Description
A clear and concise description of the bug or issue.
Environment
TensorRT Version: 7.1.3
GPU Type: AGX Xavier
Nvidia Driver Version: JETPACK 4.5
CUDA Version: 10.2
CUDNN Version: 8.0
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 2.4.0
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
trtnew.py (997 Bytes)
saved_model
Steps To Reproduce
I was trying using tf-trt to generate trt engine on Xavier. The trtnew.py was run by python3 trtnew.py. Then, I got the following message. I didn’t find the TensorRT engine generated in my output directory ‘my_model/converted_model’. There are 4 files there but they are all 0 byte. Is there anything wrong with my script or trained model?
Log:
dewei@dewei-desktop:~/Documents$ python3 trtnew.py
2021-03-23 14:10:14.430063: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:10:18.424296: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-03-23 14:10:18.427041: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1
2021-03-23 14:10:18.430794: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:18.430967: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Found device 0 with properties:
pciBusID: 0000:00:00.0 name: Xavier computeCapability: 7.2
coreClock: 1.377GHz coreCount: 8 deviceMemorySize: 15.45GiB deviceMemoryBandwidth: 82.08GiB/s
2021-03-23 14:10:18.431051: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:10:18.433870: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-03-23 14:10:18.434018: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-03-23 14:10:18.436362: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-03-23 14:10:18.436923: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-03-23 14:10:18.439887: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-03-23 14:10:18.442150: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-03-23 14:10:18.442580: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-03-23 14:10:18.442821: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:18.443093: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:18.443165: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1888] Adding visible gpu devices: 0
2021-03-23 14:10:18.443233: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:10:19.914406: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1287] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-03-23 14:10:19.914585: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1293] 0
2021-03-23 14:10:19.914632: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1306] 0: N
2021-03-23 14:10:19.915310: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:19.915732: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:19.915991: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:19.916173: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5275 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2021-03-23 14:10:19.939951: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libnvinfer.so.7
2021-03-23 14:10:43.702242: I tensorflow/compiler/jit/xla_cpu_device.cc:41] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-03-23 14:10:43.702663: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:43.702828: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Found device 0 with properties:
2021-03-23 14:10:43.702931: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:10:43.703008: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-03-23 14:10:43.703057: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-03-23 14:10:43.703099: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-03-23 14:10:43.703139: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-03-23 14:10:43.703214: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-03-23 14:10:43.703259: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-03-23 14:10:43.703326: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-03-23 14:10:43.703507: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:43.703659: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:43.703714: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1888] Adding visible gpu devices: 0
2021-03-23 14:10:43.704764: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-03-23 14:10:43.705016: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:43.705138: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Found device 0 with properties:
2021-03-23 14:10:43.705185: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:10:43.705240: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-03-23 14:10:43.705281: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-03-23 14:10:43.705320: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-03-23 14:10:43.705360: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-03-23 14:10:43.705420: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-03-23 14:10:43.705460: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-03-23 14:10:43.705502: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-03-23 14:10:43.705621: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:43.705758: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:43.705831: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1888] Adding visible gpu devices: 0
2021-03-23 14:10:44.558311: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1287] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-03-23 14:10:44.558409: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1293] 0
2021-03-23 14:10:44.558439: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1306] 0: N
2021-03-23 14:10:44.558840: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:44.559141: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:10:44.559241: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5275 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2021-03-23 14:12:23.116985: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:23.117149: I tensorflow/core/grappler/devices.cc:69] Number of eligible GPUs (core count >= 8, compute capability >= 0.0): 1
2021-03-23 14:12:23.117397: I tensorflow/core/grappler/clusters/single_machine.cc:356] Starting new session
2021-03-23 14:12:23.118027: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-03-23 14:12:23.118256: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:23.118351: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Found device 0 with properties:
2021-03-23 14:12:23.118403: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:12:23.118499: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-03-23 14:12:23.118546: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-03-23 14:12:23.118607: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-03-23 14:12:23.118671: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-03-23 14:12:23.118723: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-03-23 14:12:23.118765: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-03-23 14:12:23.118805: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-03-23 14:12:23.118976: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:23.119127: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:23.119182: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1888] Adding visible gpu devices: 0
2021-03-23 14:12:23.119251: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1287] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-03-23 14:12:23.119275: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1293] 0
2021-03-23 14:12:23.119307: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1306] 0: N
2021-03-23 14:12:23.119447: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:23.119647: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:23.119752: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5275 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2021-03-23 14:12:23.120859: W tensorflow/core/platform/profile_utils/cpu_utils.cc:116] Failed to find bogomips or clock in /proc/cpuinfo; cannot determine CPU frequency
2021-03-23 14:12:25.657738: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:954] Optimization results for grappler item: graph_to_optimize
function_optimizer: Graph size after: 4997 nodes (4509), 10438 edges (9943), time = 386.766ms.
