declaration and fonction to access texture in kernel and main :
texture<float, 2, cudaReadModeElementType> dataTest_tex;
texture<float, 2, cudaReadModeElementType> &getTexture() { return dataTest_tex; }
static __inline__ __device__ texture<float, 2, cudaReadModeElementType> &getDeviceTexture() { return dataTest_tex; }
Kernel using the texture :
__global__ void bilinear(float *d_out, int dimIn, int dimOut, float ax, float ay, float bx, float by, float cx, float cy) {
int ix = IMUL(blockDim.x, blockIdx.x) + threadIdx.x;
int iy = IMUL(blockDim.y, blockIdx.y) + threadIdx.y;
float xp = ax*ix + bx*iy + cx;
float yp = ay*ix + by*iy + cy;
int w1 = int(xp);
int h1 = int(yp);
d_out[iy*dimOut + ix] = tex2D(getDeviceTexture(), w1, h1);
Kernel call :
dim3 blockSizeEXT(16,16);
dim3 gridSizeEXT(512/16,512/16);
bilinear<<< gridSizeEXT, blockSizeEXT >>>(d_DataTemp, SIZE_TEST, SIZE_REF, tabParam[i].ax, tabParam[i].ay, tabParam[i].bx, tabParam[i].by, tabParam[i].cx, tabParam[i].cy);
I use a cudaArray to bind texture with datas :
float *h_DataTest; // <= datas are read from raw file
cudaArray *d_dataTest;
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float>();
cudaMallocArray( &d_dataTest, &channelDesc, SIZE_TEST, SIZE_TEST );
cudaMemcpyToArray( d_dataTest, 0, 0, (void*)h_DataTest, test_size, cudaMemcpyHostToDevice);
texture<float, 2, cudaReadModeElementType> &myTexture = getTexture();
myTexture.filterMode = cudaFilterModeLinear;
myTexture.normalized = false;
cudaBindTextureToArray( myTexture, d_dataTest, channelDesc);
I am sure there is no negative value in *h_DataTest but I do not know if the datas can be modified when I copy them.
ps : sorry for my bad english.
