I am testing deepstream-test1 app. The program stops at
0:00:03.495019878 15326 0x2016bf90 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/numplate/resnet_18_fp16.etlt_b1_gpu0_fp16.engine
0:00:03.499872786 15326 0x2016bf90 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
My config file is
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=NHRvZzAwbHFncTk0MXJ0YmwwbXB1bGxhbnU6MjYzNzc2MDctYzQ5MC00NjkxLThkODAtODM0NDc3ZTRhNTNh
tlt-encoded-model=../../../../samples/models/numplate/resnet_18_fp16.etlt
labelfile-path=../../../../samples/models/numplate/labels.txt
model-engine-file=../../../../samples/models/numplate/resnet_18_fp16.etlt_b1_gpu0_fp16.engine
input-dims=3;720;720;0
batch-size=1
model-color-format=0
uff-input-blob-name=input_1
process-mode=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=2
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
Tested both mov file and mp4 file, both have issue.
Is “resnet_18_fp16.etlt_b1_gpu0_fp16.engine” generated successfully?
And can you provide more log? There is no error in the log you provided.
Can you also provide the environment information? Refer to the following format:
• Hardware Platform (jetson xavier nx devkit)
• DeepStream Version
• TensorRT Version
Yes engine is generated successfully.
AGX Xavier. Deepstream 5.0. Jetpack 4.4.
TensorRT 7.1.
The followings are the only log I have and stuck there.
xavier@xavier-desktop:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1$ python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
Opening in BLOCKING MODE
0:00:05.718812517 9154 0x3ecc5f90 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/numplate/resnet_18_fp16.etlt_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x720x720
1 OUTPUT kFLOAT output_bbox/BiasAdd 8x45x45
2 OUTPUT kFLOAT output_cov/Sigmoid 2x45x45
0:00:05.719055633 9154 0x3ecc5f90 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/numplate/resnet_18_fp16.etlt_b1_gpu0_fp16.engine
0:00:05.734272487 9154 0x3ecc5f90 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
@edit_or
You can open more GST logs using this command:
export GST_DEBUG=3
And then run this python program again.
The log may be like this:
0:00:03.061754869 17986 0x2cf9a0f0 WARN codecparsers_h264 gsth264parser.c:2092:gst_h264_parser_parse_slice_hdr: couldn't find associated picture parameter set with id: 0
0:00:03.061816056 17986 0x2cf9a0f0 WARN codecparsers_h264 gsth264parser.c:2092:gst_h264_parser_parse_slice_hdr: couldn't find associated picture parameter set with id: 0
0:00:03.061841529 17986 0x2cf9a0f0 WARN codecparsers_h264 gsth264parser.c:2092:gst_h264_parser_parse_slice_hdr: couldn't find associated picture parameter set with id: 227
It seems the pipeline defined by this python file does not support codec of .mp4
format.
Try to use .h264
format.
I was facing the same and your solution works. But then how can i process .mp4 videos with it?
Thanks in advance
kayccc
September 21, 2020, 1:17pm
10
Hi shubham.shan09,
Please help to open a new topic for your issue. Thanks
