From earlier in your “v4l2-ctl --all” command it looks like your sensor is “BA10” OR V4L2_PIX_FMT_SGRBG10 Bayer 10-bit GRGR.. BGBG. Is that correct?
I’m not sure, I am waiting for format information by contacting the manufacturer with a technical inquiry.
Also, what is the exact size in bytes of your s5k5e8.raw file when you run the v4l2-ctl command to capture a frame?
The raw file size created by v4l2-ctl is 10,536,960 bytes.
For the raw file checking, you can read it by 7yuv or imagej
Hi ShaneCCC,
We fixed the hardware issue and tested it with --stream-count = 100 as your advice to make sure the capture file was saved.
I ran nvgstcapture-1.0, which was notified to check the video, but there was no video screen except the 1340x 980 screen setting message as shown below.
jpchae@jpchae-desktop:~/Downloads$ nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
(5) : 2104x1560
(6) : 2592x1944
(7) : 2616x1472
(8) : 3840x2160
(9) : 3896x2192
(10): 4208x3120
(11): 5632x3168
(12): 5632x4224
Runtime ARGUS Camera Commands:
Help : 'h'
Quit : 'q'
Set Capture Mode:
mo:<val>
(1): image
(2): video
Get Capture Mode:
gmo
Set sensor orientation:
so:<val>
(0): none
(1): Rotate counter-clockwise 90 degrees
(2): Rotate 180 degrees
(3): Rotate clockwise 90 degrees
Get sensor orientation:
gso
Set sensor mode:
smo:<val> e.g., smo:1
Get sensor mode:
gsmo
Set Whitebalance Mode:
wb:<val>
(0): off
(1): auto
(2): incandescent
(3): fluorescent
(4): warm-fluorescent
(5): daylight
(6): cloudy-daylight
(7): twilight
(8): shade
(9): manual
Get Whitebalance Mode:
gwb
Set Saturation (0 to 2):
st:<val> e.g., st:1.25
Get Saturation:
gst
Set Exposure Compensation (-2 to 2):
ec:<val> e.g., ec:-2
Get Exposure Compensation:
gec
Set Auto Whitebalance Lock:
awbl:<val> e.g., awbl:0
Get Auto Whitebalance Lock:
awbl
Set Auto Exposure Lock:
ael:<val> e.g., ael:0
Get Auto Exposure Lock:
gael
Set TNR Mode:
tnrm:<val> e.g., tnrm:1
(0): OFF
(1): FAST
(2): HIGH QUALITY
Get TNR Mode:
gtnrm
Set TNR Strength (-1 to 1):
tnrs:<val> e.g., tnrs:0.5
Get TNR Strength:
gtnrs
Set EE Mode:
eem:<val> e.g., eem:1
(0): OFF
(1): FAST
(2): HIGH QUALITY
Get EE Mode:
geem
Set EE Strength (-1 to 1):
ees:<val> e.g., ees:0.5
Get EE Strength:
gees
Set Auto Exposure Anti-Banding (0 to 3):
aeab:<val> e.g., aeab:2
(0): OFF
(1): MODE AUTO
(2): MODE 50HZ
(3): MODE 60HZ
Get Auto Exposure Anti-Banding:
gaeab
Set Gain Range:
gr:<val><space><val> e.g., gr:1 16
Get Gain Range:
ggr
Set Exposure Time Range:
etr:<val><space><val> e.g., etr:34000 35000
Get Exposure Time Range:
getr
Set ISP Digital Gain Range:
dgr:<val><space><val> e.g., dgr:2 152
Get ISP Digital Gain Range:
gdgr
Capture: enter 'j' OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter '1'
Stop Recording : enter '0'
Video snapshot : enter '2' (While recording video)
Get Preview Resolution:
gpcr
Get Image Capture Resolution:
gicr
Get Video Capture Resolution:
gvcr
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br:<val> e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep:<val> e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter 'f'
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
Message: 17:33:16.521: <main:4670> iterating capture loop ....
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2608 x 1960 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 0.000000, max 6.000000; Exposure Range min 16000000, max 30088000;
GST_ARGUS: 1340 x 980 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 0.000000, max 6.000000; Exposure Range min 16000000, max 30088000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 1
Output Stream W = 1340 H = 980
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: PowerService: requested_clock_Hz=4032000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Did you check the preview on HDMI display connect to TX2?
Yes, I’m testing on HDMI display connect to TX2.
Could you check below command if can see the preview.
gst-launch-1.0 videotestsrc ! video/x-raw,width=1920,height=1080,rate=30/1 ! xvimagesink
Have a try below command.
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=2608,height=1960’ ! nvvidconv ! xvimagesink
I’m not sure how your 2608x1960 sensor generates a raw file that size. It seems there must be extra rows or columns that are making up the extra space. Are there 80 extra columns? So the raw output from the sensor is really 2688x1960?
Also, is the Bayer format BA10?
With the right Bayer format I can give you the command to capture the raw sensor data and bypass the ISP. Then that data can be easily converted to an image for inspection. This removes any artifacts that could be added by the ISP and lets you better examine what the sensor is actually outputing.
Hi JDSchroeder,
I don’t know how to check added extra columns in raw file.
I was setup active resolution “width=2608, height=1960” .
Datasheet is only display Bayer raw10.
They support picture pixel information as shown below.
Is that GRBR Bayer format?
It is difficult for me to determine the format by looking at the picture below.
Hi Shane,
I ran the nvgstcapture-1.0 command, and after looking at the serial log message,
the following cdma_handle_timeout message appeared.
Please, give me a good advise.
