[b]We want to connect 1080P cameras to xavier, its image format is raw16. But there are some problems.
I set "csi_pixel_bit_depth = “16"” in camera dtsi, but the camera driver cannot probe. I find it report “Unsupported pixel format” error in sensor_common_parse_image_props() of sensor_common.c for the reason that it cannot recognize raw16 in extract_pixel_format().[/b]
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
*format = V4L2_PIX_FMT_SBGGR10;
else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
*format = V4L2_PIX_FMT_SRGGB10;
else if (strncmp(pixel_t, "bayer_grbg10", size) == 0)
*format = V4L2_PIX_FMT_SGRBG10;
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
*format = V4L2_PIX_FMT_SRGGB12;
else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_dol_rggb10", size) == 0)
else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
return 0;
The vi5_setup_surface() in “vi5_fops.c” will match data type according to the settings in dtsi, but the “enum tegra_image_dt” has no RAW16.
enum tegra_image_dt {
TEGRA_IMAGE_DT_YUV420_8 = 24,
TEGRA_IMAGE_DT_YUV420_10,
TEGRA_IMAGE_DT_YUV420CSPS_8 = 28,
TEGRA_IMAGE_DT_YUV420CSPS_10,
TEGRA_IMAGE_DT_YUV422_8,
TEGRA_IMAGE_DT_YUV422_10,
TEGRA_IMAGE_DT_RGB444,
TEGRA_IMAGE_DT_RGB555,
TEGRA_IMAGE_DT_RGB565,
TEGRA_IMAGE_DT_RGB666,
TEGRA_IMAGE_DT_RGB888,
TEGRA_IMAGE_DT_RAW6 = 40,
TEGRA_IMAGE_DT_RAW7,
TEGRA_IMAGE_DT_RAW8,
TEGRA_IMAGE_DT_RAW10,
TEGRA_IMAGE_DT_RAW12,
TEGRA_IMAGE_DT_RAW14,
So how can I get raw16 data from our cameras? Thank you.