function_optimizer: function_optimizer did nothing. time = 4.548ms.
2021-03-23 14:12:56.356576: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:56.356765: I tensorflow/core/grappler/devices.cc:69] Number of eligible GPUs (core count >= 8, compute capability >= 0.0): 1
2021-03-23 14:12:56.356973: I tensorflow/core/grappler/clusters/single_machine.cc:356] Starting new session
2021-03-23 14:12:56.357372: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-03-23 14:12:56.357602: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:56.357721: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Found device 0 with properties:
2021-03-23 14:12:56.357775: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-03-23 14:12:56.357844: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-03-23 14:12:56.357889: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-03-23 14:12:56.358000: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-03-23 14:12:56.358046: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-03-23 14:12:56.358092: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-03-23 14:12:56.358154: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-03-23 14:12:56.358202: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-03-23 14:12:56.358328: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:56.358489: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:56.358554: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1888] Adding visible gpu devices: 0
2021-03-23 14:12:56.358627: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1287] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-03-23 14:12:56.358652: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1293] 0
2021-03-23 14:12:56.358698: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1306] 0: N
2021-03-23 14:12:56.358910: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:56.359117: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1005] ARM64 does not support NUMA - returning NUMA node zero
2021-03-23 14:12:56.359218: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1432] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5275 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2021-03-23 14:13:02.241299: I tensorflow/compiler/tf2tensorrt/segment/segment.cc:790] There are 621 ops of 52 different types in the graph that are not converted to TensorRT: Sum, GreaterEqual, Where, Reciprocal, ResizeBilinear, Split, TensorListGetItem, Cast, StopGradient, Pad, Slice, Mul, LogicalAnd, Range, Less, Merge, NextIteration, Switch, Select, Exit, LoopCond, Pack, NoOp, Size, Greater, GatherV2, ExpandDims, Identity, Assert, NonMaxSuppressionV5, Squeeze, Enter, TensorListFromTensor, AddV2, TensorListSetItem, Placeholder, TensorListStack, TensorListReserve, Const, Sub, Reshape, Transpose, Minimum, Shape, Maximum, StridedSlice, Fill, Unpack, ConcatV2, Exp, Equal, TopKV2, (For more information see https://docs.nvidia.com/deeplearning/frameworks/tf-trt-user-guide/index.html#supported-ops).
2021-03-23 14:13:04.137642: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:757] Number of TensorRT candidate segments: 4
2021-03-23 14:13:04.879147: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:851] Replaced segment 0 consisting of 4 nodes by StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/Area/TRTEngineOp_0_0.
2021-03-23 14:13:04.879443: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:851] Replaced segment 1 consisting of 4 nodes by StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/ClipToWindow/Area/TRTEngineOp_0_1.
2021-03-23 14:13:04.879687: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:851] Replaced segment 2 consisting of 87 nodes by StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/TRTEngineOp_0_2.
2021-03-23 14:13:04.880164: I tensorflow/compiler/tf2tensorrt/convert/convert_graph.cc:851] Replaced segment 3 consisting of 933 nodes by StatefulPartitionedCall/TRTEngineOp_0_3.