[ 115.995378] s5k5e8 2-0018: s5k5e8_set_mode: mode 0
[ 116.093937] s5k5e8 2-0018: s5k5e8_start_streaming: start streaming
[ 116.154422] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 49 (15700000.vi_2) clientid 20, HW thresh 0 , done 1
[ 116.165083] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 48 (15700000.vi_1) clientid 20, HW thresh 1 , done 1
[ 116.176642] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 47 (15700000.vi_0) clientid 20, HW thresh 1 , done 1
[ 122.185026] host1x 13e10000.host1x: CaptureSchedule: syncpoint id 39 (15600000.isp_nvargus-daemon_4) stuck wa iting 18, timeout=-1
[ 126.281019] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 35 (15600000.isp_nvargus-daemon_0) clientid 11, HW thresh 0, done 2
[ 126.293030] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 36 (15600000.isp_nvargus-daemon_1) clientid 11, HW thresh 0, done 1
[ 126.305055] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 37 (15600000.isp_nvargus-daemon_2) clientid 11, HW thresh 0, done 1
[ 126.317074] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 38 (15600000.isp_nvargus-daemon_3) clientid 11, HW thresh 0, done 1
[ 126.329087] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 40 (15600000.isp_nvargus-daemon_5) clientid 11, HW thresh 0, done 1
[ 126.341100] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 39 (15600000.isp_nvargus-daemon_4) clientid 11, HW thresh 15, done 15
[ 136.521026] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 35 (15600000.isp_nvargus-daemon_0) clientid 11, HW thresh 4, done 6
[ 136.533035] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 36 (15600000.isp_nvargus-daemon_1) clientid 11, HW thresh 2, done 3
[ 136.545035] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 37 (15600000.isp_nvargus-daemon_2) clientid 11, HW thresh 2, done 3
[ 136.557039] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 38 (15600000.isp_nvargus-daemon_3) clientid 11, HW thresh 2, done 3
[ 136.569034] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 40 (15600000.isp_nvargus-daemon_5) clientid 11, HW thresh 2, done 3
[ 136.581032] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 39 (15600000.isp_nvargus-daemon_4) clientid 11, HW thresh 31, done 31
Can you check the trace log for nvgstcapture-1.0
Hi ShaneCCC,
The trace log message is attached below.
root@jpchae-desktop:/home/jpchae# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 334/334 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l_id-8559 [005] .... 336.275736: tegra_channel_open: vi-output, s5k5e8 2-0018
v4l_id-8559 [003] .... 336.276749: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
v4l_id-8559 [003] .... 336.276757: camera_common_s_power: status : 0x1
v4l_id-8559 [003] .... 336.281121: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l_id-8559 [003] .... 336.281126: csi_s_power: enable : 0x1
v4l_id-8559 [003] .... 336.282827: tegra_channel_close: vi-output, s5k5e8 2-0018
v4l_id-8559 [003] .... 336.282834: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
v4l_id-8559 [003] .... 336.282841: camera_common_s_power: status : 0x0
v4l_id-8559 [003] .... 336.284966: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l_id-8559 [003] .... 336.284969: csi_s_power: enable : 0x0
gst-plugin-scan-8583 [000] .... 413.796419: tegra_channel_open: vi-output, s5k5e8 2-0018
gst-plugin-scan-8583 [000] .... 413.797446: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
gst-plugin-scan-8583 [000] .... 413.797454: camera_common_s_power: status : 0x1
gst-plugin-scan-8583 [000] .... 413.801802: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
gst-plugin-scan-8583 [000] .... 413.801805: csi_s_power: enable : 0x1
gst-plugin-scan-8583 [000] .... 413.804877: tegra_channel_close: vi-output, s5k5e8 2-0018
gst-plugin-scan-8583 [000] .... 413.804882: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
gst-plugin-scan-8583 [000] .... 413.804889: camera_common_s_power: status : 0x0
gst-plugin-scan-8583 [000] .... 413.807002: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
gst-plugin-scan-8583 [000] .... 413.807003: csi_s_power: enable : 0x0
nvargus-daemon-8592 [005] .... 414.272330: tegra_channel_open: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [005] .... 414.272340: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
nvargus-daemon-8592 [005] .... 414.272347: camera_common_s_power: status : 0x1
nvargus-daemon-8592 [000] .... 414.276691: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8592 [000] .... 414.276694: csi_s_power: enable : 0x1
nvargus-daemon-8592 [000] .... 414.276822: tegra_channel_close: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.276824: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
nvargus-daemon-8592 [000] .... 414.276828: camera_common_s_power: status : 0x0
nvargus-daemon-8592 [000] .... 414.278920: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8592 [000] .... 414.278921: csi_s_power: enable : 0x0
nvargus-daemon-8592 [000] .... 414.281412: tegra_channel_open: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.281418: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
nvargus-daemon-8592 [000] .... 414.281422: camera_common_s_power: status : 0x1
nvargus-daemon-8592 [000] .... 414.285718: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8592 [000] .... 414.285719: csi_s_power: enable : 0x1
nvargus-daemon-8592 [000] .... 414.285777: tegra_channel_close: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.285778: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
