Our program based on multimedia_apis has some problems on memory usage when encoding 3840x2160 video.
When Gst command below is called(3840x2160 encode), The memory usage is about 150MB
gst-launch-1.0 v4l2src device="/dev/video1" ! 'video/x-raw, width=1280, height=720, format=(string)I420, framerate=25/1' ! nvvidconv ! 'video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)I420' ! omxh265enc bitrate=2000000 ! 'video/x-h265, stream-format=(string)byte-stream' ! rtph265pay pt=98 ! udpsink host=192.xxx.xx.xx port=6000
When use multimedia_apis to implement similar function, The memory usage is rather big, 511MB
I build the demo: tegra_multimedia_api_bk\samples\01_video_encode, and then run
./video_encode Kimono_1920x1080.yuv 3840 2160 H265 Kimono_1920x1080.h265 -br 410000 -ifi 25 -fps 25 1 -hpt 1
I also tried to reduce the buffer number from 10 to 4 (in video_encode_main.cpp, line 838 843 848 855 1099)
The memory usage is reduced as well, about 360M, but it's still rather bigger than gstreamer.
So, what’s the reason? How can I optimize our program to lower memory usage?
Thx!
One optimization is to do memory map/unmap dynamically:
ret = ctx.enc->output_plane.mapOutputBuffers(v4l2_buf, ctx.output_plane_fd[i]);
ret = ctx.enc->output_plane.unmapOutputBuffers(i, ctx.output_plane_fd[i]);
In default code flow, it is executed in initialization and termination. You can execute it for reading every frame.
DaneLLL:
So, If this helps on decoder as well?
And here is some more questions…
Why does multimeida_apis program cost more RAM than gstreamer command?
Do mm-api and gstreamer use different low-level libraries?
Or they work in different ways?
Thanks very much!!
By default the decoded buffers are not mapped to CPU. If you want to do post-processing on decoded buffers, you can dynamically map/unmap the buffers via NvBuffer APIs.
The main difference should be in buffer map/unmap.
No, low-level libraries are the same
One is in gstreamer and the other is in v4l2.
DaneLLL:
I tried to implement dynamic map/unmap based on the demo 01_video_encode, my thought is(just show important lines):
delete code between about 909 and 1085(the for loop to map memory for output plane)
in the while loop after the for loop, call
ctx.enc->output_plane.getNthBuffer(0)
ctx.enc->output_plane.mapOutputBuffers(v4l2_buf, ctx.output_plane_fd[0])
then call read_video_frame(), etc.(not change)
after qBuffer() is called, call dqBuffer(), then call
ctx.enc->output_plane.unmapOutputBuffers(0, ctx.output_plane_fd[0])
But the memory cost is almost the same(510MB for 4K encode, output h265 file is the same), so… Am I wrong and how to fix this? Or can you give me some code or demo using dynamic map/unmap?
Thanks!! :-)
Please share how you profile memory usage.
I use the tool: tegrastats
I opened two ssh, one runs video_encode, the other runs the command:
./tegrastats --interval 50 | cut -c1-15
to show memmory usage
[memory usage when video_encode is running] - [memory usage when video_encode isn’t running] is about 510MB.
I carried out another test, in the demo:
setup_output_dmabuf(&ctx, NUM_BUFFERS)
The Macro NUM_BUFFERS is defined as 10, 6, 4.
respectively, the memory usage is 510MB, 510MB, 359MB not relevant about if I dynamically map/unmap.
We will check and clarify.
