Hello, There is a issue when running demo NvFBCToGLEnc of Capture_Linux_v8.0.8 or v7.1.9.
When the text color is Geen(ForeColor)/Black(BackColor), the text in output.h264 created by NvFBCToGLEnc will blurred.
Should adjusting some nvfbc or nvenc paramter?
Default chroma subsampling behavior and not an issue. You would need to use YUV444 to remove chroma subsampling effects
Thanks, using YUV444, the color is correct.