nvargus-daemon-8592 [000] .... 414.285781: camera_common_s_power: status : 0x0
nvargus-daemon-8592 [000] .... 414.287867: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8592 [000] .... 414.287868: csi_s_power: enable : 0x0
nvargus-daemon-8592 [000] .... 414.301419: tegra_channel_open: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.301427: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
nvargus-daemon-8592 [000] .... 414.301434: camera_common_s_power: status : 0x1
nvargus-daemon-8592 [000] .... 414.305744: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8592 [000] .... 414.305747: csi_s_power: enable : 0x1
nvargus-daemon-8592 [000] .... 414.305769: tegra_channel_close: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.305772: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
nvargus-daemon-8592 [000] .... 414.305776: camera_common_s_power: status : 0x0
nvargus-daemon-8592 [000] .... 414.307882: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8592 [000] .... 414.307885: csi_s_power: enable : 0x0
nvargus-daemon-8592 [000] .... 414.308140: tegra_channel_open: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.308145: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
nvargus-daemon-8592 [000] .... 414.308152: camera_common_s_power: status : 0x1
nvargus-daemon-8592 [005] .... 414.312479: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8592 [005] .... 414.312483: csi_s_power: enable : 0x1
nvargus-daemon-8592 [005] .... 414.312569: tegra_channel_close: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [005] .... 414.312572: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
nvargus-daemon-8592 [005] .... 414.312578: camera_common_s_power: status : 0x0
nvargus-daemon-8592 [005] .... 414.314674: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8592 [005] .... 414.314676: csi_s_power: enable : 0x0
nvargus-daemon-8592 [000] .... 414.314929: tegra_channel_open: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.314934: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
nvargus-daemon-8592 [000] .... 414.314939: camera_common_s_power: status : 0x1
nvargus-daemon-8592 [000] .... 414.319222: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
nvargus-daemon-8592 [000] .... 414.319223: csi_s_power: enable : 0x1
nvargus-daemon-8592 [000] .... 414.319315: tegra_channel_close: vi-output, s5k5e8 2-0018
nvargus-daemon-8592 [000] .... 414.319318: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
nvargus-daemon-8592 [000] .... 414.319321: camera_common_s_power: status : 0x0
nvargus-daemon-8592 [000] .... 414.321407: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
nvargus-daemon-8592 [000] .... 414.321408: csi_s_power: enable : 0x0
kworker/5:1-1613 [005] .... 414.372818: rtos_queue_peek_from_isr_failed: tstamp:13231526932 queue:0x0b4b4500
kworker/5:1-1613 [005] .... 414.372823: rtcpu_start: tstamp:13231527965
kworker/5:1-1613 [005] .... 414.372824: rtos_queue_send_from_isr_failed: tstamp:13231536390 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.372825: rtos_queue_send_from_isr_failed: tstamp:13231536496 queue:0x0b4aad68
kworker/5:1-1613 [005] .... 414.372826: rtos_queue_send_from_isr_failed: tstamp:13231536602 queue:0x0b4ac998
kworker/5:1-1613 [005] .... 414.372826: rtos_queue_send_from_isr_failed: tstamp:13231536711 queue:0x0b4ae518
kworker/5:1-1613 [005] .... 414.372827: rtos_queue_send_from_isr_failed: tstamp:13231536820 queue:0x0b4af2d8
kworker/5:1-1613 [005] .... 414.372828: rtos_queue_send_from_isr_failed: tstamp:13231536925 queue:0x0b4b0098
kworker/5:1-1613 [005] .... 414.372828: rtos_queue_send_from_isr_failed: tstamp:13231537030 queue:0x0b4b0e58
kworker/5:1-1613 [005] .... 414.372829: rtos_queue_send_from_isr_failed: tstamp:13231537135 queue:0x0b4b1c18
kworker/5:1-1613 [005] .... 414.372830: rtos_queue_send_failed: tstamp:13231537598 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.540812: rtos_queue_peek_from_isr_failed: tstamp:13236527280 queue:0x0b4b4500
CaptureSchedule-8611 [005] .... 414.566778: tegra_channel_open: vi-output, s5k5e8 2-0018
CaptureSchedule-8611 [005] .... 414.566788: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
CaptureSchedule-8611 [005] .... 414.566796: camera_common_s_power: status : 0x1
CaptureSchedule-8611 [005] .... 414.572234: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
CaptureSchedule-8611 [005] .... 414.572238: csi_s_power: enable : 0x1
CaptureSchedule-8611 [003] .... 414.574572: tegra_channel_set_stream: enable : 0x1
CaptureSchedule-8611 [000] .... 414.577143: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
CaptureSchedule-8611 [000] .... 414.577156: csi_s_stream: enable : 0x1
CaptureSchedule-8611 [000] .... 414.577157: tegra_channel_set_stream: s5k5e8 2-0018 : 0x1
kworker/5:1-1613 [005] .... 414.596791: rtos_queue_send_from_isr_failed: tstamp:13238343075 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.596794: rtos_queue_send_from_isr_failed: tstamp:13238343185 queue:0x0b4aad68
kworker/5:1-1613 [005] .... 414.596795: rtos_queue_send_from_isr_failed: tstamp:13238343293 queue:0x0b4ac998
kworker/5:1-1613 [005] .... 414.596795: rtos_queue_send_from_isr_failed: tstamp:13238343399 queue:0x0b4ae518
kworker/5:1-1613 [005] .... 414.596796: rtos_queue_send_from_isr_failed: tstamp:13238343503 queue:0x0b4af2d8
kworker/5:1-1613 [005] .... 414.596797: rtos_queue_send_from_isr_failed: tstamp:13238343608 queue:0x0b4b0098
