AttributeError: 'NoneType' object has no attribute 'serialize'
Description
[TensorRT] ERROR: UFFParser: Validator error: FeatureExtractor/MobilenetV2/layer_19_2_Conv2d_5_3x3_s2_128_depthwise/BatchNorm/FusedBatchNormV3: Unsupported operation _FusedBatchNormV3
[TensorRT] ERROR: Network must have at least one output
File “main.py”, line 44, in
buf = engine.serialize()
AttributeError: ‘NoneType’ object has no attribute ‘serialize’
Environment
TensorRT Version: 5.0.6.3
GPU Type: Jetson TX2
Nvidia Driver Version: x
CUDA Version: 10.0
CUDNN Version: 7.3.1
Operating System + Version: Jetpack 4.2 + ubuntu 18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.14.0
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
How to solve it?
FusedBatchNormV3 operation is currently not supported by UFF parser.
You can try to convert your model to ONNX instead of UFF using tf2onnx:
tf2onnx supports converting this op to BatchNormalization op in ONNX:
And BatchNormalization op is supported by the TensorRT ONNX parser:
https://github.com/onnx/onnx-tensorrt/blob/master/operators.md
I will also recommend you to use latest TRT version.
Is it working on jetson tx2 and jetpack 4.2?
