I have a tf pb file, and I have found many convert issues, and remove ‘_ResizeBilinear’, ‘_BatchToSpaceND’ and ‘_SpaceToBatchND’, but got below issue:
xhz@xhz-omen:tf_to_trt_image_classification$ python scripts/convert_plan.py /home/xhz/Projects/models/xw_model/new/LsGan_model_test.pb /home/xhz/Projects/models/xw_model/LsGan_model.pb.plan input_img 360 640 sigmoid_logits 1 0 float
Using output node sigmoid_logits
Converting to UFF graph
WARNING: The UFF converter currently only supports 2D dilated convolutions
No. nodes: 570
UFF Output written to data/tmp.uff
UFFParser: parsing input_img
UFFParser: parsing res_aspp_g/decoder/resnet/conv1/weights
UFFParser: parsing res_aspp_g/decoder/resnet/conv1/conv1
UFFParser: Convolution: add Padding Layer to support asymmetric padding
UFFParser: Convolution: Left: 2
UFFParser: Convolution: Right: 3
UFFParser: Convolution: Top: 2
UFFParser: Convolution: Bottom: 3
UFFParser: parsing res_aspp_g/decoder/resnet/bn_conv1/BatchNorm/Const
UFFParser: parsing res_aspp_g/decoder/resnet/bn_conv1/BatchNorm/beta
UFFParser: parsing res_aspp_g/decoder/resnet/bn_conv1/BatchNorm/Const_1
UFFParser: parsing res_aspp_g/decoder/resnet/bn_conv1/BatchNorm/Const_2
UFFParser: parsing res_aspp_g/decoder/resnet/bn_conv1/BatchNorm/FusedBatchNorm
Parameter check failed at: Utils.cpp::reshapeWeights::71, condition: input.values != nullptr
UFFParser: Parser error: res_aspp_g/decoder/resnet/bn_conv1/BatchNorm/FusedBatchNorm: reshape weights failed!
Failed to parse UFF
so i remove layer ‘FusedBatchNorm’, so got below issue:
UFFParser: parsing res_aspp_g/decoder/resnet/res4b3_branch2a/weights
UFFParser: parsing res_aspp_g/decoder/resnet/res4b3_branch2a/Conv2D
res_aspp_g/decoder/resnet/res4b1_branch2b/convolution: at least three non-batch dimensions are required for input
UFFParser: parsing res_aspp_g/decoder/resnet/res4b3_branch2a/Relu
UFFParser: parsing res_aspp_g/decoder/resnet/res4b3_branch2b/weights
UFFParser: parsing res_aspp_g/decoder/resnet/res4b3_branch2b/convolution
UFFParser: parsing res_aspp_g/decoder/resnet/res4b3_branch2b/Relu
UFFParser: parsing res_aspp_g/decoder/resnet/conv/weights
UFFParser: parsing res_aspp_g/decoder/resnet/conv/Conv2D
res_aspp_g/decoder/resnet/res4b1_branch2b/Relu: at least one non-batch dimension is required for input
UFFParser: parsing res_aspp_g/decoder/resnet/conv/biases
UFFParser: parsing res_aspp_g/decoder/resnet/conv/BiasAdd
res_aspp_g/decoder/resnet/res4b1_branch2c/Conv2D: at least three non-batch dimensions are required for input
UFFParser: Parser error: res_aspp_g/decoder/resnet/conv/BiasAdd: The input to the Scale Layer is required to have a minimum of 3 dimensions.
Failed to parse UFF