kworker/5:1-1613 [005] .... 414.596797: rtos_queue_send_from_isr_failed: tstamp:13238343712 queue:0x0b4b0e58
kworker/5:1-1613 [005] .... 414.596798: rtos_queue_send_from_isr_failed: tstamp:13238343815 queue:0x0b4b1c18
kworker/5:1-1613 [005] .... 414.596799: rtos_queue_send_failed: tstamp:13238344273 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.596800: rtos_queue_send_from_isr_failed: tstamp:13238587893 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.596801: rtos_queue_send_from_isr_failed: tstamp:13238588008 queue:0x0b4aad68
kworker/5:1-1613 [005] .... 414.596801: rtos_queue_send_from_isr_failed: tstamp:13238588115 queue:0x0b4ac998
kworker/5:1-1613 [005] .... 414.596802: rtos_queue_send_from_isr_failed: tstamp:13238588221 queue:0x0b4ae518
kworker/5:1-1613 [005] .... 414.596802: rtos_queue_send_from_isr_failed: tstamp:13238588326 queue:0x0b4af2d8
kworker/5:1-1613 [005] .... 414.596803: rtos_queue_send_from_isr_failed: tstamp:13238588431 queue:0x0b4b0098
kworker/5:1-1613 [005] .... 414.596804: rtos_queue_send_from_isr_failed: tstamp:13238588549 queue:0x0b4b0e58
kworker/5:1-1613 [005] .... 414.596804: rtos_queue_send_from_isr_failed: tstamp:13238588654 queue:0x0b4b1c18
kworker/5:1-1613 [005] .... 414.596805: rtos_queue_send_failed: tstamp:13238589110 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.652791: rtos_queue_send_from_isr_failed: tstamp:13241007366 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.652794: rtos_queue_send_from_isr_failed: tstamp:13241007493 queue:0x0b4aad68
kworker/5:1-1613 [005] .... 414.652795: rtos_queue_send_from_isr_failed: tstamp:13241007600 queue:0x0b4ac998
kworker/5:1-1613 [005] .... 414.652795: rtos_queue_send_from_isr_failed: tstamp:13241007706 queue:0x0b4ae518
kworker/5:1-1613 [005] .... 414.652796: rtos_queue_send_from_isr_failed: tstamp:13241007810 queue:0x0b4af2d8
kworker/5:1-1613 [005] .... 414.652796: rtos_queue_send_from_isr_failed: tstamp:13241007915 queue:0x0b4b0098
kworker/5:1-1613 [005] .... 414.652797: rtos_queue_send_from_isr_failed: tstamp:13241008020 queue:0x0b4b0e58
kworker/5:1-1613 [005] .... 414.652798: rtos_queue_send_from_isr_failed: tstamp:13241008126 queue:0x0b4b1c18
kworker/5:1-1613 [005] .... 414.652799: rtos_queue_send_failed: tstamp:13241009095 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.708791: rtos_queue_peek_from_isr_failed: tstamp:13241527274 queue:0x0b4b4500
kworker/5:1-1613 [005] .... 414.708796: rtcpu_vinotify_event: tstamp:13242023370 tag:ISPBUF_FS channel:0x00 frame:2 vi_tstamp:13242022564 data:0x00000000
kworker/5:1-1613 [005] .... 414.708796: rtcpu_vinotify_event: tstamp:13242023492 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:13242022820 data:0x00000001
kworker/5:1-1613 [005] .... 414.708797: rtcpu_vinotify_event: tstamp:13242023656 tag:CHANSEL_FAULT channel:0x00 frame:2 vi_tstamp:13242023068 data:0x00000100
kworker/5:1-1613 [005] .... 414.708797: rtcpu_vinotify_event: tstamp:13242024441 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:2 vi_tstamp:13242023791 data:0x08000000
kworker/5:1-1613 [005] .... 414.708798: rtcpu_vinotify_event: tstamp:13242024550 tag:CHANSEL_FAULT_FE channel:0x04 frame:2 vi_tstamp:13242023792 data:0x00000001
kworker/5:1-1613 [005] .... 414.708798: rtcpu_vinotify_event: tstamp:13242024697 tag:ISPBUF_FE channel:0x00 frame:2 vi_tstamp:13242023793 data:0x00000000
kworker/5:1-1613 [005] .... 414.708800: rtos_queue_send_from_isr_failed: tstamp:13242034304 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.708801: rtos_queue_send_from_isr_failed: tstamp:13242034417 queue:0x0b4aad68
kworker/5:1-1613 [005] .... 414.708802: rtos_queue_send_from_isr_failed: tstamp:13242034523 queue:0x0b4ac998
kworker/5:1-1613 [005] .... 414.708802: rtos_queue_send_from_isr_failed: tstamp:13242034631 queue:0x0b4ae518
kworker/5:1-1613 [005] .... 414.708803: rtos_queue_send_from_isr_failed: tstamp:13242034734 queue:0x0b4af2d8
kworker/5:1-1613 [005] .... 414.708803: rtos_queue_send_from_isr_failed: tstamp:13242034838 queue:0x0b4b0098
kworker/5:1-1613 [005] .... 414.708804: rtos_queue_send_from_isr_failed: tstamp:13242034942 queue:0x0b4b0e58
kworker/5:1-1613 [005] .... 414.708805: rtos_queue_send_from_isr_failed: tstamp:13242035057 queue:0x0b4b1c18
kworker/5:1-1613 [005] .... 414.708806: rtos_queue_send_failed: tstamp:13242035599 queue:0x0b4a7258
kworker/5:1-1613 [005] .... 414.876771: rtos_queue_peek_from_isr_failed: tstamp:13246527275 queue:0x0b4b4500
The log show bit 8 of CHANSEL_FAULT, it’s PIXEL_LONG_LINE the the sensor output width may more than expect.
What’s the active_x in device tree and what’s v4l2-ctl --list-formats-ext shows.
kworker/5:1-1613 [005] … 414.708797: rtcpu_vinotify_event: tstamp:13242023656 tag:CHANSEL_FAULT channel:0x00 frame:2 vi_tstamp:13242023068 data:0x00000100
active x is 2608 in dtsi file.
it is v4l2-ctl --list-formats-ext message.
jpchae@jpchae-desktop:~/Downloads$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'BA10'
Name : 10-bit Bayer GRGR/BGBG
Size: Discrete 2608x1960
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.017s (60.000 fps)
- Have confirm if the v4l2-ctl select the same sensor mode.
2 . Does the trace log show the same CHANSEL_FAULT when run the v4l2-ctl to capture.
As your advise , i ran the v4l2-ctl command as shown below.
v4l2-ctl --set-fmt-video-width=1304,height=980, --stream-mmap --stream-count=10 -d /dev/video0 --stream-to=s5k5e8.raw
It is trace log message
I can’t find “CHANSEL_FAULT” error message.
