Sorry for digging this up, but I have problems with compiling a program using tex2DLayeredLod and texture references (the sample uses texture objects).
The compiler tells me:
ptxas fatal : Unresolved extern function '__utexfetchlodl2D'
this is how i call tex2DLayeredLod
texture<uchar4, cudaTextureType2DLayered, cudaReadModeNormalizedFloat> textureReference;
tex2DLayeredLod(textureReference, u, v, textureLayerIndex, 0)
I looked into texture_fetch_functions.h
template<class T, int texType, enum cudaTextureReadMode readMode> extern __device__ __device_builtin__ uint4 __utexfetchlodl(texture<T, texType, readMode> t, float4 i, int l, float level, int d = (texType & 0xF));
static __forceinline__ __device__ float4 tex2DLayeredLod(texture<float4, cudaTextureType2DLayered, cudaReadModeElementType> t, float x, float y, int layer, float level) {
float4 v = __ftexfetchlodl(t, make_float4(x, y, 0, 0), layer, level);
return make_float4(v.x, v.y, v.z, v.w);
extern uint4 __utexfetchlodl2D(unsigned long long, float4, int, float);
I’ve googled for the error message, but nothing is shown. But when googling only for “ptxas fatal : Unresolved extern function”, there are a lot of hits about a missing nvcc option for dynamic parallelism.
So my theory is, that I’m missing this option and that it is secret :) Is this correct and could you reveal that option? Or is it something else?
I have Cuda 6.5, Win7 and a Gf GTX550Ti (CC 2.1)
