A clear and concise description of the bug or issue.
Environment
TensorRT Version: 8.4.0.6-ea GPU Type: 3090ti Nvidia Driver Version:510.+ CUDA Version: 11.6 CUDNN Version: 8.4.0 Operating System + Version: ubuntu18.04.6
cuda11.6 and cudnn 8.4.0 installed already, but the cuda path is /home/tools/cuda/cuda-11.6
when I want install tensorrt8.4.0-ea failured.
cmd: sudo apt install tensorrt
output:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
tensorrt : Depends: libnvinfer8 (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvinfer-plugin8 (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvparsers8 (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvonnxparsers8 (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvinfer-bin (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvinfer-dev (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvinfer-plugin-dev (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvparsers-dev (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvonnxparsers-dev (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvinfer-samples (= 8.4.0-1+cuda11.6) but it is not going to be installed
Depends: libnvinfer-doc (= 8.4.0-1+cuda11.6) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
but when I install these depends:
sudo apt install libnvinfer8=8.4.0-1+cuda11.6 libnvinfer-plugin8=8.4.0-1+cuda11.6 libnvparsers8=8.4.0-1+cuda11.6 libnvonnxparsers8=8.4.0-1+cuda11.6 libnvinfer-bin=8.4.0-1+cuda11.6 libnvinfer-dev=8.4.0-1+cuda11.6 libnvinfer-plugin-dev=8.4.0-1+cuda11.6 libnvparsers-dev=8.4.0-1+cuda11.6 libnvonnxparsers-dev=8.4.0-1+cuda11.6 libnvinfer-samples=8.4.0-1+cuda11.6 libnvinfer-doc=8.4.0-1+cuda11.6
errors is :
libnvinfer-dev : Depends: libcublas.so.11-dev but it is not installable or
libcublas-dev-11-1 but it is not installable or
libcublas-dev-11-0 but it is not installable
libnvinfer-samples : Depends: libcudart.so.11.0-dev but it is not installable or
cuda-cudart-dev-11-1 but it is not installable or
cuda-cudart-dev-11-0 but it is not installable or
cuda-cudart-cross-amd64-11-6 but it is not installable
Depends: cuda-nvcc-11-1 but it is not installable or
cuda-nvcc-11-2 but it is not installable or
cuda-nvcc-11-3 but it is not installable or
cuda-nvcc-11-4 but it is not installable or
cuda-nvcc-11-5 but it is not installable or
cuda-nvcc-11-6 but it is not installable or
cuda-nvcc-11-0 but it is not installable
libnvinfer8 : Depends: libcublas.so.11 but it is not installable or
libcublas-11-1 but it is not installable or
libcublas-11-0 but it is not installable
GST_DEBUG=3 deepstream-app -c ./configs/deepstream-app/source2_1080p_dec_infer-resnet_demux_int8.txt
0:00:00.105175225 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.105210562 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.105217060 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.105222658 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.105231042 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5648e55c8a00 Failed to determine interlace mode
0:00:00.105243820 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.105249670 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.105253914 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.105259771 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.105264537 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5648e55c8a00 Failed to determine interlace mode
0:00:00.105301789 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:src> Unable to try format: Unknown error -1
0:00:00.105308756 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:src> Could not probe minimum capture size for pixelformat H264
0:00:00.105320535 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:src> Unable to try format: Unknown error -1
0:00:00.105327305 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:src> Could not probe maximum capture size for pixelformat H264
0:00:00.105560262 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.105568779 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.105572988 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.105577491 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.105582890 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5648e54d84c0 Failed to determine interlace mode
0:00:00.105592852 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.105597389 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.105601228 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.105605668 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.105610105 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5648e54d84c0 Failed to determine interlace mode
0:00:00.105640967 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:00.105645831 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe minimum capture size for pixelformat H264
0:00:00.105650549 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:00.105655341 130470 0x5648e5926380 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe maximum capture size for pixelformat H264
0:00:01.897674414 130470 0x5648e5926380 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:01.987243081 130470 0x5648e5926380 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:01.988880646 130470 0x5648e5926380 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
0:00:01.989704597 130470 0x5648e5926380 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete:
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
** INFO: <bus_callback:194>: Pipeline ready
0:00:02.004542864 130470 0x7fe9b8059f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:02.004565964 130470 0x7fe9b4024de0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:02.004817926 130470 0x7fe9b8059f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:02.004852937 130470 0x7fe9b4024de0 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:02.059440421 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059480809 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.059495726 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059508781 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.059559557 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059580186 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.059594712 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059610476 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.059646141 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059676213 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.059696322 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059755704 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.059787200 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059801378 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:02.059812740 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059825515 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:02.059848820 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059860946 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.059872144 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059887879 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.059910326 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059921901 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.059932470 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059944447 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.059968511 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.059981160 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:02.059992727 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.060008102 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:02.060107187 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:02.060139313 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:02.060152994 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:02.060168544 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:02.060189565 130470 0x7fe9ac0128f0 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7fe9a001da30 Failed to determine interlace mode
0:00:02.060398727 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060437117 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.060451828 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060465897 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.060508143 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060520807 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.060531458 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060542914 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.060572644 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060588438 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.060601779 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060615570 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.060645583 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060659703 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:02.060671456 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060683756 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:02.060706926 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060718761 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.060730389 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060746526 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.060768861 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060784381 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.060796487 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060811127 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.060837416 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060852582 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:02.060865618 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.060879968 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:02.060962949 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:02.060977934 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:02.060991340 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:02.061005609 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
0:00:02.061025620 130470 0x7fe9a8013ad0 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7fe9a401e430 Failed to determine interlace mode
0:00:02.173113840 130470 0x7fe9ac0128f0 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:02.173542110 130470 0x7fe9ac0128f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:02.181552438 130470 0x7fe9a8013ad0 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:02.188705841 130470 0x7fe9a8013ad0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:02.189039208 130470 0x7fe9a000bb20 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:02.190426352 130470 0x7fe998002320 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
Cuda failure: status=1 in cuResData at line 316
Cuda failure: status=1 in cuResData at line 348
** INFO: <bus_callback:180>: Pipeline running
0:00:02.273995375 130470 0x5648e54eb0a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:02.282161610 130470 0x5648e54eaed0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder2:pool:src> Uncertain or not enough buffers, enabling copy threshold