# tracer: nop
# entries-in-buffer/entries-written: 172/172 #P:4
# _-----=> irqs-off
# ||| / delay
v4l2-ctl-8463 [000] .... 187.449766: tegra_channel_open: vi-output, s5k5e8 2-0018
v4l2-ctl-8463 [000] .... 187.450824: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
v4l2-ctl-8463 [000] .... 187.450835: camera_common_s_power: status : 0x1
v4l2-ctl-8463 [000] .... 187.455232: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8463 [000] .... 187.455266: csi_s_power: enable : 0x1
v4l2-ctl-8463 [000] .... 187.461039: tegra_channel_close: vi-output, s5k5e8 2-0018
v4l2-ctl-8463 [000] .... 187.461054: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
v4l2-ctl-8463 [000] .... 187.461062: camera_common_s_power: status : 0x0
v4l2-ctl-8463 [003] .... 187.463405: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8463 [003] .... 187.463412: csi_s_power: enable : 0x0
v4l2-ctl-8493 [005] .... 260.800539: tegra_channel_open: vi-output, s5k5e8 2-0018
v4l2-ctl-8493 [004] .... 260.807372: tegra_channel_set_power: s5k5e8 2-0018 : 0x1
v4l2-ctl-8493 [004] .... 260.807406: camera_common_s_power: status : 0x1
v4l2-ctl-8493 [004] .... 260.812040: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8493 [004] .... 260.812048: csi_s_power: enable : 0x1
v4l2-ctl-8493 [000] .... 260.831145: tegra_channel_capture_setup: vnc_id 0 W 1304 H 980 fmt 20
vi-output, s5k5-8494 [005] .... 260.831355: tegra_channel_set_stream: enable : 0x1
vi-output, s5k5-8494 [005] .... 260.835567: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, s5k5-8494 [005] .... 260.835571: csi_s_stream: enable : 0x1
vi-output, s5k5-8494 [005] .... 260.835599: tegra_channel_set_stream: s5k5e8 2-0018 : 0x1
kworker/3:1-1218 [003] .... 260.877940: rtos_queue_peek_from_isr_failed: tstamp:8434239168 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 260.877946: rtcpu_start: tstamp:8434243115
kworker/3:1-1218 [003] .... 260.877949: rtos_queue_send_from_isr_failed: tstamp:8434307169 queue:0x0b4a7258
kworker/3:1-1218 [003] .... 260.877950: rtos_queue_send_from_isr_failed: tstamp:8434307313 queue:0x0b4aad68
kworker/3:1-1218 [003] .... 260.877951: rtos_queue_send_from_isr_failed: tstamp:8434307451 queue:0x0b4ac998
kworker/3:1-1218 [003] .... 260.877952: rtos_queue_send_from_isr_failed: tstamp:8434307591 queue:0x0b4ae518
kworker/3:1-1218 [003] .... 260.877953: rtos_queue_send_from_isr_failed: tstamp:8434307730 queue:0x0b4af2d8
kworker/3:1-1218 [003] .... 260.877954: rtos_queue_send_from_isr_failed: tstamp:8434307866 queue:0x0b4b0098
kworker/3:1-1218 [003] .... 260.877955: rtos_queue_send_from_isr_failed: tstamp:8434308004 queue:0x0b4b0e58
kworker/3:1-1218 [003] .... 260.877957: rtos_queue_send_from_isr_failed: tstamp:8434308147 queue:0x0b4b1c18
kworker/3:1-1218 [003] .... 260.877959: rtos_queue_send_failed: tstamp:8434308769 queue:0x0b4a7258
kworker/3:1-1218 [003] .... 260.877960: rtos_queue_send_from_isr_failed: tstamp:8434311506 queue:0x0b4a7258
kworker/3:1-1218 [003] .... 260.877961: rtos_queue_send_from_isr_failed: tstamp:8434311646 queue:0x0b4aad68
kworker/3:1-1218 [003] .... 260.877962: rtos_queue_send_from_isr_failed: tstamp:8434311785 queue:0x0b4ac998
kworker/3:1-1218 [003] .... 260.877963: rtos_queue_send_from_isr_failed: tstamp:8434311927 queue:0x0b4ae518
kworker/3:1-1218 [003] .... 260.877964: rtos_queue_send_from_isr_failed: tstamp:8434312066 queue:0x0b4af2d8
kworker/3:1-1218 [003] .... 260.877965: rtos_queue_send_from_isr_failed: tstamp:8434312210 queue:0x0b4b0098
kworker/3:1-1218 [003] .... 260.877966: rtos_queue_send_from_isr_failed: tstamp:8434312349 queue:0x0b4b0e58
kworker/3:1-1218 [003] .... 260.877967: rtos_queue_send_from_isr_failed: tstamp:8434312486 queue:0x0b4b1c18
kworker/3:1-1218 [003] .... 260.877968: rtos_queue_send_failed: tstamp:8434313930 queue:0x0b4a7258
vi-output, s5k5-8494 [004] .... 260.905263: tegra_channel_capture_frame: sof:260.795298341
kworker/3:1-1218 [003] .... 260.934022: rtcpu_vinotify_event: tstamp:8436629845 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:8436629306 data:0x00000001
kworker/3:1-1218 [003] .... 260.934030: rtcpu_vinotify_event: tstamp:8436630058 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:8436629312 data:0x00000000
kworker/3:1-1218 [003] .... 260.934033: rtcpu_vinotify_event: tstamp:8436632672 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:1 vi_tstamp:8436632285 data:0x08000000
kworker/3:1-1218 [003] .... 260.934035: rtcpu_vinotify_event: tstamp:8437144216 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:8437143523 data:0x03d30002
kworker/3:1-1218 [003] .... 260.934037: rtcpu_vinotify_event: tstamp:8437144368 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:8437143549 data:0x00000000
vi-output, s5k5-8494 [004] .... 260.939467: tegra_channel_capture_frame: sof:260.829469541
vi-output, s5k5-8494 [004] .... 260.973764: tegra_channel_capture_frame: sof:260.863640837
kworker/3:1-1218 [003] .... 260.989965: rtcpu_vinotify_event: tstamp:8437697703 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:8437697156 data:0x00000001
kworker/3:1-1218 [003] .... 260.989968: rtcpu_vinotify_event: tstamp:8437697916 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:8437697164 data:0x00000000
kworker/3:1-1218 [003] .... 260.989969: rtcpu_vinotify_event: tstamp:8437701589 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:2 vi_tstamp:8437701205 data:0x08000000
