Im using GTX750Ti for CUDA programming
then Tesla K40 arrived by funding
im unable to figure out how it will works
on motherboard PCI-E 3 dual slot is available
I assume your K40 is a K40c, meaning it has a fan on it.
No other steps are required. Your existing CUDA installation that you are using with the GTX750Ti should just work with the K40. As a test, run:
nvidia-smi
You can also run the deviceQuery CUDA sample code.
So any Geforce newer than 7xx will work nicely with a K40c?
