The confusion of device tree configuration in CSI
hello:
I use jetson orin nx 16G(Linux version 36.4.3 GA),Configuration method as shown in the following figure:
and I set in this:
using IMX219 Daul is Normal drawing output int CAM0 or CAM1 ,
but using IMX219-C seting in CAM0,I can use commands media-ctl -p -d /dev/media0 as fllow:
root@yz-desktop:/home/yz# media-ctl -p -d /dev/media0
Media controller API version 5.15.148
Media device information
driver          tegra-camrtc-ca
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  5.15.148
Device topology
- entity 1: 13e00000.host1x:nvcsi@15a00000- (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
        pad0: Sink
                <- "imx219 9-0010":0 [ENABLED]
        pad1: Source
                -> "vi-output, imx219 9-0010":0 [ENABLED]
- entity 4: imx219 9-0010 (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev1
        pad0: Source
                [fmt:SRGGB10_1X10/3280x2464@1/21 field:none colorspace:srgb]
                -> "13e00000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 6: vi-output, imx219 9-0010 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                <- "13e00000.host1x:nvcsi@15a00000-":1 [ENABLED]
No official device tree files have been modified,My customized board, modeled after the official device tree example, also experiences similar issues. and I just want a camera.
I don’t think I can understand what’s your problem here.
Please give the more specific to tell what’s your request.
hello:
I use imx566 in 4 lane,10bit, external clock 74.25Mhz,lane rate1188 Mpbs,hardware circuit as follows:
and my device tree file:
#include <dt-bindings/media/camera.h>
#define CAM_PWDN		TEGRA234_MAIN_GPIO(Y, 3) //cam的使能管脚,110
#define CAM_XCLR_PN		TEGRA234_MAIN_GPIO(H, 6) //xclr 管脚,114
#define CAM_PG_EN		TEGRA234_MAIN_GPIO(Y, 1) //电路板上电完成,管脚108
#define CAM_INCK_EN		TEGRA234_MAIN_GPIO(P, 0) //sensor的时钟使能,管脚116
#define CAM_XMASTER	    TEGRA234_MAIN_GPIO(Y, 2) //输出104
#define BUS_WIDTH 4
#define VC_MIPI_CAMERAS 1
#define NUM_LANES "4"
#define PORT_INDEX 2
	tegra-capture-vi  {
		num-channels = <1>; //接入相机数量
		ports {
			#address-cells = <VC_MIPI_CAMERAS>;
			#size-cells = <0>;
			vi_port0: port@0 {
				reg = <0>;
				bopixel_imx566_vi_in0: endpoint {
					port-index = <PORT_INDEX>;
					bus-width = <BUS_WIDTH>;
					remote-endpoint = <&bopixel_imx566_csi_out0>;
	host1x@13e00000 {
		nvcsi@15a00000 {
			num-channels = <VC_MIPI_CAMERAS>;
			#address-cells = <1>;
			#size-cells = <0>;
			csi_chan0: channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					csi_chan0_port0: port@0 {
						reg = <0>;
						bopixel_imx566_csi_in0: endpoint@0 {
							remote-endpoint = <&bopixel_imx566_out0>;
					csi_chan0_port1: port@1 {
						reg = <1>;
						bopixel_imx566_csi_out0: endpoint@1 {
							remote-endpoint = <&bopixel_imx566_vi_in0>;
	i2c@3160000{
		status = "okay";  // 启用该设备
		imx566_cam0: bopixel_imx566_a@1a {
			status = "okay";
			compatible = "sony,imx566";
			/* I2C device address */
			reg = <0x1a>;
			pwdn-gpios = <&tegra_main_gpio CAM_PWDN GPIO_ACTIVE_HIGH>;
			xclr-gpios = <&tegra_main_gpio CAM_XCLR_PN GPIO_ACTIVE_HIGH>;
			pg-gpios = <&tegra_main_gpio CAM_PG_EN GPIO_ACTIVE_HIGH>;
			inck-gpios = <&tegra_main_gpio CAM_INCK_EN GPIO_ACTIVE_HIGH>;
			xmaster-gpios = <&tegra_main_gpio CAM_XMASTER GPIO_ACTIVE_HIGH>;
			pwms = <&tegra_pwm5 0 1000000>;   // 两路PWM,分别1000us周期,1000us周期
   			pwm-names = "pwm-xhs";
            trigger_mode            = "0";
            io_mode                 = "0";
			/* V4L2 device node location */
			devnode = "video0";
			/* Physical dimensions of sensor */
			physical_w = "3.680";
			physical_h = "2.760";
			sensor_model = "imx566";
			use_sensor_mode_id = "true";