kworker/3:1-1218 [003] .... 260.989970: rtcpu_vinotify_event: tstamp:8438212067 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:8438211375 data:0x03d30002
kworker/3:1-1218 [003] .... 260.989971: rtcpu_vinotify_event: tstamp:8438212220 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:8438211401 data:0x00000000
kworker/3:1-1218 [003] .... 260.989972: rtcpu_vinotify_event: tstamp:8438765534 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:8438765009 data:0x00000001
kworker/3:1-1218 [003] .... 260.989973: rtcpu_vinotify_event: tstamp:8438765744 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:8438765015 data:0x00000000
kworker/3:1-1218 [003] .... 260.989974: rtcpu_vinotify_event: tstamp:8438773482 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:3 vi_tstamp:8438773099 data:0x08000000
kworker/3:1-1218 [003] .... 260.989978: rtos_queue_peek_from_isr_failed: tstamp:8439239519 queue:0x0b4b4500
vi-output, s5k5-8494 [004] .... 261.007820: tegra_channel_capture_frame: sof:260.897812101
vi-output, s5k5-8494 [003] .... 261.042030: tegra_channel_capture_frame: sof:260.931983333
kworker/3:1-1218 [003] .... 261.046081: rtcpu_vinotify_event: tstamp:8439279917 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:8439279226 data:0x03d30002
kworker/3:1-1218 [003] .... 261.046086: rtcpu_vinotify_event: tstamp:8439280070 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:8439279252 data:0x00000000
kworker/3:1-1218 [003] .... 261.046088: rtcpu_vinotify_event: tstamp:8439833386 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:8439832861 data:0x00000001
kworker/3:1-1218 [003] .... 261.046090: rtcpu_vinotify_event: tstamp:8439833601 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:8439832866 data:0x00000000
kworker/3:1-1218 [003] .... 261.046091: rtcpu_vinotify_event: tstamp:8439837713 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:4 vi_tstamp:8439837325 data:0x08000000
kworker/3:1-1218 [003] .... 261.046093: rtcpu_vinotify_event: tstamp:8440347743 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:8440347078 data:0x03d30002
kworker/3:1-1218 [003] .... 261.046094: rtcpu_vinotify_event: tstamp:8440347864 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:8440347103 data:0x00000000
kworker/3:1-1218 [003] .... 261.046096: rtcpu_vinotify_event: tstamp:8440901257 tag:CHANSEL_PXL_SOF channel:0x00 frame:5 vi_tstamp:8440900712 data:0x00000001
kworker/3:1-1218 [003] .... 261.046097: rtcpu_vinotify_event: tstamp:8440901468 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:8440900718 data:0x00000000
kworker/3:1-1218 [003] .... 261.046099: rtcpu_vinotify_event: tstamp:8440906908 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:5 vi_tstamp:8440906528 data:0x08000000
vi-output, s5k5-8494 [005] .... 261.076148: tegra_channel_capture_frame: sof:260.966154597
kworker/3:1-1218 [003] .... 261.101976: rtcpu_vinotify_event: tstamp:8441415598 tag:CHANSEL_PXL_EOF channel:0x00 frame:5 vi_tstamp:8441414929 data:0x03d30002
kworker/3:1-1218 [003] .... 261.101982: rtcpu_vinotify_event: tstamp:8441415714 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:8441414954 data:0x00000000
kworker/3:1-1218 [003] .... 261.101983: rtcpu_vinotify_event: tstamp:8441969100 tag:CHANSEL_PXL_SOF channel:0x00 frame:6 vi_tstamp:8441968564 data:0x00000001
kworker/3:1-1218 [003] .... 261.101985: rtcpu_vinotify_event: tstamp:8441969336 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:8441968569 data:0x00000000
kworker/3:1-1218 [003] .... 261.101986: rtcpu_vinotify_event: tstamp:8441972964 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:6 vi_tstamp:8441972580 data:0x08000000
kworker/3:1-1218 [003] .... 261.101987: rtcpu_vinotify_event: tstamp:8442483448 tag:CHANSEL_PXL_EOF channel:0x00 frame:6 vi_tstamp:8442482780 data:0x03d30002
kworker/3:1-1218 [003] .... 261.101989: rtcpu_vinotify_event: tstamp:8442483563 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:8442482806 data:0x00000000
vi-output, s5k5-8494 [003] .... 261.110373: tegra_channel_capture_frame: sof:261.325797
vi-output, s5k5-8494 [000] .... 261.144482: tegra_channel_capture_frame: sof:261.34497061
kworker/3:1-1218 [003] .... 261.157935: rtcpu_vinotify_event: tstamp:8443036943 tag:CHANSEL_PXL_SOF channel:0x00 frame:7 vi_tstamp:8443036414 data:0x00000001
kworker/3:1-1218 [003] .... 261.157938: rtcpu_vinotify_event: tstamp:8443037152 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:8443036421 data:0x00000000
kworker/3:1-1218 [003] .... 261.157938: rtcpu_vinotify_event: tstamp:8443042448 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:7 vi_tstamp:8443042067 data:0x08000000
kworker/3:1-1218 [003] .... 261.157939: rtcpu_vinotify_event: tstamp:8443551304 tag:CHANSEL_PXL_EOF channel:0x00 frame:7 vi_tstamp:8443550632 data:0x03d30002
kworker/3:1-1218 [003] .... 261.157939: rtcpu_vinotify_event: tstamp:8443551426 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:8443550659 data:0x00000000
kworker/3:1-1218 [003] .... 261.157940: rtcpu_vinotify_event: tstamp:8444104791 tag:CHANSEL_PXL_SOF channel:0x00 frame:8 vi_tstamp:8444104266 data:0x00000001
kworker/3:1-1218 [003] .... 261.157940: rtcpu_vinotify_event: tstamp:8444105013 tag:ATOMP_FS channel:0x00 frame:8 vi_tstamp:8444104272 data:0x00000000
