TensorRT5 sampleSSD ssd.prototxt missing
TensorRT-Developer-Guide
9.1.13.3. Defining The Network
The network is defined in a prototxt file which is shipped with the sample and located
in the data/ssd directory. The original prototxt file provided by the authors is modified
and included in the TensorRT in-built plugin layers in the prototxt file.
But,There is not ssd.prototxt in /data/ssd.
which version of TRT are you referencing?
I am having the same issue.
The TRT version is 5.0.2.6
I’m looking at the latest document https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#sample_movie, I don’t see a section 9.1.13.3. Defining The Network
You’re looking at the wrong place.
Take a look at [url]https://docs.nvidia.com/deeplearning/sdk/tensorrt-archived/tensorrt-503/tensorrt-developer-guide/index.html#sample_ssd_define[/url]
It is mentioned that
The network is defined in a prototxt file which is shipped with the sample and located in the data/ssd directory. The original prototxt file provided by the authors is modified and included in the TensorRT in-built plugin layers in the prototxt file.
But there isn’t any prototxt file.
The sample README has instructions on how to generate the prototxt file. I believe this was mentioned in the release notes.
The docs need to be updated.
https://docs.nvidia.com/deeplearning/sdk/tensorrt-release-notes/tensorrt-5.html#rel_5-0-2
Thank you!
I don’t find the README very clear on how to edit the prototxt file, Is the ssd.prototxt file available somewhere online ?
