The data of csi bayer image is too large
Hi, I use v4l2 to obtain bayer image from imx 219 camera on jetson nx. I get the raw image, but I think the data is not right. I use the following command to get raw image from this post.
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=imx219.raw
I think the lagest value of the data is 1024, But when I read the raw image by using python, I find most values are bigger than 1024.
>>> import numpy as np
>>> f = open('imx219.raw', 'rb')
>>> rawdata = np.fromfile(f, dtype=np.uint16, count=1080 * 1920)
>>> print(rawdata)
[4100 4292 4164 ... 4100 4100 4164]
I want to know the reason, thanks in advance.
hello 85704592,
you may try using 3rdparty tools, such as 7yuv to view the raw files directly.
I can use the 7yuv to view the file, but in the HEX mode with 16bit, the value is also bigger than 1024.
Because I want to scale the value to 8bit, I need to know what value I shoud to divide.
hello 85704592,
there’s MSBs replicated.
please access download center for Xavier TRM.
you may refer to page-1394, for [Figure 7.17] to understand the Raw memory formats.
Got it. Thanks.