kworker/3:1-1218 [003] .... 261.157941: rtcpu_vinotify_event: tstamp:8444108384 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:8 vi_tstamp:8444108000 data:0x08000000
kworker/3:1-1218 [003] .... 261.157943: rtos_queue_peek_from_isr_failed: tstamp:8444239525 queue:0x0b4b4500
vi-output, s5k5-8494 [003] .... 261.178713: tegra_channel_capture_frame: sof:261.68668325
vi-output, s5k5-8494 [000] .... 261.212905: tegra_channel_capture_frame: sof:261.102839557
kworker/3:1-1218 [003] .... 261.213997: rtcpu_vinotify_event: tstamp:8444619153 tag:CHANSEL_PXL_EOF channel:0x00 frame:8 vi_tstamp:8444618483 data:0x03d30002
kworker/3:1-1218 [003] .... 261.214002: rtcpu_vinotify_event: tstamp:8444619278 tag:ATOMP_FE channel:0x00 frame:8 vi_tstamp:8444618509 data:0x00000000
kworker/3:1-1218 [003] .... 261.214003: rtcpu_vinotify_event: tstamp:8445172643 tag:CHANSEL_PXL_SOF channel:0x00 frame:9 vi_tstamp:8445172118 data:0x00000001
kworker/3:1-1218 [003] .... 261.214004: rtcpu_vinotify_event: tstamp:8445172853 tag:ATOMP_FS channel:0x00 frame:9 vi_tstamp:8445172123 data:0x00000000
kworker/3:1-1218 [003] .... 261.214005: rtcpu_vinotify_event: tstamp:8445178072 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:9 vi_tstamp:8445177691 data:0x08000000
kworker/3:1-1218 [003] .... 261.214007: rtcpu_vinotify_event: tstamp:8445687009 tag:CHANSEL_PXL_EOF channel:0x00 frame:9 vi_tstamp:8445686335 data:0x03d30002
kworker/3:1-1218 [003] .... 261.214008: rtcpu_vinotify_event: tstamp:8445687132 tag:ATOMP_FE channel:0x00 frame:9 vi_tstamp:8445686361 data:0x00000000
kworker/3:1-1218 [003] .... 261.214009: rtcpu_vinotify_event: tstamp:8446240496 tag:CHANSEL_PXL_SOF channel:0x00 frame:10 vi_tstamp:8446239969 data:0x00000001
kworker/3:1-1218 [003] .... 261.214010: rtcpu_vinotify_event: tstamp:8446240707 tag:ATOMP_FS channel:0x00 frame:10 vi_tstamp:8446239976 data:0x00000000
kworker/3:1-1218 [003] .... 261.214011: rtcpu_vinotify_event: tstamp:8446246612 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:10 vi_tstamp:8446246222 data:0x08000000
vi-output, s5k5-8494 [005] .... 261.247026: tegra_channel_capture_frame: sof:261.137010789
kworker/3:1-1218 [003] .... 261.269990: rtcpu_vinotify_event: tstamp:8446754859 tag:CHANSEL_PXL_EOF channel:0x00 frame:10 vi_tstamp:8446754186 data:0x03d30002
kworker/3:1-1218 [003] .... 261.269996: rtcpu_vinotify_event: tstamp:8446754984 tag:ATOMP_FE channel:0x00 frame:10 vi_tstamp:8446754212 data:0x00000000
kworker/3:1-1218 [003] .... 261.269997: rtcpu_vinotify_event: tstamp:8447308345 tag:CHANSEL_PXL_SOF channel:0x00 frame:11 vi_tstamp:8447307820 data:0x00000001
kworker/3:1-1218 [003] .... 261.269999: rtcpu_vinotify_event: tstamp:8447308558 tag:ATOMP_FS channel:0x00 frame:11 vi_tstamp:8447307827 data:0x00000000
kworker/3:1-1218 [003] .... 261.270001: rtcpu_vinotify_event: tstamp:8447312878 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:11 vi_tstamp:8447312488 data:0x08000000
kworker/3:1-1218 [003] .... 261.270002: rtcpu_vinotify_event: tstamp:8447822710 tag:CHANSEL_PXL_EOF channel:0x00 frame:11 vi_tstamp:8447822037 data:0x03d30002
kworker/3:1-1218 [003] .... 261.270003: rtcpu_vinotify_event: tstamp:8447822832 tag:ATOMP_FE channel:0x00 frame:11 vi_tstamp:8447822064 data:0x00000000
vi-output, s5k5-8494 [003] .... 261.281192: tegra_channel_capture_frame: sof:261.171182021
vi-output, s5k5-8494 [004] .... 261.315358: tegra_channel_capture_frame: sof:261.205353285
kworker/3:1-1218 [003] .... 261.325994: rtcpu_vinotify_event: tstamp:8448376198 tag:CHANSEL_PXL_SOF channel:0x00 frame:12 vi_tstamp:8448375671 data:0x00000001
kworker/3:1-1218 [003] .... 261.326000: rtcpu_vinotify_event: tstamp:8448376408 tag:ATOMP_FS channel:0x00 frame:12 vi_tstamp:8448375678 data:0x00000000
kworker/3:1-1218 [003] .... 261.326001: rtcpu_vinotify_event: tstamp:8448380543 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:12 vi_tstamp:8448380161 data:0x08000000
kworker/3:1-1218 [003] .... 261.326003: rtcpu_vinotify_event: tstamp:8448890560 tag:CHANSEL_PXL_EOF channel:0x00 frame:12 vi_tstamp:8448889890 data:0x03d30002
kworker/3:1-1218 [003] .... 261.326004: rtcpu_vinotify_event: tstamp:8448890682 tag:ATOMP_FE channel:0x00 frame:12 vi_tstamp:8448889916 data:0x00000000
kworker/3:1-1218 [003] .... 261.326009: rtos_queue_peek_from_isr_failed: tstamp:8449239532 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 261.326011: rtcpu_vinotify_event: tstamp:8449444047 tag:CHANSEL_PXL_SOF channel:0x00 frame:13 vi_tstamp:8449443523 data:0x00000001
kworker/3:1-1218 [003] .... 261.326012: rtcpu_vinotify_event: tstamp:8449444257 tag:ATOMP_FS channel:0x00 frame:13 vi_tstamp:8449443529 data:0x00000000
kworker/3:1-1218 [003] .... 261.326014: rtcpu_vinotify_event: tstamp:8449451723 tag:CHANSEL_LOAD_FRAMED channel:0x04 frame:13 vi_tstamp:8449451342 data:0x08000000
v4l2-ctl-8493 [004] .... 261.366004: tegra_channel_capture_done: eof:261.255980325
v4l2-ctl-8493 [000] .... 261.366458: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-8493 [000] .... 261.366463: tegra_channel_set_stream: s5k5e8 2-0018 : 0x0
kworker/3:1-1218 [003] .... 261.382000: rtcpu_vinotify_event: tstamp:8449958431 tag:CHANSEL_PXL_EOF channel:0x00 frame:13 vi_tstamp:8449957739 data:0x03d30002
kworker/3:1-1218 [003] .... 261.382007: rtcpu_vinotify_event: tstamp:8449958583 tag:ATOMP_FE channel:0x00 frame:13 vi_tstamp:8449957766 data:0x00000000