			mode0 {
				// mclk_khz = "37125";
				num_lanes = NUM_LANES;
				tegra_sinterface = "serial_c";
				phy_mode = "DPHY";
				discontinuous_clk = "yes";
				dpcm_enable = "false";
				cil_settletime = "0";
				lane_polarity = "0";
				active_w = "2840";
				active_h = "2840";
				mode_type = "bayer";
				pixel_phase = "rggb";
				csi_pixel_bit_depth = "10";
				// readout_orientation = "90";
				line_length = "3448";
				inherent_gain = "1";
				mclk_multiplier = "12.8";
				pix_clk_hz = "475200000";
				gain_factor = "16";
				framerate_factor = "1000000";
				exposure_factor = "1000000";
				min_gain_val = "16"; /* 1.00x */
				max_gain_val = "170"; /* 10.66x */
				step_gain_val = "1";
				default_gain = "16"; /* 1.00x */
				min_hdr_ratio = "1";
				max_hdr_ratio = "1";
				min_framerate = "2000000"; /* 2.0 fps */
				max_framerate = "21000000"; /* 21.0 fps */
				step_framerate = "1";
				default_framerate = "21000000"; /* 21.0 fps */
				min_exp_time = "13"; /* us */
				max_exp_time = "683709"; /* us */
				step_exp_time = "1";
				default_exp_time = "2495"; /* us */
				embedded_metadata_height = "2";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					bopixel_imx566_out0: endpoint {
						remote-endpoint = <&bopixel_imx566_csi_in0>;
	tcp: tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		num_csi_lanes = <BUS_WIDTH>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <240000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		modules {
			cam_module0: module0 {
				badge = "jakku_front_RBP194";
				position = "front";
				orientation = "1";
				cam_module0_drivernode0: drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "imx566 9-001a";
					proc-device-tree = "/proc/device-tree/i2c@3160000/bopixel_imx566_a@1a";
//end
but report errors
[ 2415.673152] bwmgr API not supported
[ 2418.328054] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2418.328076] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2418.329013] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 2418.329019] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 2418.329024] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 2418.329026] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 2418.329228] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 2420.887885] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2420.887900] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2420.889003] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 2420.889008] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 2420.889012] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 2420.889014] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 2420.889218] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
root@tegra-ubuntu:/home/yz/nfs# sudo media-ctl -p -d /dev/media0
Media controller API version 5.10.120
serial
bus info
hw revision     0x3
driver version  5.10.120
Device topology
- entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
        pad0: Sink
                <- "imx566 0-001a":0 [ENABLED]
        pad1: Source
                -> "vi-output, imx566 0-001a":0 [ENABLED]
- entity 4: imx566 0-001a (1 pad, 1 link)
        pad0: Source
                [fmt:SRGGB10_1X10/2840x2840 field:none colorspace:srgb
                 crop.bounds:(0,0)/2840x2840
                 crop:(0,0)/2840x2840
                 compose.bounds:(0,0)/2840x2840
                 compose:(0,0)/2840x2840]
                -> "13e40000.host1x:nvcsi@15a00000-":0 [ENABLED]
- entity 6: vi-output, imx566 0-001a (1 pad, 1 link)
        pad0: Sink
                <- "13e40000.host1x:nvcsi@15a00000-":1 [ENABLED]
Please help check the device tree configuration, or other configurations are missing. Thank you.
