Trying to convert my model to run on Jetson TX2…
I built my tensorflow model in NCHW (which runs fine on TF) like this:
The Input of data is (448,576)
self.feed('data')
conv2d(kernel_h=3, kernel_w=3, 32, stride_h=2,stride_w= 2, biased=False, padding='SAME', relu=False, name='conv1_1_3x3_s2')# 1/2
batch_normalization(relu=True, name='conv1_1_3x3_s2_bn')
conv2d(kernel_h=3, kernel_w=3, 32, stride_h=1, stride_w=1, biased=False, padding='SAME', relu=False, name='conv1_2_3x3')
batch_normalization(relu=True, name='conv1_2_3x3_bn')
Then I follow the steps to convert it to TRT:
output_graph_def = tf.graph_util.convert_variables_to_constants(
self.sess,
tf.get_default_graph().as_graph_def(),
self.output_layers)
frozen = tf.graph_util.remove_training_nodes(output_graph_def)
uff_model = uff.from_tensorflow(frozen, self.output_layers)
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.INFO)
MAX_WORKSPACE = 1 << 30
parser = uffparser.create_uff_parser()
parser.register_input("x_placeholder", (1,448,576), 0)
parser.register_input("y_placeholder", (1,448,576), 0)
parser.register_output("output_layer_name")
engine = trt.utils.uff_to_trt_engine(G_LOGGER,
uff_model,
parser,
1,
MAX_WORKSPACE, datatype=trt.infer.DataType.FLOAT)
assert (engine)
The uff parsing passes fine:
Converting to UFF graph
No. nodes: 548
but transformig to TRT gets the following error:
[TensorRT] INFO: UFFParser: parsing output_layer_name
[TensorRT] INFO: UFFParser: parsing x_placeholder
[TensorRT] INFO: UFFParser: parsing y_placeholder
[TensorRT] INFO: UFFParser: parsing concat
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2/weights
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2/Conv2D
[TensorRT] INFO: UFFParser: Convolution: add Padding Layer to support asymmetric padding
[TensorRT] INFO: UFFParser: Convolution: Left: 0
[TensorRT] INFO: UFFParser: Convolution: Right: 1
[TensorRT] INFO: UFFParser: Convolution: Top: 0
[TensorRT] INFO: UFFParser: Convolution: Bottom: 1
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2_bn/gamma
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2_bn/beta
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2_bn/moving_mean
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2_bn/moving_variance
[TensorRT] INFO: UFFParser: parsing conv1_1_3x3_s2_bn/FusedBatchNorm
[TensorRT] ERROR: UFFParser: Parser error: conv1_1_3x3_s2_bn/FusedBatchNorm: Invalid scale mode, nbWeights: 288
[TensorRT] ERROR: Failed to parse UFF model stream
Does TensorRT support batch norm? what is Invalid scale mode, nbWeights: 288?
Why 288 which is half of width input?
I’m using TensorRT 4, cuda 9 and Cudnn 7.1.3