kworker/3:1-1218 [003] .... 261.382009: rtcpu_vinotify_event: tstamp:8450511900 tag:CHANSEL_PXL_SOF channel:0x00 frame:14 vi_tstamp:8450511375 data:0x00000001
kworker/3:1-1218 [003] .... 261.382012: rtcpu_vinotify_event: tstamp:8450512119 tag:ATOMP_FS channel:0x00 frame:14 vi_tstamp:8450511381 data:0x00000000
kworker/3:1-1218 [003] .... 261.382014: rtcpu_vinotify_event: tstamp:8451026274 tag:CHANSEL_PXL_EOF channel:0x00 frame:14 vi_tstamp:8451025593 data:0x03d30002
kworker/3:1-1218 [003] .... 261.382016: rtcpu_vinotify_event: tstamp:8451026427 tag:ATOMP_FE channel:0x00 frame:14 vi_tstamp:8451025618 data:0x00000000
kworker/3:1-1218 [003] .... 261.382022: rtos_queue_send_from_isr_failed: tstamp:8451031151 queue:0x0b4a7258
kworker/3:1-1218 [003] .... 261.382026: rtos_queue_send_from_isr_failed: tstamp:8451031295 queue:0x0b4aad68
kworker/3:1-1218 [003] .... 261.382029: rtos_queue_send_from_isr_failed: tstamp:8451031439 queue:0x0b4ac998
kworker/3:1-1218 [003] .... 261.382031: rtos_queue_send_from_isr_failed: tstamp:8451031580 queue:0x0b4ae518
kworker/3:1-1218 [003] .... 261.382034: rtos_queue_send_from_isr_failed: tstamp:8451031717 queue:0x0b4af2d8
kworker/3:1-1218 [003] .... 261.382039: rtos_queue_send_from_isr_failed: tstamp:8451031860 queue:0x0b4b0098
kworker/3:1-1218 [003] .... 261.382042: rtos_queue_send_from_isr_failed: tstamp:8451031999 queue:0x0b4b0e58
kworker/3:1-1218 [003] .... 261.382045: rtos_queue_send_from_isr_failed: tstamp:8451032143 queue:0x0b4b1c18
kworker/3:1-1218 [003] .... 261.382051: rtos_queue_send_failed: tstamp:8451032917 queue:0x0b4a7258
kworker/3:1-1218 [003] .... 261.382054: rtos_queue_send_from_isr_failed: tstamp:8451037417 queue:0x0b4a7258
kworker/3:1-1218 [003] .... 261.382057: rtos_queue_send_from_isr_failed: tstamp:8451037558 queue:0x0b4aad68
kworker/3:1-1218 [003] .... 261.382059: rtos_queue_send_from_isr_failed: tstamp:8451037696 queue:0x0b4ac998
kworker/3:1-1218 [003] .... 261.382061: rtos_queue_send_from_isr_failed: tstamp:8451037836 queue:0x0b4ae518
kworker/3:1-1218 [003] .... 261.382064: rtos_queue_send_from_isr_failed: tstamp:8451037980 queue:0x0b4af2d8
kworker/3:1-1218 [003] .... 261.382066: rtos_queue_send_from_isr_failed: tstamp:8451038118 queue:0x0b4b0098
kworker/3:1-1218 [003] .... 261.382068: rtos_queue_send_from_isr_failed: tstamp:8451038254 queue:0x0b4b0e58
kworker/3:1-1218 [003] .... 261.382071: rtos_queue_send_from_isr_failed: tstamp:8451038391 queue:0x0b4b1c18
kworker/3:1-1218 [003] .... 261.382073: rtos_queue_send_failed: tstamp:8451038972 queue:0x0b4a7258
v4l2-ctl-8493 [003] .... 261.451473: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8493 [003] .... 261.451485: csi_s_stream: enable : 0x0
v4l2-ctl-8493 [000] .... 261.473329: tegra_channel_close: vi-output, s5k5e8 2-0018
v4l2-ctl-8493 [000] .... 261.474212: tegra_channel_set_power: s5k5e8 2-0018 : 0x0
v4l2-ctl-8493 [000] .... 261.474222: camera_common_s_power: status : 0x0
v4l2-ctl-8493 [000] .... 261.476331: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8493 [000] .... 261.476334: csi_s_power: enable : 0x0
kworker/3:1-1218 [003] .... 261.493917: rtos_queue_peek_from_isr_failed: tstamp:8454239579 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 261.662121: rtos_queue_peek_from_isr_failed: tstamp:8459239582 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 261.830023: rtos_queue_peek_from_isr_failed: tstamp:8464239596 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 261.997983: rtos_queue_peek_from_isr_failed: tstamp:8469239565 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 262.110088: rtos_queue_peek_from_isr_failed: tstamp:8474239577 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 262.277985: rtos_queue_peek_from_isr_failed: tstamp:8479239611 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 262.445995: rtos_queue_peek_from_isr_failed: tstamp:8484239590 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 262.613951: rtos_queue_peek_from_isr_failed: tstamp:8489239579 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 262.782039: rtos_queue_peek_from_isr_failed: tstamp:8494239607 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 262.950028: rtos_queue_peek_from_isr_failed: tstamp:8499239638 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 263.122027: rtos_queue_peek_from_isr_failed: tstamp:8504239619 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 263.234054: rtos_queue_peek_from_isr_failed: tstamp:8509239626 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 263.402023: rtos_queue_peek_from_isr_failed: tstamp:8514239631 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 263.570028: rtos_queue_peek_from_isr_failed: tstamp:8519239627 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 263.738036: rtos_queue_peek_from_isr_failed: tstamp:8524239636 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 263.905986: rtos_queue_peek_from_isr_failed: tstamp:8529239677 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 264.074040: rtos_queue_peek_from_isr_failed: tstamp:8534239650 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 264.242075: rtos_queue_peek_from_isr_failed: tstamp:8539239666 queue:0x0b4b4500
kworker/3:1-1218 [003] .... 264.354057: rtos_queue_peek_from_isr_failed: tstamp:8544239662 queue:0x0b4b4500
