Not mean one shot solution actually, I also happy to try many possible solutions. I just suggest that reading the existing contents before replying, otherwise it may have a relpy on a very different way…
For the reply, it is not for image’s solution, and the topic is obvious for seeking the solution about image.
And, please check if you run the exactly same instructions as below
$ sudo tar -xvf deepstream_sdk_v5.1.0_jetson.tbz2 -C /
$ cd /opt/nvidia/deepstream/deepstream-5.1
$ sudo ./install.sh
$ sudo ldconfig
** ERROR: <main:655>: Failed to set pipeline to PAUSED
Quitting
ERROR from src_elem: Cannot identify device '/dev/video0'.
Debug info: v4l2_calls.c(609): gst_v4l2_open (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
system error: No such file or directory
App run failed
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-eglcore.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-glcore.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-tls.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/libnvidia-glsi.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rmapi-tegra.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glvkspirv.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-tls.so.32.5.0 is empty, not checked.
/sbin/ldconfig.real: File /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.32.5.0 is empty, not checked.
Sure, Originally I don’t know the issue in this topic would also cause another issue, that’s why I opened another topic on 29th May, Let’s discuss under that topic. Thanks for the support on this topic.
