=1, bias=False)
self.conv4 = nn.Conv2d(64, 64, kernel_size=3, padding=12, dilation=12, bias=False)
self.conv5 = nn.Conv2d(64, 64, kernel_size=3, padding=24, dilation=24, bias=False)
self.conv6 = nn.Conv2d(64, 64, kernel_size=3, padding=36, dilation=36, bias=False)
def forward(self, x):
x = self.conv1(x)
x = self.bn1(x)
x = self.relu(x)
x = self.maxpool(x)
x = self.maxpool(x)
x1 = self.avgpool(x)
x1 = self.conv2(x1)
feat1 = F.interpolate(x1, size=(129, 257), mode='bilinear', align_corners=True)
feat2 = self.conv3(x)
feat3 = self.conv4(x)
feat4 = self.conv5(x)
feat5 = self.conv6(x)
#out = torch.cat((feat1, feat2, feat3, feat4, feat5), 1)
return feat1
Steps To Reproduce
./trtexec --onnx=output_deeplabv3.onnx --explicitBatch --verbose=True --workspace=9000 --shapes=input:1x3x1024x2048
- code error :
[04/19/2020-19:34:19] [V] [TRT] /workspace/TensorRT/parsers/onnx/ModelImporter.cpp:181: [Concat] outputs: [31 -> (4)],
[04/19/2020-19:34:19] [V] [TRT] /workspace/TensorRT/parsers/onnx/ModelImporter.cpp:107: Parsing node: [Resize]
[04/19/2020-19:34:19] [V] [TRT] /workspace/TensorRT/parsers/onnx/ModelImporter.cpp:123: Searching for input: 22
[04/19/2020-19:34:19] [V] [TRT] /workspace/TensorRT/parsers/onnx/ModelImporter.cpp:123: Searching for input: 24
[04/19/2020-19:34:19] [V] [TRT] /workspace/TensorRT/parsers/onnx/ModelImporter.cpp:123: Searching for input: 31
[04/19/2020-19:34:19] [V] [TRT] /workspace/TensorRT/parsers/onnx/ModelImporter.cpp:129: [Resize] inputs: [22 -> (1, 64, 1, 1)], [24 -> ()], [24 -> ()], [31 -> (4)],
While parsing node number 16 [Resize -> "32"]:
--- Begin node ---
input: "22"
input: "24"
input: "24"
input: "31"
output: "32"
op_type: "Resize"
attribute {
s: "align_corners"
type: STRING
attribute {
f: -0.75
type: FLOAT
attribute {
s: "linear"
type: STRING
attribute {
s: "floor"
type: STRING
--- End node ---
ERROR: /workspace/TensorRT/parsers/onnx/builtin_op_importers.cpp:2453 In function importResize:
[8] Assertion failed: (transformationMode == "asymmetric") && "This version of TensorRT only supports asymmetric resize!"
[04/19/2020-19:34:19] [E] Failed to parse onnx file
[04/19/2020-19:34:19] [E] Parsing model failed
[04/19/2020-19:34:19] [E] Engine creation failed
[04/19/2020-19:34:19] [E] Engine set up failed
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
