The image of the self-made camera becomes the image of the perspective camera
Isaac 2022.1.1
I am doing reinforcement learning using images using Isaac sim. There is a problem that the camera image of the agent, which is the observed value, becomes the image of the perspective camera.
Below is the camera class.
class Camera:
    def __init__(self, camera_prim_path: str, width: int, height: int, fov, near, far, headless: bool = False, path: str = "/World"):
        Args:
            camera_prim_path: The camera prim path
            width: The horizontal image resolution in pixels
            height: The vertical image resolution in pixels
            fov: The field of view of the camera
            near: The near plane distance
            far: The far plane distance
        from omni.isaac.core.utils.stage import add_reference_to_stage
        from omni.isaac.core.utils.viewports import set_camera_view
        from omni.isaac.synthetic_utils import SyntheticDataHelper
        self.sd_helper = SyntheticDataHelper()
        import omni.kit.viewport.utility
        from omni.kit.viewport.utility import get_active_viewport_window
        import omni.kit.commands
        #from omni.kit.viewport.utility import get_active_viewport
        from pxr import Sdf, Usd, UsdGeom
        self._width = width
        self._height = height
        self.__fov = fov
        self.__near = near
        self.__far = far
        # TODO: see why it is not 62 degrees the horizontalAperture !!!!
        self.__aspect = self._width / self._height
        self._view_matrix = None
        self.camera_prim_path = camera_prim_path
        fov_horizontal = self.__aspect * fov
        focal_length = 1.88
        attributes = {"horizontalAperture": 2*focal_length*math.tan(fov_horizontal*math.pi/180/2),
                      "verticalAperture": 2*focal_length*math.tan(fov*math.pi/180/2),
                      "focalLength": focal_length,
                      "clippingRange": (self.__near, self.__far)
        self.stage = omni.usd.get_context().get_stage()
        self.camera_prim = self.stage.GetPrimAtPath(self.camera_prim_path)
        # Set as current camera
        if headless:
            viewport_interface = omni.kit.viewport_legacy.get_viewport_interface()
            self.viewport = viewport_interface.get_viewport_window()
            viewport_interface = omni.kit.viewport.utility.get_active_viewport()
            self.viewport = omni.kit.viewport.utility.get_active_viewport()
            #self.viewport = omni.kit.viewport.utilityget_active_viewport_window
        else:
            viewport_handle = omni.kit.viewport_legacy.get_viewport_interface().create_instance()
            list_viewports = omni.kit.viewport_legacy.get_viewport_interface().get_instance_list()
            new_viewport_name = omni.kit.viewport_legacy.get_viewport_interface().get_viewport_window_name(
                viewport_handle
            self.viewport = omni.kit.viewport_legacy.get_viewport_interface(
            ).get_viewport_window(viewport_handle)
            window_width = 200
            window_height = 200
            self.viewport.set_window_size(window_width, window_height)
            self.viewport.set_window_pos(
                800, window_height*(len(list_viewports)-2))
        self.viewport.set_active_camera(camera_prim_path)
        #self.viewport.camera_path = camera_prim_path
        self.viewport.set_texture_resolution((self._width,self._height))
        active_viewport = omni.kit.viewport.utility.get_active_viewport()
        self.sd_helper.initialize(["rgb"], self.viewport)
    def get_image(self):
        # Get ground truths
        #active_viewport = omni.kit.viewport.utility.get_active_viewport()
        gt = self.sd_helper.get_groundtruth(
                "rgb",
                # "depthLinear",
                # "depth",
                # "boundingBox2DTight",
                # "boundingBox2DLoose",
                # "instanceSegmentation",
                # "semanticSegmentation",
                # "boundingBox3D",
                # "camera",
                # "pose"
            self.viewport,
            verify_sensor_init=False,
            wait_for_sensor_data=0.0
        rgb = gt["rgb"]
        return rgb
Below is an instance.
l_camera_prim_path = "/Fork/Fork_mini_1_twin_camera/Fork_mini_1/Frame/Camera"
        #l_camera_prim_path = "/Fork/Fork_mini_1/Frame/Camera"
        r_camera_prim_path = "/Fork/Fork_mini_1_twin_camera/Fork_mini_1/Frame/r_Camera"
        #r_camera_prim_path = "/Fork/Fork_mini_1/Frame/r_Camera"
        self._l_cameras = Camera(camera_prim_path=l_camera_prim_path,
                                 width=256, height=256, fov=45, near=0.10, far=4, headless=True)
        self._r_cameras = Camera(camera_prim_path=r_camera_prim_path,
I checked the image like this as a test.
    def get_observations(self):
        # image
        cams_l = self._l_cameras
        img_l = Image.fromarray(cams_l.get_image()).convert("RGB")
        # debug
        # image save pass
        img_path= f"/home/sfai20/python_ws/RL_simple_fork_Q2/img/image_{self.counter}.png"
        img_l.save(img_path)
The result was a perspective camera image.
image_6
The agent has a camera like this.
How can I get the agent’s camera image?
The following warning is displayed. Is it related?
[Warning] [omni.kit.window.viewport.plugin] Specified bound camera in usd does not exist: /Fork/Fork_mini_1_twin_camera/Fork_mini_1/Frame/Camera
Hi there,
would using the Camera sensor class or Replicator API to access the data solve your issues? If not can you provide a short working script to test? Thanks!
I simply mistyped the camera prim pass. Also, I didn’t know that perspective camera images would be acquired instead.