Get the trace log for the capture failed.
root@tegra-ubuntu:/home/yz/nfs# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 33/33   #P:4
#                                _-------=> irqs-off
#                               / _------=> need-resched
#                              | / _-----=> need-resched-lazy
#                              || / _----=> hardirq/softirq
#                              ||| / _---=> preempt-depth
#                              |||| / _--=> preempt-lazy-depth
#                              ||||| / _-=> migrate-disable
#                              |||||| /     delay
#           TASK-PID     CPU#  |||||||  TIMESTAMP  FUNCTION
     kworker/0:1-19631   [000] .......  4028.789198: rtcpu_string: tstamp:126290976343 id:0x04010000 str:"VM0 deactivating."
          v4l_id-26202   [003] .......  4044.257597: tegra_channel_open: vi-output, imx566 0-001a
          v4l_id-26202   [003] .......  4044.257753: tegra_channel_close: vi-output, imx566 0-001a
        v4l2-ctl-26340   [001] .......  4066.556171: tegra_channel_open: vi-output, imx566 0-001a
        v4l2-ctl-26340   [001] .......  4066.574397: tegra_channel_set_power: imx566 0-001a : 0x1
        v4l2-ctl-26340   [001] .......  4066.574408: camera_common_s_power: status : 0x1
        v4l2-ctl-26340   [001] .......  4066.574418: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-26340   [001] .......  4066.574420: csi_s_power: enable : 0x1
        v4l2-ctl-26340   [001] .......  4066.575153: tegra_channel_capture_setup: vnc_id 0 W 2840 H 2840 fmt c4
        v4l2-ctl-26340   [001] .......  4066.581111: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-26340   [001] .......  4066.583241: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-26340   [001] .......  4066.583243: csi_s_stream: enable : 0x1
        v4l2-ctl-26340   [001] .......  4066.583557: tegra_channel_set_stream: imx566 0-001a : 0x1
     kworker/0:2-26193   [000] .......  4066.621620: rtcpu_string: tstamp:127472982136 id:0x04010000 str:"VM0 activating."
     kworker/0:2-26193   [000] .......  4066.621623: rtcpu_vinotify_event: tstamp:127473430622 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4079139295712 data:0x759d580010000000
     kworker/0:2-26193   [000] .......  4066.621623: rtcpu_vinotify_event: tstamp:127473430808 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4079139302144 data:0x0000000031000001
     kworker/0:2-26193   [000] .......  4066.621624: rtcpu_vinotify_event: tstamp:127473430969 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4079139347488 data:0x759d550010000000
     kworker/0:2-26193   [000] .......  4066.621624: rtcpu_vinotify_event: tstamp:127473431113 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4079139354080 data:0x0000000031000002
 vi-output, imx5-26342   [000] .......  4069.122836: tegra_channel_capture_setup: vnc_id 0 W 2840 H 2840 fmt c4
     kworker/0:2-26193   [000] .......  4069.149651: rtcpu_vinotify_event: tstamp:127552871009 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4081681157312 data:0x759d580010000000
     kworker/0:2-26193   [000] .......  4069.149653: rtcpu_vinotify_event: tstamp:127552871148 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4081681163776 data:0x0000000031000001
     kworker/0:2-26193   [000] .......  4069.149654: rtcpu_vinotify_event: tstamp:127552871301 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4081681209120 data:0x759d550010000000
     kworker/0:2-26193   [000] .......  4069.149654: rtcpu_vinotify_event: tstamp:127552871433 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:4081681215648 data:0x0000000031000002
        v4l2-ctl-26340   [002] .......  4071.019429: tegra_channel_close: vi-output, imx566 0-001a
 vi-output, imx5-26342   [000] .......  4071.650836: tegra_channel_capture_setup: vnc_id 0 W 2840 H 2840 fmt c4
        v4l2-ctl-26340   [001] .......  4071.650949: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-26340   [001] .......  4071.650951: tegra_channel_set_stream: imx566 0-001a : 0x0
        v4l2-ctl-26340   [001] .......  4071.650953: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-26340   [001] .......  4071.650955: csi_s_stream: enable : 0x0
        v4l2-ctl-26340   [001] .......  4071.652699: tegra_channel_set_power: imx566 0-001a : 0x0
        v4l2-ctl-26340   [001] .......  4071.652705: camera_common_s_power: status : 0x0
        v4l2-ctl-26340   [001] .......  4071.652714: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-26340   [001] .......  4071.652716: csi_s_power: enable : 0x0
Looks like doesn’t receive any validate data from the sensor.
Maybe probe the sensor output signal to confirm.
