we met some issue when testing cuMAC-CP with task bit set as 0xf.
Is it an known issue currently?
we see some description about this part in release guide as below. Does it mean we cannot finish cuMAC-CP test with task_bitmask=0xf?
Test command:
aerial@alpha:/opt/nvidia/cuBB/testVectors/cumac$ sudo $cuBB_SDK/build/cuMAC-CP/cumac_cp
aerial@alpha:/opt/nvidia/cuBB$ sudo $cuBB_SDK/build/cuPHY-CP/testMAC/testMAC/test_mac F08 8C_60c
cumac-cp error
10:20:00.955021 WRN 732 475914 [CUMCP.HANDLER] SFN 78.10: task process can’t catch up with enqueue, drop slot
10:20:00.955693 WRN 732 475914 [CUMCP.HANDLER] SFN 78.12: task process can’t catch up with enqueue, drop slot
10:20:00.956345 WRN 732 475914 [CUMCP.HANDLER] SFN 78.13: task process can’t catch up with enqueue, drop slot
10:20:00.957017 WRN 732 475914 [CUMCP.HANDLER] SFN 78.14: task process can’t catch up with enqueue, drop slot
10:20:00.957688 WRN 732 475914 [CUMCP.HANDLER] SFN 78.16: task process can’t catch up with enqueue, drop slot
sigaction_handler: SIGNAL 11 - exit
Segmentation fault
testMAC error
10:20:01.213002 ERR 741 0 [AERIAL_CUMAC_CP_EVENT] [CUMAC.HANDLER] Error: testMAC scheduler is full, please check SLOT.ind sending frequency
10:20:01.213502 ERR 741 0 [AERIAL_CUMAC_CP_EVENT] [CUMAC.HANDLER] Error: testMAC scheduler is full, please check SLOT.ind sending frequency
10:20:01.214002 ERR 741 0 [AERIAL_CUMAC_CP_EVENT] [CUMAC.HANDLER] Error: testMAC scheduler is full, please check SLOT.ind sending frequency
10:20:01.214502 ERR 741 0 [AERIAL_CUMAC_CP_EVENT] [CUMAC.HANDLER] Error: testMAC scheduler is full, please check SLOT.ind sending frequency
10:20:01.215002 ERR 741 0 [AERIAL_CUMAC_CP_EVENT] [CUMAC.HANDLER] Error: testMAC scheduler is full, please check SLOT.ind sending frequency
10:20:01.215502 ERR 741 0 [AERIAL_CUMAC_CP_EVENT] [CUMAC.HANDLER] Error: testMAC scheduler is full, please check SLOT.ind sending frequency