2021-03-23 14:13:06.515463: I tensorflow/core/grappler/optimizers/meta_optimizer.cc:954] Optimization results for grappler item: tf_graph
constant_folding: Graph size after: 2233 nodes (-2459), 7326 edges (-2725), time = 2068.16895ms.
layout: Graph size after: 2267 nodes (34), 7360 edges (34), time = 460.172ms.
constant_folding: Graph size after: 2267 nodes (0), 7360 edges (0), time = 240.303ms.
TensorRTOptimizer: Graph size after: 1247 nodes (-1020), 1707 edges (-5653), time = 3366.40698ms.
constant_folding: Graph size after: 1243 nodes (-4), 1707 edges (0), time = 133.495ms.
Optimization results for grappler item: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/TRTEngineOp_0_2_native_segment
constant_folding: Graph size after: 105 nodes (0), 104 edges (0), time = 5.242ms.
layout: Graph size after: 105 nodes (0), 104 edges (0), time = 5.332ms.
constant_folding: Graph size after: 105 nodes (0), 104 edges (0), time = 5.189ms.
TensorRTOptimizer: Graph size after: 105 nodes (0), 104 edges (0), time = 0.256ms.
constant_folding: Graph size after: 105 nodes (0), 104 edges (0), time = 5.106ms.
Optimization results for grappler item: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/Area/TRTEngineOp_0_0_native_segment
constant_folding: Graph size after: 9 nodes (0), 8 edges (0), time = 0.809ms.
layout: Graph size after: 9 nodes (0), 8 edges (0), time = 0.608ms.
constant_folding: Graph size after: 9 nodes (0), 8 edges (0), time = 0.576ms.
TensorRTOptimizer: Graph size after: 9 nodes (0), 8 edges (0), time = 0.028ms.
constant_folding: Graph size after: 9 nodes (0), 8 edges (0), time = 0.634ms.
Optimization results for grappler item: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/ClipToWindow/Area/TRTEngineOp_0_1_native_segment
constant_folding: Graph size after: 9 nodes (0), 8 edges (0), time = 0.727ms.
layout: Graph size after: 9 nodes (0), 8 edges (0), time = 0.682ms.
constant_folding: Graph size after: 9 nodes (0), 8 edges (0), time = 0.623ms.
TensorRTOptimizer: Graph size after: 9 nodes (0), 8 edges (0), time = 0.029ms.
Optimization results for grappler item: StatefulPartitionedCall/TRTEngineOp_0_3_native_segment
constant_folding: Graph size after: 937 nodes (0), 966 edges (0), time = 179.573ms.
layout: Graph size after: 937 nodes (0), 966 edges (0), time = 381.25ms.
constant_folding: Graph size after: 937 nodes (0), 966 edges (0), time = 179.629ms.
TensorRTOptimizer: Graph size after: 937 nodes (0), 966 edges (0), time = 36.968ms.
constant_folding: Graph size after: 937 nodes (0), 966 edges (0), time = 182.959ms.
2021-03-23 14:33:15.708868: I tensorflow/compiler/mlir/mlir_graph_optimization_pass.cc:116] None of the MLIR optimization passes are enabled (registered 2)
2021-03-23 14:33:17.822496: I tensorflow/compiler/tf2tensorrt/common/utils.cc:58] Linked TensorRT version: 7.1.3
2021-03-23 14:33:17.823162: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libnvinfer.so.7
2021-03-23 14:33:17.824186: I tensorflow/compiler/tf2tensorrt/common/utils.cc:60] Loaded TensorRT version: 7.1.3
2021-03-23 14:33:17.844918: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libnvinfer_plugin.so.7
WARNING:absl:Found untraced functions such as restored_function_body, restored_function_body, restored_function_body, restored_function_body, restored_function_body while saving (showing 5 of 315). These functions will not be directly callable after loading.
